I've recently upgraded my Shuttle PC (SZ68R5) from Windows 7 to Windows 10 and in the process, the second partition on a Seagate ST4000DM000 4TB drive has disappeared. I unfortunately can't remember the precise detail of how the drive came to be divided into two but I believe it was because the PC has a BIOS and therefore can only access partitions of a maximum size of 2TB.
I've now run Teskdisk and it seemed to find the missing second partition. I did what I thought was required to repair the partition but now, after a reboot, neither partitions are working in Windows. Instead, I have two drives, one of which reports a corrupted disk structure and the other claims to be un-formatted. I'm now out of my depth and would like to seek help before I make matters worse.
Thanks in anticipation...
The Teskdisk log now follows:
Wed Jan 8 19:22:57 2020
TestDisk 7.2-WIP, Data Recovery Utility, December 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=479515041792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2199022206976
Disk /dev/sda - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - ST4000DM000-1F2168, S/N:W301738E, FW:CC54
Disk /dev/sdb - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - KINGSTON SUV500MS480G, S/N:50026B7782667038, FW:003056RI
Disk /dev/sda - 4000 GB / 3726 GiB - ST4000DM000-1F2168
Analyse Disk /dev/sda - 4000 GB / 3726 GiB - CHS 486401 255 63
NTFS at 0/32/33
Info: size boot_sector 4294965241, partition 4294965248
1 * HPFS - NTFS 0 32 33 267349 89 4 4294965248 [Data]
NTFS at 0/1/1
filesystem size 3907023554
mftmirr_lcn 91571500
HPFS - NTFS 0 1 1 243200 247 56 3907023554
BAD_RS LBA=4294973440 2048
NTFS at 267349/186/38
filesystem size 3519055872
mftmirr_lcn 2
HPFS - NTFS 267349 186 38 486400 211 19 3519055872 [Backups]
NTFS, blocksize=4096, 1801 GB / 1678 GiB
file_pread(4,2,buffer,7814037503(486401/86/21)) lseek err Invalid argument
file_pread(4,1,buffer,7814037503(486401/86/21)) lseek err Invalid argument
file_pread(4,2,buffer,7814037504(486401/86/22)) lseek err Invalid argument
file_pread(4,1,buffer,7814037504(486401/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,7814037248(486401/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,7814037248(486401/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,7814037376(486401/84/20)) lseek err Invalid argument
file_pread(4,7,buffer,7814037505(486401/86/23)) lseek err Invalid argument
file_pread(4,8,buffer,7814037512(486401/86/30)) lseek err Invalid argument
file_pread(4,3,buffer,7814037520(486401/86/38)) lseek err Invalid argument
file_pread(4,3,buffer,7814037567(486401/87/22)) lseek err Invalid argument
file_pread(4,8,buffer,7814037583(486401/87/38)) lseek err Invalid argument
file_pread(4,11,buffer,7814037630(486401/88/22)) lseek err Invalid argument
file_pread(4,2,buffer,7814039552(486401/118/54)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 255 but the correct value may be 8.
* HPFS - NTFS 0 1 1 243200 254 63 3907024002
P HPFS - NTFS 267349 186 38 486400 211 19 3519055872 [Backups]
1 * HPFS - NTFS 0 1 1 243200 254 63 3907024002
2 P HPFS - NTFS 267349 186 38 486400 211 19 3519055872 [Backups]
write!
Second partition missing after Windows 7 -> 10 upgrade
Re: Second partition missing after Windows 7 -> 10 upgrade
Every PC have a BIOS. Your disk isn't using 4096 bytes sector and your disk is over 2 TB, you should select EFI GPT, Analyse, Quick Search, for each partition, use 'p' to list the files.
If it's ok, on next screen, choose Write, confirm, Quit and restart your computer.
OK, my main concern is that I selected Write in the session logged above and I think I may have made my situation worse.
I've just followed your advice to select EFI GPT and when I use 'p' to list the files, I get "Can't open filesystem. Filesystem seems damaged." for each. My log for that session follows...
