FreeBSD filesystem/partition recovery
mnavarre
#1 Post by mnavarre »
I lost a drive on my PC-BSD box after a reboot. I hadn't done anything to the drive other than normal use, but after rebooting I was unable to mount the file systems.
The disk has two DOS primary partitions on it, each containing a single UFS2 file system. I think the physical drive may be failing (but it's still spinning and accessable, testdisks' Deeper Search option finds both partitions but freezes and panics the computer arond 80%), so I made an image file on another drive using dd to work with.
Here's a testdisk log file from the image after using Quick Search and writing the Partition table:
Tue Aug 7 20:25:34 2012
Command line: TestDisk -log ./ada1_backup
TestDisk 6.12, Data Recovery Utility, May 2011
OS: FreeBSD, kernel 9.0-RELEASE-p3 (FreeBSD 9.0-RELEASE-p3 #0: Tue Jun 12 02:52:29 UTC 2012 root@a
Compiler: GCC 4.2
Compilation date: 2012-08-04T02:08:10
ext2fs lib: none, ntfs lib: none, reiserfs lib: none, ewf lib: none
Disk ./ada1_backup - 160 GB / 149 GiB - CHS 19458 255 63, sector size=512
Analyse Disk ./ada1_backup - 160 GB / 149 GiB - CHS 19458 255 63
1 P FreeBSD 0 1 1 10442 254 63 167766732
2 P FreeBSD 10443 0 1 19456 254 63 144809910
Ask the user for vista mode
search_vista_part: 1
FreeBSD 0 1 1 10442 254 62 167766731
FreeBSD 10443 0 1 19456 254 62 144809909
1 * FreeBSD 0 1 1 10442 254 63 167766732
I'd already written the Partition table to the file before this run.
Here's what testdisk -log /dev/ada1 shows:
Tue Aug 7 20:50:42 2012
Command line: TestDisk -log /dev/ada1
Compiler: GCC 4.2
Disk /dev/ada1 - 160 GB / 149 GiB - CHS 310098 16 63, sector size=512
Analyse Disk /dev/ada1 - 160 GB / 149 GiB - CHS 310098 16 63
1 * FreeBSD 0 1 1 166435 4 63 167766732
2 * FreeBSD 166435 5 1 310095 14 63 144809910
Warning: Bad starting head (CHS and LBA don't match)
Computes LBA from CHS for Disk /dev/ada1 - 160 GB / 149 GiB - CHS 310099 16 63
FreeBSD 0 1 1 166435 4 62 167766731
FreeBSD 166435 5 1 310095 14 62 144809909
Warning: the current number of heads per cylinder is 16 but the correct value may be 255.
I've tried using FreeBSDs loopback device to mount the filesystems, but the only device entry I get is /dev/md0, I should be seeing md0, md0s1 and md0s2.
The manual for the drive says this is the disk geometry:
Guaranteed Sectors: 312,581,808
bytes per sector: 512
Sectors per track: 63
Heads: 16
Sectors: 16383
Any ideas? Because I think I'm out of my depth here
Thanks,
Matt
