Cannot mark a partition logical on testdisk
appiazzolla
#1 Post by appiazzolla »
My hard disk broke and I am trying to recover all the data I can from the largest of three partitions.
At the moment I have replaced the hard disk for another and I am trying to recover the data from the broken HDD from a case that lets me connect the disk via USB to my laptop, running Debian 10 buster, at /dev/sdb
fdisk gives me Input/Output error e2fsck as well
Testdisk 7.0 is able to see all the data in the partition I am interested in recovering, and also sees all the partitions, as follows
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 953869 64 32
>D Linux                    1   0  1 39771  63 32   81451008
 D Linux                36723   0  1 953868  63 32 1878315008
 D Linux Swap           39773   0  1 47878  63 32   16601088
     Enter: to continue
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 41 GB / 38 GiB
I am not able to recreate the partition table, the option "Logical" does not appear when using Left/Right arrows. I would like to set the first partition as Primary bootable, the second as Logical and the third is Swap, so I don't know.
Afterwards I plan to use e2fsck and then copy the information somewhere else.
Could anybody help me?
Thanks everybody.
Re: Cannot mark a partition logical on testdisk
The 3 listed partitions overlap.
As fdisk and fsck repots I/O errors, you should clone the disk to a new empty disk using ddrescue as described in https://www.cgsecurity.org/testdisk.pdf
Once it's done, remove the original disk and try to access your data from the clone.
appiazzolla
#3 Post by appiazzolla »
Thank you so much! I recovered the data.
If you indulge me with one more thing... How can I fix the overlapping partitions if fdisk, parted and fsck give me input/output error?
Thanks again!
You should only set the partition containing your data as "Primary".
appiazzolla
#5 Post by appiazzolla »
Thank you. I did that twice, always writing the testdisk changes and then disconnecting the disk and reconnecting it afterwards.
When I connect it again I still get Input/Output in fsck, fdisk, parted... So I can't format the disk :-(
Here's my testdisk output
     Enter: to continue
Is there any way to write the correct partition table?
Thank you!
#6 Post by recuperation »
appiazzolla wrote: 23 Mar 2020, 20:48 Thank you. I did that twice, always writing the testdisk changes and then disconnecting the disk and reconnecting it afterwards.
     Enter: to continue
Thank you!
Looks like you did not use ddrescue as proposed.
#7 Post by recuperation »
I would ask that question on every forum available:
https://superuser.com/questions/1534625 ... n-testdisk
appiazzolla
#8 Post by appiazzolla »
As I said before, I could recover the information and is OK.
I just want to be able to format the disk, that is all.
Of course, any forum would do.
#9 Post by recuperation »
Zero out your disk at the expense of loosing its content.
appiazzolla wrote: 24 Mar 2020, 22:40 Of course, any forum would do.
Consider reading about Netiquette.
#10 Post by recuperation »
Use smartmontools to check for failures.
Further use may probably not be recommended anymore.
