Bonjour a tous,
si quelqu'un peut m'aider merci d'avance j'y ai plein de photo (disque dur de sauvegarde)
le journal de testdisk.
Sun Mar 8 13:15:27 2020
TestDisk 7.2-WIP, Data Recovery Utility, January 2020
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=33820286976
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=160041885696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=400088457216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=33820286976
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=160041885696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=400088457216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=160031015424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=400085328384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=33820286976
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=207484928
filewin32_getfilesize(\\.\L:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\L:) SetFilePointer err Fonction incorrecte.
filewin32_getfilesize(\\.\M:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\M:) SetFilePointer err Fonction incorrecte.
Warning: can't get size for \\.\M:
Disk /dev/sda - 33 GB / 31 GiB - CHS 4111 255 63, sector size=512 - ST380011A, S/N:4a3339564b5a3057202020202020202020202020, FW:3.16
Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WDC WD1600AAJS-07PSA0, S/N:2020202057202d44435750413439303235393130, FW:05.06H05
Disk /dev/sdc - 400 GB / 372 GiB - CHS 51681 240 63, sector size=512 - WDC WD4000AAJS-00YFA0, S/N:2020202057202d44435753413038353730323230, FW:12.01C02
Drive F: - 207 MB / 197 MiB - CHS 49 64 32, sector size=2048 - PIONEER DVD-RW DVR-107D, FW:1.22
Disk /dev/sda - 33 GB / 31 GiB - ST380011A
Analyse Disk /dev/sda - 33 GB / 31 GiB - CHS 4111 255 63
test_FAT()
1 * FAT16 <32M 0 0 1 4111 190 63 66055248
sector_size 190
cluster_size 124
reserved 191
fats 6
dir_entries 185
sectors 62209
media A5
fat_length 61118
secs_track 45063
heads 59912
hidden 1568
total_sect 129187456
Invalid FAT boot sector
La partition suivante ne peut pas être récupérée
Re: La partition suivante ne peut pas être récupérée
Il faudrait le résultat du Quick Search et si la partition n'est pas trouvée, celui aussi du Deeper Search.
