Accidentally did a diskpart /clean on primary boot partition
apdunshiz
#1 Post by apdunshiz »
Hey guys,
So this morning I was working on a user's laptop and was trying to convert the primary hard drive from mbr partition to guid so we could enable secure boot. I was a bit intoxicated still from last night of drinking and was reading a guide online and accidentally read the wrong version that had me add in the step of cleaning the drive with the diskpart /clean command. I did this from command prompt in recovery mode on the primary boot partition.
I read online that data is not lost and this is likely a fixable problem. I did some research and it was determined that TestDisk could help with this so I made a bootable USB with testdisk and did a search, and advanced search, and it only found the recovery partition and a broken FAT partition. Tried to fix the FAT partition but it wouldn't proceed. So I looked in "unknown" partitions and saw one, changed it to NTFS, and am now doing a rebuildbs. Please tell me this will work? Is there something else I am missing?
Thanks!
Re: Accidentally did a diskpart /clean on primary boot partition
Try TestDisk, Analyse, Quick Search and Deeper Search as Quick Search didn't find one of your missing partition.
