I had a INTEL RST Raid 5 with Server 2012 running with 6x1,8 TB disks. One disk get corrupted and it started to rebuild. Unfortunately the rebuild did not work end ended in a raid “failed” status
With one “non member” disk. I recreated the raid with the exact Name and Strip size and order of the disks. And started testdisk.
Testdisk showed me the partitions and I started deeper search. The Search is taking quite a while (Cause one other disk is maybe also damaged)
Now I am at 70% analyze of testdisk and have following error messages :
Disk /dev/md126 – 10001 GB /9315GiB – CHS 2441890048 2 4
Analyse cylinder 1711034508/2441890047: 70%
MS DATA 108 3907025087
Warning: number of heads /cylinder mismatches 255(NTFS) !=2(HD)
Warning: number of sectors per track mismatches 255(NTFS) !=4(HD)
MS Data 1083392 4122073087 4120989696
MS DATA 4122073087 82430627824120989696
Check_FAT: Bad jump in Fat partition
Unknown 9492874924 12471969382 2979094459
MS Data 9673026483 9676494184 3467701 [)t ‘R’]
Unknown 9878425790 992315754685 9824328896 [#DO]
Unknown 10025397319 10025397318 0[ < ~E
Unknown 10812449154 10812449153 0[ ~YC’Zr]
MAC HFS 11888959876 13239526020 1350566145 [Oj~] 4T
E’ ?
What do this errors mean, and what ist the best way to get any data back ?
thanks
Help with partition and data rescue raid5 Intel RST
Johannes195
Re: Help with partition and data rescue raid5 Intel RST
You have to rebuild your RAID completely before running testdisk.
