wiped out extended and logical partitions after trying to recover NTFS partition
slipstream3
#1 Post by slipstream3 »
I seem to be making things worse with testdisk so I am asking for help!
I used gparted in Ubuntu (this distro is located on my 7th/8th partitions) intending on deleting and creating new partitions on my external backup drive. In a moment of total distraction I wiped out the first 2 partitions on my main HDD on my laptop which had Windows 7 and its boot partition.
I downloaded Testdisk and analysed the disk. It seemed to have found the correct NTFS partitions which I marked as primary and bootable primary, but I once again distractedly did not bother to analyse the other partitions which included my Ubuntus and other ext 4 partitions. I believe that they thus remained 'deleted' by default.
To make matters worse, when I tried to write the recovered NTFS partitions, testdisk warned that there was a mismatch with the beginning and end of the partitions and I chose to 'copy to the partition' what had just been recovered.
Now when I reboot I am left with grub rescue mode and when I use a live ubuntu CD I see that all that I have left are the Windows/ NTFS partitions!
I am trying to use Testdisk once again and I am totally confused with how to proceed.
I found all my partitions in the right order, not overlapping, except that the extended partition is missing (which should be the third partition). I need to find it in order to change most of my recovered partitions to Logical without getting an error message. I tried analysing the first few partitions. Doing a deeper search for my first linux partition, Testdisk gave the option of writing it as the 4th (starting and ending as the 4th partition) along with a suggested extended partition that covers the whole HDD, but that is NOT correct!
Will a deeper search left running for a longer time of my first partition (that I created in error) reveal the correct structure with the extended partition? Where should I be looking?
Re: wiped out extended and logical partitions after trying to recover NTFS partition
If some partitions aren't listed after Quick Search, use Deeper Search.
All the partitions you want to recover need to be marked as P(rimary, *(bootable) or L(ogical).
You can use the arrow keys to switch the partition from D(eleted).
Can you post the testdisk.log file content and tell which partitions you want to recover ?
slipstream3
#3 Post by slipstream3 »
Hello again,
I have been called away and had to set the laptop aside all this time! I hope there is a way back for my harddrive!
I have made a couple of log files so far and I am still doing a deeper search on yet another deleted partition.
I would like to recover 6 ext4 partitions but deeper search of almost every partition (marked deleted) doesn't reveal the extended partition that I had originally created. I am pretty sure I had made it the 3rd partition and it covered most of the hard drive except the windows and swap partition. Without it I will not be able to recover my logical 6 partitions!
To recap- from one log file:
     Linux                    0  32 33 10917  14 41  175380480 [Movies and Shows]
     ext4 blocksize=4096 Large_file Sparse_SB, 89 GB / 83 GiB
     Linux                10917  47 11 14375   2 27   55549952 [KxStudio_14]
     ext4 blocksize=4096 Large_file Sparse_SB, 28 GB / 26 GiB
     Linux                14375   2 28 22941  43 14  137615360 [KxStudio_Home]
     ext4 blocksize=4096 Large_file Sparse_SB, 70 GB / 65 GiB
     Linux                22941  75 47 30816  63 31  126511104 [Multimedia]
     ext4 blocksize=4096 Large_file Sparse_SB, 64 GB / 60 GiB
     Linux                30816  96  1 33941 153  4   50206720
     ext4 blocksize=4096 Large_file Sparse_SB, 25 GB / 23 GiB
     Linux                33941 153  5 42390 154  4  135733248
     ext4 blocksize=4096 Large_file Sparse_SB, 69 GB / 64 GiB
     Linux                42390 186 37 60278  97 43  287365120 [MultimediaII]
     ext4 blocksize=4096 Large_file Sparse_SB, 147 GB / 137 GiB
     Linux Swap           60278 130 13 60801  80 15    8398848
     SWAP2 version 1, pagesize=4096, 4300 MB / 4101 MiB
Movies and shows is actually the partition that I had originally created in error after I had deleted the 2 windows partitions (also in error). I then recovered the Windows partitions with testdisk and applied ''copy to disk'' which changed the whole partitions structure, I believe:
Disk /dev/sda - 500 GB / 465 GiB - HGST HTS725050A7E630
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/32/33
NTFS at 191/89/27
Info: size boot_sector 172306425, partition 172306432
 1 * HPFS - NTFS              0  32 33   191  89 26    3072000
 2 P HPFS - NTFS            191  89 27 10916 237  9  172306432
I have to figure out how to attach the log file, it shows invalid file type...but I am not sure how to recover the extended partition!
