Photorec Stuck On A Sector
JimBop1209
#1 Post by JimBop1209 »
Hello, I accidentally formatted a 2TB HDD, and out of impulse used Photorrec to retrieve data back but overwrote only 6GB.
However, I have recently got an external hard drive with the same size as the drive I am recovering from, but I am stuck on a sector. I have run the recovery program twice (testdisk-7.2-WIP), but still gets stuck onto the same sector. Before those attempts, I used a later version (testdisk-7.1), but it gets stuck into a loop, scanning for the same 5 sectors.
Could this be resolved, although having 6GB overwritten?
Thanks,
Jim
Re: Photorec Stuck On A Sector
I have uploaded a new 7.2-WIP version. Can you try it ?
Is a new file recovered each time before PhotoRec scans again this sector range ? If new files are found, lets PhotoRec work.
If you really want to avoid this sector range, stop PhotoRec, edit the photorec.ses file (vim under Linux, notepad++ or wordpad under Windows...), restart PhotoRec and choose to resume the recovery.
The new sector should respect the blocksize (new_sector = old_sector + x * block_size/sector_size).
You can also remove some sector range from the file.
JimBop1209
#3 Post by JimBop1209 »
Thank you for your reply.
I had no choice but I sent my drive to a computer repair shop. I will keep your solution when a mishap happens.
Jim
