Disk shows as unallocated after a forced shutdown
disk0
#1 Post by disk0 »
After hibernating my Windows 10 laptop the computer never actually shutdown. The screen was black but the fans kept spinning. Usually hibernation does not take all that long and after about 10 min I forced a shutdown by holding down the power button. The next day the computer booted straight to BIOS (or I guess UEFI) and said that there were not bootable devices. Since the laptop can house two SSD drives I installed another one and installed Windows 10 on it. Disk manager says that the original disk is unallocated and that there are no partitions on it. When I use TestDisk it seems to find all the partitions and I can successfully browse and backup files. I'm not sure how to rebuild the partition table and make the disk bootable again. The original failing disk is a 512GB SanDisk and the new one is a 1TB Samsung.
After studying the TestDisk documentation I tried section "7.4 Repairing FAT32, exFAT and NTFS boot sector using TestDisk". So I selected "Advanced" > select the OS disk > "Boot". I don't see an option for "Backup BS". If I select "Rebuild BS", it says that "Extrapolated boot sector and current boot sector are identical".
When I select "Analyse", I see this:
Disk /dev/sdb - 512 GB / 476 GiB - CHS 62260 255 63
Trying alternate GPT
 1 P EFI System                  2048     534527     532480 [EFI system partition]
 2 P MS Reserved               534528     567295      32768 [Microsoft reserved partition]
 3 P MS Data                   567296  999192575  998625280 [Basic data partition] [OS]
 4 P Windows Recovery Env   999192576 1000214527    1021952 [Basic data partition]
After "Quick Search" I see this:
>P EFI System                  2048     534527     532480 [EFI System Partition] [SYSTEM]
 D MS Data                   567296  999192575  998625280 [OS]
 D MS Data                998170625  999192576    1021952
 D MS Data                999192576 1000214527    1021952 [RECOVERY]
The search does not find the "MS Reserved" partition which showed up twice it the earlier list. Instead it sees an "MS Data" partition between 998170625 and 999192576 which probably shouldn't be there. I don't get an option to mark any of the partitions as bootable. I can only mark them as P or D. I'm afraid to move forward from here.
What should I do? Here is the log. I had to leave out a lot of those "lseek err Invalid argument" lines because phpBB complained that the message was too long.
Sat Feb 29 13:26:37 2020
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999527809024
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 860 EVO 1TB, S/N:S4X6NF0N120481E, FW:RVT04B6Q
Disk /dev/sdb - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - SanDisk SD8SN8U512G1002, S/N:164201432324, FW:X4131002
Disk /dev/sdb - 512 GB / 476 GiB - SanDisk SD8SN8U512G1002
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1000215215
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_end=1000215182
hdr_lba_table=1000215183
hdr_entries=128
hdr_entsz=128
     NTFS, blocksize=4096, 511 GB / 476 GiB
ntfs_boot_sector
NTFS at 35/79/45
NTFS at 35/79/45
filesystem size           998625280
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         2
ntfs_find_mft: mft_record_size     1024 bytes
ntfs_find_mft: index_block_size    4096
mftmirr_lcn               2
ntfs_boot_sector
NTFS at 35/79/45
NTFS at 35/79/45
mftmirr_lcn               2
Status: OK
Status: OK
Analyse Disk /dev/sdb - 512 GB / 476 GiB - CHS 62260 255 63
hdr_size=92
hdr_lba_start=34
hdr_entries=128
hdr_entsz=128
FAT32 at 0/32/33
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
no_of_cluster : 65536 (2 - 65537)
fat_length 513 calculated 513
FAT32 at 0/32/33
FAT: cluster=2(0x2), pos=10240
     FAT32, blocksize=4096, 272 MB / 260 MiB
NTFS at 35/79/45
mftmirr_lcn               2
NTFS part_offset=290455552, part_size=511296143360, sector_size=512
NTFS at 35/79/45
mftmirr_lcn               2
NTFS at 62196/219/40
filesystem size           1021952
mft_lcn                   42581
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 523 MB / 499 MiB
mft_lcn                   42581
mftmirr_lcn               2
     NTFS, blocksize=4096, 523 MB / 499 MiB
file_pread(5,2,buffer,1000216576(62260/153/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000216576(62260/153/38)) lseek err Invalid argument
file_pread(5,2,buffer,1000216577(62260/153/39)) lseek err Invalid argument
file_pread(5,1,buffer,1000216579(62260/153/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000216580(62260/153/42)) lseek err Invalid argument
file_pread(5,1,buffer,1000216581(62260/153/43)) lseek err Invalid argument
file_pread(5,1,buffer,1000216582(62260/153/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000216583(62260/153/45)) lseek err Invalid argument
file_pread(5,1,buffer,1000216584(62260/153/46)) lseek err Invalid argument
file_pread(5,1,buffer,1000216585(62260/153/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000216586(62260/153/48)) lseek err Invalid argument
file_pread(5,1,buffer,1000216587(62260/153/49)) lseek err Invalid argument
file_pread(5,1,buffer,1000216588(62260/153/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000216589(62260/153/51)) lseek err Invalid argument
file_pread(5,1,buffer,1000216590(62260/153/52)) lseek err Invalid argument
file_pread(5,1,buffer,1000216591(62260/153/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000216592(62260/153/54)) lseek err Invalid argument
file_pread(5,1,buffer,1000216593(62260/153/55)) lseek err Invalid argument
file_pread(5,1,buffer,1000216594(62260/153/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000216595(62260/153/57)) lseek err Invalid argument
file_pread(5,1,buffer,1000216596(62260/153/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000216597(62260/153/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000216598(62260/153/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000216599(62260/153/61)) lseek err Invalid argument
file_pread(5,1,buffer,1000216600(62260/153/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000216601(62260/153/63)) lseek err Invalid argument
file_pread(5,1,buffer,1000216602(62260/154/1)) lseek err Invalid argument
... SNIP ...