slipstream3
#4 Post by slipstream3 »
Here is the result of deeper search of first few partitions (deleted)
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 147 GB / 137 GiB
BAD_RS LBA=3467322276 13102435
     FAT12                215830 211 34 279340  27 62 1020276587
This partition ends after the disk limits. (start=3467322276, size=1020276587, end=4487598862, disk end=976773168)
     Linux Swap           60278 130 13 60801  79 62    8398832
     SWAP2 version 1, pagesize=4096, 4300 MB / 4100 MiB
NTFS at 191/89/26
filesystem size           3072000
sectors_per_cluster       8
mft_lcn                   128000
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS at 191/89/27
filesystem size           172306425
mftmirr_lcn               2
The harddisk (500 GB / 465 GiB) seems too small! (< 2297 GB / 2139 GiB)
     Linux                51285  40 20 69172 206 26  287365120 [MultimediaII]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 147 GB / 137 GiB
     Linux                51286  12 55 69173 178 61  287365120 [MultimediaII]
     Linux                51286 175 26 69174  86 32  287365120 [MultimediaII]
Warning: the current number of heads per cylinder is 255 but the correct value may be 128.
     NTFS, blocksize=4096, 1572 MB / 1500 MiB
     HPFS - NTFS            191  89 26   382 146 19    3072000
     NTFS, blocksize=4096, 88 GB / 82 GiB
     HPFS - NTFS            191  89 34 10916 237  9  172306425
     NTFS found using backup sector, blocksize=4096, 88 GB / 82 GiB
     Linux                12505  91  3 15963  46 19   55549952 [KxStudio_14]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 28 GB / 26 GiB
     Linux                12511  56 26 15969  11 42   55549952 [KxStudio_14]
     Linux                12511 186 28 15969 141 44   55549952 [KxStudio_14]
     Linux                12515  44 10 15972 254 26   55549952 [KxStudio_14]
     Linux                18573 226 22 27140  12  8  137615360 [KxStudio_Home]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 70 GB / 65 GiB
     Linux                18575   8 58 27141  49 44  137615360
     Linux                18575 138 60 27141 179 46  137615360
     Linux                32140  70 59 35265 127 62   50206720
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 25 GB / 23 GiB
     Linux                32141 238 34 35267  40 37   50206720
     Linux                32145 161 17 35270 218 20   50206720
     Linux                32147 171 25 35272 228 28   50206720
     Linux                32148 176 29 35273 233 32   50206720
     Linux                32152 229 14 35278  31 17   50206720
     Linux                32154 141 52 35279 198 55   50206720
     Linux                38136 199 16 46585 200 15  135733248
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 69 GB / 64 GiB
     Linux                38139 181 59 46588 182 58  135733248
     Linux                38142   2  5 46591   3  4  135733248
     Linux                38143 169 43 46592 170 42  135733248
     Linux                38150  10  5 46599  11  4  135733248
     Linux                38151  80 10 46600  81  9  135733248
   * Linux Swap           60278 130 13 60801  80 15    8398848
I just tried out changing back my partitions to logical without getting an error again, still have not been able to recover all of them, not sure what im doing wrong. At least I found out that the extended partition option shows up after I press continue and its looking more promising...
#5 Post by recuperation »
You have to use the "p"-key to look inside to verify that Testdisk can read its contents.
Parts of your logfile are missing and until know I can only guess that your recovery is about a drive that is 500GB big.
slipstream3
#6 Post by slipstream3 »
thanks for your reply!
I have done so (checked for the files inside the partition) in an previous deeper search but I had not done a complete check of all the required partitions. So that will be my next step later.
Does it matter which deleted partition(s), I use for the deeper search? That part still confuses me, and I had tried pretty much all of them and the results seem the same...
So far I have managed to recuperate most of the partitions but not all of them ( would show an error if changing from D to L).
