[HELP] 'Warning: Bad ending head' message??
BlockABoots
#1 Post by BlockABoots »
So i stupidly changed a 3TB drive from MBR to GPT and lost all the data!!
The drive as it stands now is in an 'unallocated' state, i haven't set the drive up again in fear of destroying more data.
I have run Testdisk_win.exe, and then....
  • selected Create a new log file
  • selected the correct drive to scan
  • selected Intel (as thats whats been detected)
  • and then Analyse.
But on the next screen i get a message....
am i getting this message as the drive is in an 'unallocated' state and is it ok to carry on the search?
Re: [HELP] 'Warning: Bad ending head' message??
Yes, you need to choose QUick Search and if your partition still isn't found, try Deeper Search.