file_pread(5,1,buffer,1000217035(62260/160/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000217036(62260/160/57)) lseek err Invalid argument
file_pread(5,1,buffer,1000217037(62260/160/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000217038(62260/160/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000217039(62260/160/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000217040(62260/160/61)) lseek err Invalid argument
file_pread(5,1,buffer,1000217041(62260/160/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000217042(62260/160/63)) lseek err Invalid argument
file_pread(5,1,buffer,1000217043(62260/161/1)) lseek err Invalid argument
file_pread(5,1,buffer,1000217044(62260/161/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000217045(62260/161/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000217046(62260/161/4)) lseek err Invalid argument
file_pread(5,1,buffer,1000217047(62260/161/5)) lseek err Invalid argument
file_pread(5,1,buffer,1000217048(62260/161/6)) lseek err Invalid argument
file_pread(5,1,buffer,1000217049(62260/161/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000217050(62260/161/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000217051(62260/161/9)) lseek err Invalid argument
file_pread(5,1,buffer,1000217052(62260/161/10)) lseek err Invalid argument
file_pread(5,1,buffer,1000217053(62260/161/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000217054(62260/161/12)) lseek err Invalid argument
file_pread(5,1,buffer,1000217055(62260/161/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000217056(62260/161/14)) lseek err Invalid argument
file_pread(5,1,buffer,1000217057(62260/161/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000217058(62260/161/16)) lseek err Invalid argument
file_pread(5,1,buffer,1000217059(62260/161/17)) lseek err Invalid argument
file_pread(5,1,buffer,1000217060(62260/161/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000217061(62260/161/19)) lseek err Invalid argument
file_pread(5,1,buffer,1000217062(62260/161/20)) lseek err Invalid argument
file_pread(5,1,buffer,1000217063(62260/161/21)) lseek err Invalid argument
file_pread(5,1,buffer,1000217064(62260/161/22)) lseek err Invalid argument
file_pread(5,1,buffer,1000217065(62260/161/23)) lseek err Invalid argument
file_pread(5,1,buffer,1000217066(62260/161/24)) lseek err Invalid argument
file_pread(5,1,buffer,1000217067(62260/161/25)) lseek err Invalid argument
file_pread(5,1,buffer,1000217068(62260/161/26)) lseek err Invalid argument
file_pread(5,1,buffer,1000217069(62260/161/27)) lseek err Invalid argument
file_pread(5,1,buffer,1000217070(62260/161/28)) lseek err Invalid argument
file_pread(5,1,buffer,1000217071(62260/161/29)) lseek err Invalid argument
file_pread(5,1,buffer,1000217072(62260/161/30)) lseek err Invalid argument
file_pread(5,1,buffer,1000217073(62260/161/31)) lseek err Invalid argument
file_pread(5,1,buffer,1000217074(62260/161/32)) lseek err Invalid argument
file_pread(5,1,buffer,1000217075(62260/161/33)) lseek err Invalid argument
file_pread(5,1,buffer,1000217076(62260/161/34)) lseek err Invalid argument
file_pread(5,1,buffer,1000217077(62260/161/35)) lseek err Invalid argument
file_pread(5,1,buffer,1000217078(62260/161/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000217079(62260/161/37)) lseek err Invalid argument
file_pread(5,1,buffer,1000217080(62260/161/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000217081(62260/161/39)) lseek err Invalid argument
file_pread(5,1,buffer,1000217082(62260/161/40)) lseek err Invalid argument
file_pread(5,1,buffer,1000217083(62260/161/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000217084(62260/161/42)) lseek err Invalid argument
file_pread(5,1,buffer,1000217085(62260/161/43)) lseek err Invalid argument
file_pread(5,1,buffer,1000217086(62260/161/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000217087(62260/161/45)) lseek err Invalid argument
file_pread(5,1,buffer,1000217088(62260/161/46)) lseek err Invalid argument
file_pread(5,1,buffer,1000217089(62260/161/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000217090(62260/161/48)) lseek err Invalid argument
file_pread(5,1,buffer,1000217091(62260/161/49)) lseek err Invalid argument
file_pread(5,1,buffer,1000217092(62260/161/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000217093(62260/161/51)) lseek err Invalid argument
file_pread(5,1,buffer,1000217094(62260/161/52)) lseek err Invalid argument
file_pread(5,1,buffer,1000217095(62260/161/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000217096(62260/161/54)) lseek err Invalid argument
file_pread(5,1,buffer,1000217097(62260/161/55)) lseek err Invalid argument
file_pread(5,1,buffer,1000217098(62260/161/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000217099(62260/161/57)) lseek err Invalid argument
file_pread(5,1,buffer,1000217100(62260/161/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000217101(62260/161/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000217102(62260/161/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000217103(62260/161/61)) lseek err Invalid argument