Here are 2 logs; I had tried more partitions for the deeper search in the original log, but did not attempt to change their status. The other log shows my first attempt to recuperate the logical and extended partition(s).
https://drive.google.com/file/d/1LlzEIq ... sp=sharing
https://drive.google.com/file/d/1edLs7v ... sp=sharing
#7 Post by recuperation »
slipstream3 wrote: 27 Feb 2020, 23:15 Does it matter which deleted partition(s), I use for the deeper search? That part still confuses me, and I had tried pretty much all of them and the results seem the same...
No, deep search takes place on drive level and would maybe find partitions located at uncommon locations.
As far as I know, you do not have to search for an extended partition. An extended partition is an organisational component of Intel/MBR style partitions which is taking care of by Testdisk.
Your job is to check the partitions found for valid content.
slipstream3
#8 Post by slipstream3 »
Hello again!
I went through the deeper search again and went through all the results and found the valid partitions (with all my missing files), but I hit a wall again. I could not change the partitions from deleted to either L or P past 4 of them even excluding the NTFS partition. It kept warning of structure error and at the next page it failed with the same error. Is it normal for not all the partitions to begin exactly at the next sector where the last one ended? Somehow I may have corrupted the disk partition structure when I deleted the windows partitions in gparted?
At this point I am ready to scrap Windows all together, (which I have little use for) and just reinstall ubuntu in its stead. But first I would recover the 2 home and 2 data partitions with test disk since it wont go past 4 partitions (aside from the swap partition).
Here is a part of the log highlighting what I wanted to recover and was valid partitions, excluding the NTFS partition which didn't make a difference wether kept deleted or changed to primary:
I can resend the full log again but it seems to not have included the failed attempt to change the partitions state, if that might help at this point...
#9 Post by recuperation »
The missing free space between KXStudio_14 and KXStudio_Home suggests you should use GPT instead of Intel/MBR when asked for the partition table type.
slipstream3
#10 Post by slipstream3 »
...suggests you should use GPT instead of Intel/MBR when asked for the partition table type.
I am pretty sure that the drive was originally partitioned with Intel/MBR. In the meantime I went ahead with Intel table type and recuperated my partitions with data. Is this why I am getting these errors when trying deeper search with GPT, or is GPT incorrect regardless? Keeping in mind that I only went as far as 11% as I had to stop for now.
....Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
Trying alternate GPT
     MS Data                     2046  175382525  175380480 [Movies and Shows]
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 89 GB / 83 GiB
     MS Data                     2048    3074047    3072000
     MS Data                     2048  175382527  175380480 [Movies and Shows]
     MS Data                   723187     729360       6174
     MS Data                   729360     735533       6174 [Boot]
     MS Data                  1589883    1596056       6174
     MS Data                  1596056    1602229       6174 [Boot]
     MS Data                  1602240    1605119       2880 [EFISECTOR]
     MS Data                  1605120    1607999       2880 [EFISECTOR]
     MS Data                  1632276    1653014      20739 [NO NAME]
     MS Data                  2073763    2079936       6174
     MS Data                  2079936    2086109       6174 [Boot]
     MS Data                  3074047    6146046    3072000
     MS Data                  3074048  175380472  172306425
     Mac HFS                  4695524   13084133    8388610 [����D#]
     HFS blocksize=16777216, 4294 MB / 4096 MiB
     MS Data                  6352187    6358360       6174
     MS Data                  6358360    6364533       6174 [Boot]
     MS Data                  9027760   90947759   81920000
     NTFS, blocksize=4096, 41 GB / 39 GiB
     MS Data                 17707651   17728389      20739 [NO NAME]
     MS Data                 31918024   31920903       2880 [EFISECTOR]
     MS Data                 34120776   34123655       2880 [EFISECTOR]
     MS Data                 37328459   37334632       6174
     MS Data                 37334632   37340805       6174 [Boot]
     MS Data                 37334667   37340840       6174
     MS Data                 37340840   37347013       6174 [Boot]
     Mac HFS                 45026908   95358813   50331906
     HFS blocksize=33554432, 25 GB / 24 GiB
     MS Data                 83301992   83304871       2880 [EFISECTOR]
     MS Data                 83326127   83332300       6174
     MS Data                 83332300   83338473       6174 [Boot]
     MS Data                 83338480   83341359       2880 [EFISECTOR]
     MS Data                 83341360   83344239       2880 [EFISECTOR]
     MS Data                 84138396   84159134      20739 [NO NAME]
     FAT12, blocksize=4096, 10 MB / 10 MiB...
