memory leak on ntfs volume
mesajflaviu
#1 Post by mesajflaviu »
I ran the code in the debugger, tested on NTFS device, by calling ntfs_undelete_part function. In the step by step debugging, I arrived on volume.c file, at line:
br = ntfs_pread(dev, 0, sizeof(NTFS_BOOT_SECTOR), bs);
if I call this function, I got the following memory leak:
Dumping objects ->
{26571} normal block at 0x034B8020, 65536 bytes long.
 Data: < R NTFS         > EB 52 90 4E 54 46 53 20 20 20 20 00 02 08 00 00
Object dump complete.
I don't know from where come this memory leak, but the garbage value is a little bit interesting: EB 52 90 4E 54 46 53 20 20 20 20 00 02 08 00 00 ... what can I know this ML source for sure ?
Update:
The code is run like this:
1. volume.c / br = ntfs_pread(dev, 0, sizeof(NTFS_BOOT_SECTOR), bs);
2. device.c / br = dops->pread(dev, (char*)b + total, count, pos + total);
3. ntfs_io.c /
static s64 ntfs_device_testdisk_io_pread(struct ntfs_device* dev, void *buf, s64 count, s64 offset)
	my_data_t* my_data = (my_data_t*)dev->d_private;
	return my_data->disk_car->pread(my_data->disk_car, buf, (int)count, my_data->partition->part_offset + offset);
4. hdaccess.c /
static int file_pread(disk_t* disk_car, void *buf, const unsigned int count, const uint64_t offset)
	return align_pread(&file_pread_aux, disk_car, buf, count, offset);
5. align.c /
static int align_pread(int(*fnct_pread)(disk_t *disk_car, void *buf, const unsigned int count, const uint64_t offset),
	disk_t* disk_car, void*buf, const unsigned int count, const uint64_t offset)
	const uint64_t offset_new = offset + disk_car->offset;
	const unsigned int count_new = ((offset_new%disk_car->sector_size) + count + disk_car->sector_size - 1) / disk_car->sector_size*disk_car->sector_size;
	if (count != count_new ||
		((disk_car->access_mode & TESTDISK_O_DIRECT) != 0 &&
		(((size_t)(buf) & (disk_car->sector_size - 1)) != 0) &&
			(buf != disk_car->rbuffer || disk_car->rbuffer_size < count_new))
		if (disk_car->rbuffer == NULL)
			disk_car->rbuffer_size = 128 * 512;
		while (disk_car->rbuffer_size < count_new)
			free(disk_car->rbuffer);
			disk_car->rbuffer = NULL;
			disk_car->rbuffer_size *= 2;
			disk_car->rbuffer = MALLOC(disk_car->rbuffer_size);
		TRACE(" bad case: %p|%p %d|%d\n", disk_car, disk_car->rbuffer, count_new, offset_new / disk_car->sector_size*disk_car->sector_size);
		int res = fnct_pread(disk_car, disk_car->rbuffer, count_new, offset_new / disk_car->sector_size*disk_car->sector_size);
		memcpy(buf, (char*)disk_car->rbuffer + (offset_new%disk_car->sector_size), count);
		return (res < (signed)count ? res : (signed)count);
	TRACE("good case: %p|%p %d|%d\n", disk_car, buf, count, offset_new);
	return fnct_pread(disk_car, buf, count, offset_new);
Re: memory leak on ntfs volume
disk_car->rbuffer is allocated by align_pread()
generic_clean() in hdaccess.c calls "free(disk_car->rbuffer);"
mesajflaviu
#3 Post by mesajflaviu »
Thank you Grenier !!! To see how important is your words, I can say: I found/solved memory leaks. At least, I guess so. Might be a little bug, I am not sure, you can check yourself. Here was the problem:
In alignio.h (sorry, not alignio.c), in function align_pread
		int res = fnct_pread(disk_car, disk_car->rbuffer, count_new, offset_new / disk_car->sector_size * disk_car->sector_size);
		memcpy(buf, (char*)disk_car->rbuffer + (offset_new % disk_car->sector_size), count);
		free(disk_car->rbuffer);   // this is the my code !!! I hope to be ok
still, the code doesn't found any deleted files from USB NTFS drives. this could be another issue. Again, kindly thank you Grenier !!!!
