Hello people. This is my first time writing in this forum, but I really need your help.
Last night I started cleaning up and sorting files on my pc and I messed up. Here is everything that happened.
I'm using Windows 7 One of my hard drives had 2 partitions "D" and "E".
Partition "D" was 700GB and partition "E" was approximately 1160GB.
I wanted to combine the two partitions and to have only one partition for this drive. I moved my files from "D" to "E" and deleted the "D" partition. When I tried to extend the E partition so it can use the available space windows said that it needed to be converted to dynamic partition. I was never being asked to do that before and it seemed weird, because this were not my system partitions and windows had nothing to do with them. So I converted them to dynamic and I had only 1 letter in my computer, but in the disk manager they were still separated. They were highlighted in yellow. I didn't liked that and I decided to delete the "D" partition again. The problem is that now both partitions are gone ("D" and "E", and my data was on partition "E").
I started looking up online and found out about TestDisk. I downloaded the 64 bit version, selected the drive, and selected the Intel option, then I selected analyze, selected quick search (it started from 37% analyzing) and I stopped it, one of my partitions showed up. I think that the star option was selected (Primary bootable) and pressed enter. I restarted my PC and one of my partitions showed up. The problem was that the partition that I recovered the empty "D" partition.
I tried the scanning again and let it scan to 100%, then I selected the partition that showed up, but again that was the empty partition.
Now when I start scanning I get an error saying that the hard disk seems too small.
https://imgur.com/BqJutsC
Could you please help me recover my deleted dynamic partition. Any help will be appreciated, thanks.
Recovering a deleted dynamic disk partition in windows
Re: Recovering a deleted dynamic disk partition in windows
Choose Continue and post the results from the next screen.
Sorry for the late reply. Managed to recover all of my files using different software.
From what I saw using TestDisk somehow I accidentally had recovered the empty partition twice, but not the other one.
You can close the topic.