Thanks
Mon Jan 13 10:07:49 2020
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=1993064448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=1993064448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396289024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1801756606464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=1993064448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=1258029056
Disk /dev/sdg - 1993 MB / 1900 MiB - CHS 242 255 63, sector size=512 - USB DISK, S/N:9BBC0A00F31D1A34, FW:PMAP
Drive O: - 1258 MB / 1199 MiB - CHS 2457088 1 1, sector size=512
Partition table type: EFI GPT
Trying alternate GPT
NTFS at 0/1/1
NTFS part_offset=32256, part_size=2000396059648, sector_size=512
NTFS at 0/1/1
MS Data 63 3907023616 3907023554
NTFS at 243200/254/63
MS Data 511 3907024064 3907023554
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
MS Data 3907024064 7814047617 3907023554
file_pread(4,1,buffer,7814047618(486401/246/56)) lseek err Invalid argument
file_pread(4,1,buffer,7814047619(486401/246/57)) lseek err Invalid argument
file_pread(4,14,buffer,7814047620(486401/246/58)) lseek err Invalid argument
file_pread(4,3,buffer,7814047634(486401/247/9)) lseek err Invalid argument
file_pread(4,3,buffer,7814047681(486401/247/56)) lseek err Invalid argument
file_pread(4,8,buffer,7814047697(486401/248/9)) lseek err Invalid argument
file_pread(4,11,buffer,7814047744(486401/248/56)) lseek err Invalid argument
file_pread(4,2,buffer,7814049666(486402/24/25)) lseek err Invalid argument
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Thanks
NTFS at 0/1/1
NTFS at 0/1/1
I've run it once more, with the Intel setting and it seemed to identify the second partition, certainly it listed the files I expected to see. I'm still not confident how to restore this partition and whether that can cause any more harm:
Mon Jan 13 11:23:03 2020
NTFS at 0/1/1
Info: size boot_sector 3907023554, partition 3907024002
NTFS at 267349/89/4
Error: size boot_sector 4294965241 > partition 3519055872
Invalid NTFS or exFAT boot
2 P HPFS - NTFS 267349 89 4 486400 113 48 3519055872
NTFS at 0/1/1
NTFS at 267349/89/4
filesystem size 4294965241
mft_lcn 770042
mftmirr_lcn 91534057
HPFS - NTFS 0 32 40 267349 89 4 4294965241
NTFS found using backup sector, blocksize=4096, 2199 GB / 2047 GiB
NTFS at 267349/89/4
mft_lcn 770042
HPFS - NTFS 267349 89 4 534698 145 31 4294965241
NTFS, blocksize=4096, 2199 GB / 2047 GiB
This partition ends after the disk limits. (start=4294967295, size=4294965241, end=8589932535, disk end=7814037168)
mftmirr_lcn 2
The harddisk (4000 GB / 3726 GiB) seems too small! (< 4398 GB / 4095 GiB)
* HPFS - NTFS 267349 186 38 486400 211 19 3519055872 [Backups]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 16-Dec-2019 21:03 .
5 dr-xr-xr-x 0 0 0 16-Dec-2019 21:03 ..
***** REMOVED FOUND FILES *****
56264 -r--r--r-- 0 0 430592 12-Mar-2019 19:05 EUMONBMP.SYS
56271 -r--r--r-- 0 0 4096 24-Sep-2017 21:37 {01EE95A1-5DCB-463C-ABDB-DAF50B15835C}.CBM
Not an exFAT boot sector.
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 267349 154 6 486400 211 19 3519057920
5 L HPFS - NTFS 267349 186 38 486400 211 19 3519055872 [Backups]
write_all_log_i386: CHS: 267349/154/6,lba=4294971392
NTFS at 0/1/1
NTFS at 267349/89/4
NTFS at 0/1/1
NTFS at 267349/89/4
mft_lcn 770042
NTFS at 267349/89/4
mft_lcn 770042
mftmirr_lcn 2
After Deeper Search, use the arrow keys to switch the partitions from D(eleted) to P(rimary) to get
On next screen, choose Write, confirm, Quit
After a reboot, run testdisk again, Advanced, select the first partition, Boot, List. If you can see your files, choose BackupBS, confirm, Quit
D HPFS - NTFS 0 1 1 243200 254 63 3907024002
P HPFS - NTFS 0 32 40 267349 89 4 4294965241
I've tried to do this, however the PC won't boot with the disk attached. I unplugged the disk while the PC rebooted and then reconnected it once Windows had started. I ran the second steps as advised but following the boot screen, 'list' wasn't available. My log follows:
Tue Jan 14 09:22:55 2020
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=4000787030016
Disk /dev/sda - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - KINGSTON SUV500MS480G, S/N:50026B7782667038, FW:003056RI
Disk /dev/sdf - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - ST4000DM000-1F2168, S/N:W301738E, FW:CC54
Disk /dev/sdf - 4000 GB / 3726 GiB - ST4000DM000-1F2168
NTFS at 267349/89/4
1 P HPFS - NTFS 267349 89 4 486400 113 48 3519055872
ntfs_boot_sector
NTFS at 267349/89/4
filesystem size 4294965241 1
sectors_per_cluster 8 0
mft_lcn 770042 0
mftmirr_lcn 91534057 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: Bad
Status: Bad
Sectors are not identical.
NTFS at 267349/89/4
ntfs_boot_sector
NTFS at 267349/89/4
mft_lcn 770042 0
Status: Bad
Status: Bad
