but im not sure what steps i need to do next, i did press 'P' to list files but when doing so i get the following message, 'Can't open filesystem. Filesystem seems damaged' but it appears to have saved loads of folders from the deleted partition to my J drive (but with randomly generated file names)
Am i supposed to change the drive partition characteristics to Primary and then write and restart the PC?
heres the log, it might not be the full log as i put the PC into sleep half way from testdisk's search???...
Mon Feb 10 19:40:15 2020
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=511432458240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000068874240
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=4000750501888
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00DC0B0, S/N:WD-WCC1T0292979, FW:80.00A80
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00BN5A0, S/N:WD-WCC3F6FLFFY9, FW:01.01A01
Disk /dev/sdc - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - Crucial_CT512MX100SSD1, S/N:14350D143D75, FW:MU01
Disk /dev/sdd - 4000 GB / 3725 GiB - CHS 486397 255 63, sector size=512 - WD My Passport 25E2, S/N:WX31DA70R9YX, FW:4004
Disk /dev/sda - 3000 GB / 2794 GiB - WDC WD30EZRX-00DC0B0
Analyse Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63
NTFS at 12/223/20
filesystem size 4294758400
mftmirr_lcn 2
HPFS - NTFS 12 223 20 267349 56 35 4294758400
NTFS, blocksize=4096, 2198 GB / 2047 GiB
file_pread(4,2,buffer,5860534271(364801/98/33)) lseek err Invalid argument
file_pread(4,1,buffer,5860534271(364801/98/33)) lseek err Invalid argument
file_pread(4,2,buffer,5860534272(364801/98/34)) lseek err Invalid argument
file_pread(4,14,buffer,5860534274(364801/98/36)) lseek err Invalid argument
file_pread(4,3,buffer,5860534288(364801/98/50)) lseek err Invalid argument
file_pread(4,3,buffer,5860534335(364801/99/34)) lseek err Invalid argument
file_pread(4,8,buffer,5860534351(364801/99/50)) lseek err Invalid argument
file_pread(4,11,buffer,5860534398(364801/100/34)) lseek err Invalid argument
file_pread(4,2,buffer,5860536320(364801/131/3)) lseek err Invalid argument
* HPFS - NTFS 12 223 20 267349 56 35 4294758400
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
1 * HPFS - NTFS 12 223 20 267349 56 35 4294758400