file_pread(5,1,buffer,1000217104(62260/161/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000217105(62260/161/63)) lseek err Invalid argument
file_pread(5,1,buffer,1000217106(62260/162/1)) lseek err Invalid argument
file_pread(5,1,buffer,1000217107(62260/162/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000217108(62260/162/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000217109(62260/162/4)) lseek err Invalid argument
file_pread(5,1,buffer,1000217110(62260/162/5)) lseek err Invalid argument
file_pread(5,1,buffer,1000217111(62260/162/6)) lseek err Invalid argument
file_pread(5,1,buffer,1000217112(62260/162/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000217113(62260/162/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000217114(62260/162/9)) lseek err Invalid argument
file_pread(5,1,buffer,1000217115(62260/162/10)) lseek err Invalid argument
file_pread(5,1,buffer,1000217116(62260/162/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000217117(62260/162/12)) lseek err Invalid argument
file_pread(5,1,buffer,1000217118(62260/162/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000217119(62260/162/14)) lseek err Invalid argument
file_pread(5,1,buffer,1000217120(62260/162/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000217121(62260/162/16)) lseek err Invalid argument
file_pread(5,1,buffer,1000217122(62260/162/17)) lseek err Invalid argument
file_pread(5,1,buffer,1000217123(62260/162/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000217124(62260/162/19)) lseek err Invalid argument
file_pread(5,1,buffer,1000217125(62260/162/20)) lseek err Invalid argument
file_pread(5,1,buffer,1000217126(62260/162/21)) lseek err Invalid argument
file_pread(5,1,buffer,1000217127(62260/162/22)) lseek err Invalid argument
file_pread(5,1,buffer,1000217128(62260/162/23)) lseek err Invalid argument
file_pread(5,1,buffer,1000215216(62260/132/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1000217129(62260/162/24)) lseek err Invalid argument
file_pread(5,1,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000217130(62260/162/25)) lseek err Invalid argument
file_pread(5,1,buffer,1000215218(62260/132/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000217131(62260/162/26)) lseek err Invalid argument
file_pread(5,1,buffer,1000215219(62260/132/4)) lseek err Invalid argument
file_pread(5,1,buffer,1000217132(62260/162/27)) lseek err Invalid argument
file_pread(5,11,buffer,1000215210(62260/131/58)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1000217133(62260/162/28)) lseek err Invalid argument
file_pread(5,5,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000217134(62260/162/29)) lseek err Invalid argument
file_pread(5,1,buffer,1000215222(62260/132/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000217135(62260/162/30)) lseek err Invalid argument
file_pread(5,1,buffer,1000215223(62260/132/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000217136(62260/162/31)) lseek err Invalid argument
file_pread(5,1,buffer,1000215224(62260/132/9)) lseek err Invalid argument
file_pread(5,1,buffer,1000217137(62260/162/32)) lseek err Invalid argument
file_pread(5,1,buffer,1000215225(62260/132/10)) lseek err Invalid argument
file_pread(5,1,buffer,1000217138(62260/162/33)) lseek err Invalid argument
file_pread(5,11,buffer,1000215216(62260/132/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1000217139(62260/162/34)) lseek err Invalid argument
file_pread(5,1,buffer,1000215227(62260/132/12)) lseek err Invalid argument
file_pread(5,1,buffer,1000217140(62260/162/35)) lseek err Invalid argument
file_pread(5,1,buffer,1000215228(62260/132/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000217141(62260/162/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000215229(62260/132/14)) lseek err Invalid argument
file_pread(5,1,buffer,1000217142(62260/162/37)) lseek err Invalid argument
file_pread(5,1,buffer,1000215230(62260/132/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000217143(62260/162/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000215231(62260/132/16)) lseek err Invalid argument
file_pread(5,1,buffer,1000217144(62260/162/39)) lseek err Invalid argument
file_pread(5,11,buffer,1000215222(62260/132/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000217145(62260/162/40)) lseek err Invalid argument
file_pread(5,1,buffer,1000215233(62260/132/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000217146(62260/162/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000215234(62260/132/19)) lseek err Invalid argument
file_pread(5,1,buffer,1000217147(62260/162/42)) lseek err Invalid argument
file_pread(5,1,buffer,1000215235(62260/132/20)) lseek err Invalid argument
file_pread(5,1,buffer,1000217148(62260/162/43)) lseek err Invalid argument
file_pread(5,1,buffer,1000215236(62260/132/21)) lseek err Invalid argument
file_pread(5,1,buffer,1000217149(62260/162/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000215237(62260/132/22)) lseek err Invalid argument
