Win 7->10 RAW recovery, all seemed okay but after reboot still broken. Topic is solved
mbourgon
#1 Post by mbourgon »
Howdy, all. I upgraded Win 7 to Win 10, and my third hard drive (2tb) now shows up as "RAW".
I've tried to recover files from the drive using a different tool, just in case, but since not everything came back properly I want to try and fix the partition.
I am able to use Diskpart to Analyze the partition and I see files when I hit P.
I change it from * it to Primary or Logical (I've tried both), tell it to write it, then reboot, but on reboot it's still not showing up. I get "E:\ is not accessible. The file or directory is corrupted and unreadable."
Any help appreciated. I've included the logs below from multiple attempts.
MANY thanks in advance!!!
M
Sun Jan 19 11:42:51 2020
TestDisk 7.2-WIP, Data Recovery Utility, December 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=240065183744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=240065183744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239455961088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DL004 HD204UI, S/N:S2H7J9FC303728, FW:1AQ10001
Disk /dev/sdb - 240 GB / 223 GiB - CHS 29186 255 63, sector size=512 - SanDisk SSD PLUS 240GB, S/N:183247803482, FW:UF4500RL
Disk /dev/sda - 2000 GB / 1863 GiB - ST2000DL004 HD204UI
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 243201 45 44 3907024896 [TB2_2012]
NTFS at 0/32/33
filesystem size 3907024896
mftmirr_lcn 2
file_pread(4,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(4,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(4,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(4,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(4,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(4,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(4,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(4,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(4,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(4,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(4,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(4,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(4,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(4,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(4,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(4,6,buffer,3907031042(243201/110/48)) lseek err Invalid argument
file_pread(4,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(4,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(4,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(4,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(4,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(4,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 243201 45 44 3907024896 [TB2_2012]
1 * HPFS - NTFS 0 32 33 243201 45 44 3907024896 [TB2_2012]
write!
Sun Jan 19 11:49:23 2020
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
file_pread(4,16,buffer,6293524(391/192/14)) ReadFile Data error (cyclic redundancy check).
dir_partition inode=5
file_pread(4,16,buffer,6293514(391/192/4)) ReadFile Data error (cyclic redundancy check).
5 dr-xr-xr-x 0 0 0 15-Jan-2020 03:02 .
5 dr-xr-xr-x 0 0 0 15-Jan-2020 03:02 ..
53 dr-xr-xr-x 0 0 0 27-Aug-2017 01:15 $RECYCLE.BIN
154120 dr-xr-xr-x 0 0 0 16-Jan-2020 06:52 .bzvol
177545 dr-xr-xr-x 0 0 0 21-Jul-2013 03:32 0cb23805342a9755fb1d4a9c52
141672 dr-xr-xr-x 0 0 0 4-Jan-2020 23:49 2019-09-26-raspbian-buster-full
635248 dr-xr-xr-x 0 0 0 3-Jan-2019 17:46 2b9462775a9deb839ac482c14daf9502fe4e3b09_blahblahblah
21181 dr-xr-xr-x 0 0 0 12-May-2018 10:02 5f237bc5ee0a34128292c93c39dab846
318808 dr-xr-xr-x 0 0 0 11-May-2016 20:54 Anathema 5.1
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 0 32 32 243201 45 44 3907024897
5 L HPFS - NTFS 0 32 33 243201 45 44 3907024896 [TB2_2012]
write!
write_all_log_i386: CHS: 0/32/32,lba=2047
Sun Jan 19 11:54:17 2020
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 0/32/33
mftmirr_lcn 2
write!
Re: Win 7->10 RAW recovery, all seemed okay but after reboot still broken.
Run "cmd" (right click Run as Administrator) and "chkdsk /f e:".
Does it repair your filesystem ?
mbourgon
#3 Post by mbourgon »
WOOT! That fixed it!
Thanks!!!!!
(and I have to ask in case this ever comes up again - I hope not... so TestDisk fixed it and chkdsk finished it, or did it just take chkdsk?)
Either way, fantastic news, and thanks for the help!
mbourgon wrote: 19 Jan 2020, 22:07 (and I have to ask in case this ever comes up again - I hope not... so TestDisk fixed it and chkdsk finished it, or did it just take chkdsk?)
Chkdsk can only work on file systems that reside in partitions. From the view of the operating system, there were no partitions ("raw"). Testdisk fixed it and enabled the work of chkdsk.
mbourgon
#5 Post by mbourgon »
recuperation wrote: 19 Jan 2020, 22:45
Ah! Okay, thanks. Been too long since I've had to work with chkdsk/diskpart/etc. Thanks for the info! :D
