Filesystem may be damaged, BS OK, MFT not OK!
MerNion
#1 Post by MerNion »
Hey!
I have a WD Cavial Blue 250GB WD2500AAJB disk which all of a sudden stopped working. I run testdisk from a livecd and eventhough it says that it is NTFS and displays the size correctly, when i try to list the files it says "Filesystem may be damaged". From the Advanced menu > Boot it says the Boot sector and backup boot sector is OK, BUT it can not read the MFT.. Look at last screenshot.
Here are the screenshots from testdisk:
The important one though i think is this one:
What do I do now that MFT can't be read...?
Thanks a lot!
wargo
Re: Filesystem may be damaged, BS OK, MFT not OK!
#2 Post by wargo »
Did you try "Repair MFT"?
MerNion
#3 Post by MerNion »
Yes, it is the last screenshot above. "Can't read NTFS MFT".
