Seagate Freeagent 2Tb.. Filesystem corrupted and missing mbr
tarunjeet
#1 Post by tarunjeet »
Hello every1.. I have Seagate Freeagent Desk HDD of 2 tb capacity. iT runs with power supply
P/N - 0ZC2AR-501
S/N - 2GETA22V
everything was fine one night.. in morning i attached it to laptop windows said format to use it...
I think its filesystem got corrupted .. i opened it with Winhex .. in a side box it says mbr is missing
I tried to recover files using getback for ntfs... It is only showing me 3 gb of data
how to recover now or to fix it.. i want my data back :-\
it was 1.5 tb full
theni tried stellar ... it showed nothing.. then i tried stellar raw recovery in that it takes long time.. it wil take 2 days i guess .. but i raw only some particular file types ca be searched ... but strange is 1-2 files i got from stellar which get back for ntfs does'nt shows and some files coruupted too
Any suggestions guys? any information u need extra like all the hex codes from winhex or something?
I don't have money to go to professionals so any advice is appracilable..
I'm not sure where the problem is
Re: Seagate Freeagent 2Tb.. Filesystem corrupted and missing
I'd need some infos from TestDisk "Analyse".
It's your current partition table.
tarunjeet
#3 Post by tarunjeet »
Fiona wrote:I'd need some infos from TestDisk "Analyse".
thanx for the reply fiona
here are the test disk analyze snapshots
after 4th image i did'nt knew what to do
wargo
#4 Post by wargo »
Press enter and run deeper search
#5 Post by Fiona »
Looks like that you have a partition in your partition table.
That's why you can diagnose your boot sector.
Like in this case;
But only if you closed TestDisk.
Deeper Search would be the normal way.
But consumes time.
tarunjeet
#6 Post by tarunjeet »
Fiona wrote:Looks like that you have a partition in your partition table.
Like in this case;
But consumes time.
yea quick search tool 8 hours .. deep wil take 24 i guess
well i'm not a professional ...
what do u mean by "there's a partition in your partition table that's why you can diagnose your boot sector"
2ndly
what should i do now
deep search?
or this
"Start TestDisk.
Confirm through until you see the menu Analyse.
Confirm at Boot with enter also.
Please let us know, do you see your data or an error message.
To get back to the previous screen, easily press q for Quit."
thnx for helping man.. i really appreciate your effort n time u're giving me
#7 Post by Fiona »
or this "Start TestDisk.
Yes, a boot sector diagnose should be faster.
Thats why I suggested it first.
If a boot sector diagnose doesn't find any data, you should run deeper search, like wargo suggested.
tarunjeet
#8 Post by tarunjeet »
here is what i did ... but hard drive has no data now :( 1.8 tb free of 1.8 tb
#9 Post by Fiona »
Probably a wrong partition.
No data means empty partition?
In case you should run Deeper Search.
Even datarecovery software scanning a large drive takes time.
Looks like it's not avoidable.
tarunjeet
#10 Post by tarunjeet »
Fiona wrote:Probably a wrong partition.
but the interesting point is first i could see 3 gb of my data in getback for ntfs and more way much more data in stellar raw recovery which i can't c now
what could b the cause ?
yea one more thing u said it will take couple of minuts to rebuild boot sector ...it took hardly 5 seconds in my case
after i entered rebuild boot sector i saw 4 options
dump,list,quit ,,write
i chose write
any idea what could be wrong?
i'll try deeper
search now