file_pread(5,1,buffer,1000217150(62260/162/45)) lseek err Invalid argument
file_pread(5,11,buffer,1000215228(62260/132/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000217151(62260/162/46)) lseek err Invalid argument
file_pread(5,1,buffer,1000215239(62260/132/24)) lseek err Invalid argument
file_pread(5,1,buffer,1000217152(62260/162/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000215240(62260/132/25)) lseek err Invalid argument
file_pread(5,1,buffer,1000217153(62260/162/48)) lseek err Invalid argument
file_pread(5,1,buffer,1000215241(62260/132/26)) lseek err Invalid argument
file_pread(5,1,buffer,1000217154(62260/162/49)) lseek err Invalid argument
file_pread(5,1,buffer,1000215242(62260/132/27)) lseek err Invalid argument
file_pread(5,1,buffer,1000217155(62260/162/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000215243(62260/132/28)) lseek err Invalid argument
file_pread(5,1,buffer,1000217156(62260/162/51)) lseek err Invalid argument
file_pread(5,11,buffer,1000215234(62260/132/19)) lseek err Invalid argument
file_pread(5,1,buffer,1000217157(62260/162/52)) lseek err Invalid argument
file_pread(5,11,buffer,1000215235(62260/132/20)) lseek err Invalid argument
file_pread(5,1,buffer,1000217158(62260/162/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000215246(62260/132/31)) lseek err Invalid argument
file_pread(5,1,buffer,1000217159(62260/162/54)) lseek err Invalid argument
file_pread(5,1,buffer,1000215247(62260/132/32)) lseek err Invalid argument
file_pread(5,1,buffer,1000217160(62260/162/55)) lseek err Invalid argument
file_pread(5,1,buffer,1000215248(62260/132/33)) lseek err Invalid argument
file_pread(5,1,buffer,1000217161(62260/162/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000215249(62260/132/34)) lseek err Invalid argument
file_pread(5,1,buffer,1000217162(62260/162/57)) lseek err Invalid argument
file_pread(5,1,buffer,1000215250(62260/132/35)) lseek err Invalid argument
file_pread(5,1,buffer,1000217163(62260/162/58)) lseek err Invalid argument
file_pread(5,11,buffer,1000215241(62260/132/26)) lseek err Invalid argument
file_pread(5,1,buffer,1000217164(62260/162/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000215252(62260/132/37)) lseek err Invalid argument
file_pread(5,1,buffer,1000217165(62260/162/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000215253(62260/132/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000217166(62260/162/61)) lseek err Invalid argument
file_pread(5,1,buffer,1000215254(62260/132/39)) lseek err Invalid argument
file_pread(5,1,buffer,1000217167(62260/162/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000215255(62260/132/40)) lseek err Invalid argument
file_pread(5,1,buffer,1000217168(62260/162/63)) lseek err Invalid argument
file_pread(5,1,buffer,1000215256(62260/132/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000217169(62260/163/1)) lseek err Invalid argument
file_pread(5,11,buffer,1000215247(62260/132/32)) lseek err Invalid argument
file_pread(5,1,buffer,1000217170(62260/163/2)) lseek err Invalid argument
file_pread(5,11,buffer,1000215248(62260/132/33)) lseek err Invalid argument
file_pread(5,1,buffer,1000217171(62260/163/3)) lseek err Invalid argument
file_pread(5,11,buffer,1000215249(62260/132/34)) lseek err Invalid argument
file_pread(5,1,buffer,1000217172(62260/163/4)) lseek err Invalid argument
file_pread(5,11,buffer,1000215250(62260/132/35)) lseek err Invalid argument
file_pread(5,1,buffer,1000217173(62260/163/5)) lseek err Invalid argument
file_pread(5,11,buffer,1000215251(62260/132/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000215251(62260/132/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000217174(62260/163/6)) lseek err Invalid argument
file_pread(5,11,buffer,1000215252(62260/132/37)) lseek err Invalid argument
file_pread(5,1,buffer,1000217175(62260/163/7)) lseek err Invalid argument
file_pread(5,11,buffer,1000215253(62260/132/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000217176(62260/163/8)) lseek err Invalid argument
file_pread(5,11,buffer,1000215254(62260/132/39)) lseek err Invalid argument
file_pread(5,1,buffer,1000217177(62260/163/9)) lseek err Invalid argument
file_pread(5,11,buffer,1000215255(62260/132/40)) lseek err Invalid argument
file_pread(5,1,buffer,1000217178(62260/163/10)) lseek err Invalid argument
file_pread(5,11,buffer,1000215256(62260/132/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000217179(62260/163/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000215267(62260/132/52)) lseek err Invalid argument
file_pread(5,1,buffer,1000217180(62260/163/12)) lseek err Invalid argument
file_pread(5,1,buffer,1000215268(62260/132/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000217181(62260/163/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000215269(62260/132/54)) lseek err Invalid argument
file_pread(5,1,buffer,1000217182(62260/163/14)) lseek err Invalid argument
file_pread(5,8,buffer,1000215213(62260/131/61)) ReadFile The drive cannot find the sector requested.
