how to find the correct partition type [list of partition type]?
dentonmedia
#1 Post by dentonmedia »
Thanks for this great software,
How do I find the correct type under
  • Please.
    Sat Apr 4 00:38:42 2020
    TestDisk 7.2-WIP, Data Recovery Utility, July 2019
    OS: Windows 8 (9200)
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499180469760
    Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500830AS, S/N:5QG29CSR, FW:3.AAD
    Disk /dev/sdb - 500 GB / 465 GiB - CHS 7600 255 63, sector size=4096 - WDC WD50 00LPCX-24C6HT0, S/N:152D20337A0C
    Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 7600 255 63, sector size=4096 - WDC WD50 00LPCX-24C6HT0, S/N:152D20337A0C
    Disk /dev/sdb - 500 GB / 465 GiB - WDC WD50 00LPCX-24C6HT0
    New geometry
    Disk /dev/sdb - 500 GB / 465 GiB - CHS 60802 255 63 sector_size=512
    New options :
    Dump : No
    Align partition: Yes
    Expert mode : Yes
    Analyse Disk /dev/sdb - 500 GB / 465 GiB - CHS 60802 255 63
    Partition: Read error
    file_pread(5,2,buffer,4(0/0/5)) ReadFile Data error (cyclic redundancy check).
    file_pread(5,2,buffer,122098175(7600/66/18)) lseek err Invalid argument
    file_pread(5,1,buffer,0(0/0/1)) ReadFile Data error (cyclic redundancy check).
    interface_load
    Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63 Mon Sep 30 10:43:17 2019
    1 * HPFS - NTFS 0 32 33 121601 25 24 1953519616
    Disk /dev/sdb - 500 GB / 465 GiB - CHS 7600 255 63 Wed Apr 1 06:55:59 2020
    write!
    Store new MBR code
    read failed but trying to write anywayfile_pwrite(5,1,buffer,0(0/0/1)) write err File truncated
    Partition: Write error
    file_pread(5,1,buffer,0(0/0/1)) ReadFile The specified network resource or device is no longer available.
Re: how to find the correct partition type [list of partition type]?
It is a physical problem. You should contact a data recovery company.
dentonmedia
#3 Post by dentonmedia »
Thanks for your response.
I was able to list the files and then I was unable to list them again.
What would be the best approach with testdisk to reset the drive or make it usable again?
dentonmedia
#4 Post by dentonmedia »
cgrenier wrote: 04 Apr 2020, 07:52 It is a physical problem. You should contact a data recovery company.
I don't know which partition type to select under the list partition type for this drive.
[edit]Is there a way to find out which partition type would fit the drive plugged in with testdisk?[/edit]
