Overwritten Partition Tables with dd
hkjz
#1 Post by hkjz »
i have had an external hard drive 2TB,
while it was plugged in and something was being copied from/to, i plugged in USBstick to install linux on it.
I selected wrong target USB Device, and 'dd' process started. I canceled it after couple seconds, but problem arrived unavoidable.
It was partition with Apple OSx backups, so it probably was sort of modern Apple PartitionTables
2)
Current status of the drive is like this
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: M3 Portable
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: dos
Disk identifier: 0x814555ba
Device     Boot Start      End  Sectors  Size Id Type
/dev/sda1        8192    92159    83968   41M  c W95 FAT32 (LBA)
/dev/sda2       92160 15126527 15034368  7.2G 83 Linux
3)
I've got other 2TB drive, and made 'dd' copy of the overwritten one, to work saftely.
4)
current software i have is
TestDisk 7.0
PhotoRec 7.0
thank you,
your work is and will be appriciated.
Re: Overwritten Partition Tables with dd
It's probably an EFI GPT partition table.
Here is an example of an encrypted 3TB external disk seen by latest 7.2-WIP
     Partition			Start        End    Size in sectors
 1 P EFI System                    40     409639     409600 [EFI System Partition]
 2 P Apple Core Storage        409640 5860270983 5859861344
 3 P Mac Boot              5860270984 5860533127     262144 [Booter]
You can run PhotoRec a few minutes and see if it recover something (ignore the files copied by dd). If it recovers your data, it's not an encrypted filesystem.
hkjz
#3 Post by hkjz »
@cgrenier,
thank you,
Encryption was never a topic on this hard drive, it is not encrypted,
It was one partition backup harddrive, where i overwritten Partition Tables (as it is shown in sudo fdisk -l above), and files are not visible anymore.
Which approach would be preferable way, to handle such a situation.
Am i able to get partition back, folders names, file names
or best i can count on,
is recovery made by PhotoRec with 'random' names like f234567887654.png ?