file_pread(5,11,buffer,1000215260(62260/132/45)) lseek err Invalid argument
file_pread(5,1,buffer,1000217183(62260/163/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000215271(62260/132/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000217184(62260/163/16)) lseek err Invalid argument
file_pread(5,1,buffer,1000215272(62260/132/57)) lseek err Invalid argument
file_pread(5,1,buffer,1000217185(62260/163/17)) lseek err Invalid argument
file_pread(5,1,buffer,1000215273(62260/132/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000217186(62260/163/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000215274(62260/132/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000217187(62260/163/19)) lseek err Invalid argument
file_pread(5,8,buffer,1000215218(62260/132/3)) lseek err Invalid argument
file_pread(5,11,buffer,1000215265(62260/132/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000217188(62260/163/20)) lseek err Invalid argument
file_pread(5,8,buffer,1000215219(62260/132/4)) lseek err Invalid argument
file_pread(5,1,buffer,1000215276(62260/132/61)) lseek err Invalid argument
file_pread(5,1,buffer,1000217189(62260/163/21)) lseek err Invalid argument
file_pread(5,8,buffer,1000215220(62260/132/5)) lseek err Invalid argument
file_pread(5,1,buffer,1000215220(62260/132/5)) lseek err Invalid argument
file_pread(5,1,buffer,1000215277(62260/132/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000217190(62260/163/22)) lseek err Invalid argument
file_pread(5,8,buffer,1000215221(62260/132/6)) lseek err Invalid argument
file_pread(5,1,buffer,1000215221(62260/132/6)) lseek err Invalid argument
file_pread(5,11,buffer,1000215268(62260/132/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000217191(62260/163/23)) lseek err Invalid argument
file_pread(5,8,buffer,1000215222(62260/132/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000215279(62260/133/1)) lseek err Invalid argument
file_pread(5,1,buffer,1000217192(62260/163/24)) lseek err Invalid argument
file_pread(5,8,buffer,1000215223(62260/132/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000215280(62260/133/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000217193(62260/163/25)) lseek err Invalid argument
file_pread(5,8,buffer,1000215224(62260/132/9)) lseek err Invalid argument
file_pread(5,11,buffer,1000215271(62260/132/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000217194(62260/163/26)) lseek err Invalid argument
file_pread(5,8,buffer,1000215225(62260/132/10)) lseek err Invalid argument
file_pread(5,1,buffer,1000215282(62260/133/4)) lseek err Invalid argument
file_pread(5,1,buffer,1000217195(62260/163/27)) lseek err Invalid argument
file_pread(5,8,buffer,1000215226(62260/132/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000215226(62260/132/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000215283(62260/133/5)) lseek err Invalid argument
file_pread(5,1,buffer,1000217196(62260/163/28)) lseek err Invalid argument
file_pread(5,8,buffer,1000215227(62260/132/12)) lseek err Invalid argument
file_pread(5,11,buffer,1000215274(62260/132/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000217197(62260/163/29)) lseek err Invalid argument
file_pread(5,8,buffer,1000215228(62260/132/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000215285(62260/133/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000217198(62260/163/30)) lseek err Invalid argument
file_pread(5,8,buffer,1000215229(62260/132/14)) lseek err Invalid argument
file_pread(5,1,buffer,1000215286(62260/133/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000217199(62260/163/31)) lseek err Invalid argument
file_pread(5,8,buffer,1000215230(62260/132/15)) lseek err Invalid argument
file_pread(5,11,buffer,1000215277(62260/132/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000217200(62260/163/32)) lseek err Invalid argument
file_pread(5,1,buffer,1000215238(62260/132/23)) lseek err Invalid argument
file_pread(5,1,buffer,1000215288(62260/133/10)) lseek err Invalid argument
file_pread(5,1,buffer,1000217201(62260/163/33)) lseek err Invalid argument
file_pread(5,1,buffer,1000215289(62260/133/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000217202(62260/163/34)) lseek err Invalid argument
file_pread(5,1,buffer,1000215290(62260/133/12)) lseek err Invalid argument
file_pread(5,1,buffer,1000217203(62260/163/35)) lseek err Invalid argument
file_pread(5,8,buffer,1000215234(62260/132/19)) lseek err Invalid argument
file_pread(5,11,buffer,1000215281(62260/133/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000217204(62260/163/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000215292(62260/133/14)) lseek err Invalid argument
file_pread(5,1,buffer,1000217205(62260/163/37)) lseek err Invalid argument
file_pread(5,1,buffer,1000215293(62260/133/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000217206(62260/163/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000215244(62260/132/29)) lseek err Invalid argument
file_pread(5,1,buffer,1000215294(62260/133/16)) lseek err Invalid argument
file_pread(5,1,buffer,1000217207(62260/163/39)) lseek err Invalid argument
