Can't find my partition on HD
Tallys
#1 Post by Tallys »
My boss dropped water on his notebook and his slave hard drive don't show any partition. He still appears on Disk Manager on windows as Unknown and Not Allocated.
These are two images from the Analyze option
and a part from the log, the same message keep appearing
file_pread(X,XX,buffer,XX(X/X/XX)) ReadFile O dispositivo não está pronto.
. Translating to "The Device is not ready"
Can someone help me?
Thanks!
Thu Jan  9 16:26:44 2020
TestDisk 7.2-WIP, Data Recovery Utility, December 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=103833785344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=395247091712
filewin32_getfilesize(\\.\F:) GetFileSize err Função incorreta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Função incorreta.
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500LM012 HN-M500MBB, S/N:S2WCJ5CD403191, FW:2AR10001
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MQ04ABF100, S/N:49164C304, FW:JUF0
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA MQ04ABF100
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile O dispositivo não está pronto.
file_pread(5,3,buffer,48(0/0/49)) ReadFile O dispositivo não está pronto.
file_pread(5,3,buffer,95(0/1/33)) ReadFile O dispositivo não está pronto.
file_pread(5,8,buffer,111(0/1/49)) ReadFile O dispositivo não está pronto.
file_pread(5,11,buffer,158(0/2/33)) ReadFile O dispositivo não está pronto.
file_pread(5,2,buffer,2080(0/33/2)) ReadFile O dispositivo não está pronto.
Re: Can't find my partition on HD
It's an hardware problem, all read operations failed, you should contact a data recovery company.