file_pread(5,8,buffer,1000215238(62260/132/23)) lseek err Invalid argument
file_pread(5,11,buffer,1000215285(62260/133/7)) lseek err Invalid argument
file_pread(5,1,buffer,1000217208(62260/163/40)) lseek err Invalid argument
file_pread(5,1,buffer,1000215296(62260/133/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000217209(62260/163/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000215297(62260/133/19)) lseek err Invalid argument
file_pread(5,1,buffer,1000217210(62260/163/42)) lseek err Invalid argument
file_pread(5,1,buffer,1000215298(62260/133/20)) lseek err Invalid argument
file_pread(5,1,buffer,1000217211(62260/163/43)) lseek err Invalid argument
file_pread(5,8,buffer,1000215242(62260/132/27)) lseek err Invalid argument
file_pread(5,11,buffer,1000215289(62260/133/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000217212(62260/163/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000215300(62260/133/22)) lseek err Invalid argument
file_pread(5,1,buffer,1000217213(62260/163/45)) lseek err Invalid argument
file_pread(5,1,buffer,1000215301(62260/133/23)) lseek err Invalid argument
file_pread(5,1,buffer,1000217214(62260/163/46)) lseek err Invalid argument
file_pread(5,1,buffer,1000215302(62260/133/24)) lseek err Invalid argument
file_pread(5,1,buffer,1000217215(62260/163/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000215232(62260/132/17)) lseek err Invalid argument
file_pread(5,8,buffer,1000215246(62260/132/31)) lseek err Invalid argument
file_pread(5,11,buffer,1000215293(62260/133/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000217216(62260/163/48)) lseek err Invalid argument
file_pread(5,1,buffer,1000215304(62260/133/26)) lseek err Invalid argument
file_pread(5,1,buffer,1000217217(62260/163/49)) lseek err Invalid argument
file_pread(5,1,buffer,1000215305(62260/133/27)) lseek err Invalid argument
file_pread(5,1,buffer,1000217218(62260/163/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000215306(62260/133/28)) lseek err Invalid argument
file_pread(5,1,buffer,1000217219(62260/163/51)) lseek err Invalid argument
file_pread(5,8,buffer,1000215250(62260/132/35)) lseek err Invalid argument
file_pread(5,11,buffer,1000215297(62260/133/19)) lseek err Invalid argument
file_pread(5,1,buffer,1000217220(62260/163/52)) lseek err Invalid argument
file_pread(5,1,buffer,1000215258(62260/132/43)) lseek err Invalid argument
file_pread(5,1,buffer,1000215308(62260/133/30)) lseek err Invalid argument
file_pread(5,1,buffer,1000217221(62260/163/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000215259(62260/132/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000215309(62260/133/31)) lseek err Invalid argument
file_pread(5,1,buffer,1000217222(62260/163/54)) lseek err Invalid argument
file_pread(5,1,buffer,1000215260(62260/132/45)) lseek err Invalid argument
file_pread(5,1,buffer,1000215310(62260/133/32)) lseek err Invalid argument
file_pread(5,1,buffer,1000217223(62260/163/55)) lseek err Invalid argument
file_pread(5,8,buffer,1000215254(62260/132/39)) lseek err Invalid argument
file_pread(5,11,buffer,1000215301(62260/133/23)) lseek err Invalid argument
file_pread(5,1,buffer,1000217224(62260/163/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000215262(62260/132/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000215312(62260/133/34)) lseek err Invalid argument
file_pread(5,1,buffer,1000217225(62260/163/57)) lseek err Invalid argument
file_pread(5,1,buffer,1000215263(62260/132/48)) lseek err Invalid argument
file_pread(5,1,buffer,1000215313(62260/133/35)) lseek err Invalid argument
file_pread(5,1,buffer,1000217226(62260/163/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000215264(62260/132/49)) lseek err Invalid argument
file_pread(5,1,buffer,1000215314(62260/133/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000217227(62260/163/59)) lseek err Invalid argument
file_pread(5,8,buffer,1000215258(62260/132/43)) lseek err Invalid argument
file_pread(5,11,buffer,1000215305(62260/133/27)) lseek err Invalid argument
file_pread(5,1,buffer,1000217228(62260/163/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000215245(62260/132/30)) lseek err Invalid argument
file_pread(5,1,buffer,1000215266(62260/132/51)) lseek err Invalid argument
file_pread(5,1,buffer,1000215316(62260/133/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000217229(62260/163/61)) lseek err Invalid argument
file_pread(5,1,buffer,1000215317(62260/133/39)) lseek err Invalid argument
file_pread(5,1,buffer,1000217230(62260/163/62)) lseek err Invalid argument
file_pread(5,1,buffer,1000215318(62260/133/40)) lseek err Invalid argument
file_pread(5,1,buffer,1000217231(62260/163/63)) lseek err Invalid argument
file_pread(5,8,buffer,1000215262(62260/132/47)) lseek err Invalid argument
file_pread(5,11,buffer,1000215309(62260/133/31)) lseek err Invalid argument
file_pread(5,1,buffer,1000217232(62260/164/1)) lseek err Invalid argument
file_pread(5,1,buffer,1000215270(62260/132/55)) lseek err Invalid argument
file_pread(5,1,buffer,1000215320(62260/133/42)) lseek err Invalid argument
file_pread(5,1,buffer,1000217233(62260/164/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000215321(62260/133/43)) lseek err Invalid argument
file_pread(5,1,buffer,1000217234(62260/164/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000215322(62260/133/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000217235(62260/164/4)) lseek err Invalid argument
file_pread(5,8,buffer,1000215266(62260/132/51)) lseek err Invalid argument
file_pread(5,11,buffer,1000215313(62260/133/35)) lseek err Invalid argument
file_pread(5,1,buffer,1000217236(62260/164/5)) lseek err Invalid argument
file_pread(5,1,buffer,1000215324(62260/133/46)) lseek err Invalid argument
file_pread(5,1,buffer,1000217237(62260/164/6)) lseek err Invalid argument
file_pread(5,1,buffer,1000215275(62260/132/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000215325(62260/133/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000217238(62260/164/7)) lseek err Invalid argument
file_pread(5,8,buffer,1000215269(62260/132/54)) lseek err Invalid argument
file_pread(5,11,buffer,1000215316(62260/133/38)) lseek err Invalid argument
file_pread(5,1,buffer,1000217239(62260/164/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000215327(62260/133/49)) lseek err Invalid argument
file_pread(5,1,buffer,1000217240(62260/164/9)) lseek err Invalid argument
file_pread(5,1,buffer,1000215257(62260/132/42)) lseek err Invalid argument
file_pread(5,1,buffer,1000215278(62260/132/63)) lseek err Invalid argument
file_pread(5,1,buffer,1000215328(62260/133/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000217241(62260/164/10)) lseek err Invalid argument
file_pread(5,8,buffer,1000215272(62260/132/57)) lseek err Invalid argument
file_pread(5,11,buffer,1000215319(62260/133/41)) lseek err Invalid argument
file_pread(5,1,buffer,1000217242(62260/164/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000215330(62260/133/52)) lseek err Invalid argument
file_pread(5,1,buffer,1000217243(62260/164/12)) lseek err Invalid argument
file_pread(5,1,buffer,1000215281(62260/133/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000215331(62260/133/53)) lseek err Invalid argument
file_pread(5,1,buffer,1000217244(62260/164/13)) lseek err Invalid argument
file_pread(5,1,buffer,1000215261(62260/132/46)) lseek err Invalid argument
file_pread(5,8,buffer,1000215275(62260/132/60)) lseek err Invalid argument
file_pread(5,11,buffer,1000215322(62260/133/44)) lseek err Invalid argument
file_pread(5,1,buffer,1000217245(62260/164/14)) lseek err Invalid argument
file_pread(5,1,buffer,1000215333(62260/133/55)) lseek err Invalid argument
file_pread(5,1,buffer,1000217246(62260/164/15)) lseek err Invalid argument
file_pread(5,1,buffer,1000215284(62260/133/6)) lseek err Invalid argument
file_pread(5,1,buffer,1000215334(62260/133/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000217247(62260/164/16)) lseek err Invalid argument
file_pread(5,8,buffer,1000215278(62260/132/63)) lseek err Invalid argument
file_pread(5,11,buffer,1000215325(62260/133/47)) lseek err Invalid argument
file_pread(5,1,buffer,1000217248(62260/164/17)) lseek err Invalid argument
file_pread(5,1,buffer,1000215265(62260/132/50)) lseek err Invalid argument
file_pread(5,1,buffer,1000215336(62260/133/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000217249(62260/164/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000215287(62260/133/9)) lseek err Invalid argument
file_pread(5,1,buffer,1000215337(62260/133/59)) lseek err Invalid argument
file_pread(5,1,buffer,1000217250(62260/164/19)) lseek err Invalid argument
file_pread(5,14,buffer,1000215204(62260/131/52)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1000215218(62260/132/3)) lseek err Invalid argument
file_pread(5,3,buffer,1000215265(62260/132/50)) lseek err Invalid argument
file_pread(5,8,buffer,1000215281(62260/133/3)) lseek err Invalid argument
file_pread(5,11,buffer,1000215328(62260/133/50)) lseek err Invalid argument
file_pread(5,2,buffer,1000217250(62260/164/19)) lseek err Invalid argument
file_pread(5,14,buffer,1000215205(62260/131/53)) ReadFile The drive cannot find the sector requested.
file_pread(5,2,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,3,buffer,1000215219(62260/132/4)) lseek err Invalid argument
file_pread(5,3,buffer,1000215266(62260/132/51)) lseek err Invalid argument
file_pread(5,8,buffer,1000215282(62260/133/4)) lseek err Invalid argument
file_pread(5,11,buffer,1000215329(62260/133/51)) lseek err Invalid argument
file_pread(5,2,buffer,1000217251(62260/164/20)) lseek err Invalid argument
file_pread(5,14,buffer,1000215206(62260/131/54)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,3,buffer,1000215220(62260/132/5)) lseek err Invalid argument
file_pread(5,3,buffer,1000215267(62260/132/52)) lseek err Invalid argument
file_pread(5,8,buffer,1000215283(62260/133/5)) lseek err Invalid argument
file_pread(5,11,buffer,1000215330(62260/133/52)) lseek err Invalid argument
file_pread(5,2,buffer,1000217252(62260/164/21)) lseek err Invalid argument
file_pread(5,14,buffer,1000215207(62260/131/55)) ReadFile The drive cannot find the sector requested.
file_pread(5,4,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,3,buffer,1000215221(62260/132/6)) lseek err Invalid argument
file_pread(5,3,buffer,1000215268(62260/132/53)) lseek err Invalid argument
file_pread(5,8,buffer,1000215284(62260/133/6)) lseek err Invalid argument
file_pread(5,11,buffer,1000215331(62260/133/53)) lseek err Invalid argument
file_pread(5,2,buffer,1000217253(62260/164/22)) lseek err Invalid argument
file_pread(5,14,buffer,1000215208(62260/131/56)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1000215222(62260/132/7)) lseek err Invalid argument
file_pread(5,3,buffer,1000215269(62260/132/54)) lseek err Invalid argument
file_pread(5,8,buffer,1000215285(62260/133/7)) lseek err Invalid argument
file_pread(5,11,buffer,1000215332(62260/133/54)) lseek err Invalid argument
file_pread(5,2,buffer,1000217254(62260/164/23)) lseek err Invalid argument
file_pread(5,1,buffer,1000215343(62260/134/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000217256(62260/164/25)) lseek err Invalid argument
file_pread(5,14,buffer,1000215210(62260/131/58)) ReadFile The drive cannot find the sector requested.
file_pread(5,7,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,3,buffer,1000215224(62260/132/9)) lseek err Invalid argument
file_pread(5,3,buffer,1000215271(62260/132/56)) lseek err Invalid argument
file_pread(5,8,buffer,1000215287(62260/133/9)) lseek err Invalid argument
file_pread(5,11,buffer,1000215334(62260/133/56)) lseek err Invalid argument
file_pread(5,1,buffer,1000217257(62260/164/26)) lseek err Invalid argument
file_pread(5,1,buffer,1000215295(62260/133/17)) lseek err Invalid argument
file_pread(5,1,buffer,1000215345(62260/134/4)) lseek err Invalid argument
file_pread(5,1,buffer,1000217258(62260/164/27)) lseek err Invalid argument
file_pread(5,14,buffer,1000215212(62260/131/60)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1000215226(62260/132/11)) lseek err Invalid argument
file_pread(5,3,buffer,1000215273(62260/132/58)) lseek err Invalid argument
file_pread(5,8,buffer,1000215289(62260/133/11)) lseek err Invalid argument
file_pread(5,11,buffer,1000215336(62260/133/58)) lseek err Invalid argument
file_pread(5,1,buffer,1000217259(62260/164/28)) lseek err Invalid argument
file_pread(5,10,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000215347(62260/134/6)) lseek err Invalid argument
file_pread(5,1,buffer,1000217260(62260/164/29)) lseek err Invalid argument
file_pread(5,14,buffer,1000215214(62260/131/62)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1000215228(62260/132/13)) lseek err Invalid argument
file_pread(5,3,buffer,1000215275(62260/132/60)) lseek err Invalid argument
file_pread(5,8,buffer,1000215291(62260/133/13)) lseek err Invalid argument
file_pread(5,11,buffer,1000215338(62260/133/60)) lseek err Invalid argument
file_pread(5,1,buffer,1000217261(62260/164/30)) lseek err Invalid argument
file_pread(5,12,buffer,1000215217(62260/132/2)) lseek err Invalid argument
file_pread(5,1,buffer,1000215299(62260/133/21)) lseek err Invalid argument
file_pread(5,1,buffer,1000215349(62260/134/8)) lseek err Invalid argument
file_pread(5,1,buffer,1000217262(62260/164/31)) lseek err Invalid argument
file_pread(5,1,buffer,1000215350(62260/134/9)) lseek err Invalid argument
file_pread(5,1,buffer,1000217263(62260/164/32)) lseek err Invalid argument
file_pread(5,2,buffer,1000215229(62260/132/14)) lseek err Invalid argument
file_pread(5,8,buffer,1000215294(62260/133/16)) lseek err Invalid argument
file_pread(5,11,buffer,1000215341(62260/133/63)) lseek err Invalid argument
file_pread(5,1,buffer,1000217264(62260/164/33)) lseek err Invalid argument
file_pread(5,14,buffer,1000215218(62260/132/3)) lseek err Invalid argument
file_pread(5,1,buffer,1000215352(62260/134/11)) lseek err Invalid argument
file_pread(5,1,buffer,1000217265(62260/164/34)) lseek err Invalid argument
Re: Disk shows as unallocated after a forced shutdown
After Quick search, use 'a' to manually add the "MS Reserved" partition.
Set all the partitions to P(rimary) and on next screen, choose to Write
disk0
#3 Post by disk0 »
Thank you for the reply. I did as you suggested. I marked the three real partitions as primary (P), left that one ghost partition as D and manually added MS Reserved. After I rebooted to the new disk Windows now saw the partitions of the old disk and all of its files. When I tried to boot to the old disk I got a blue screen of death during bootup complaining about error "0xc000000e: A required device isn’t connected or cannot be accessed". After some googling I found a solution. I started Windows from the new disk and ran these commands:
bcdboot D:\Windows
bcdboot C:\Windows
Now I could dual boot to either Windows installation. This only works when the new disk is the first in the boot order in BIOS.
