I'm not that familiar with all the terms, so I hope I can explain properly what happend.
I'm using WD My Passport, and several days ago I ran the command:
""dd if=/dev/sdb of=/dev/sda..."
After about 29GB have been copied, I stopped the process using CTRL + C, as I realised it wasn't just copying the data from one place to another, but over-writting in the process.
I was using a dual-booted computer, having windows 10 & Ubuntu 19.04.
In the last few days I tried recovering files from the external hard disk using PhotoRec.
However, because I over-written the partition info, only some of the disk's storage space partitions were displayed (as EFI partitions).
In the last 20hours testdisk is running (I chose the EFI option), and I wonder what I should do next and did I make the right choice?
I currently planned of following the Documentation's section 8.1 TestDisk: undelete file for FAT, exFAT, ext2.
Written into WD My Passport using dd command
Re: Written into WD My Passport using dd command
Using TestDisk, you should be able to recover the partitions starting after the first 29GB.
If the first partition was an NTFS, TestDisk may be able to find it using the NTFS boot sector (After Analyse, Quick Search and Deeper Search).
If it's the case, choose BackupBS when asked.
I will try it as soon as the deeper search ends.
Is it normal that it analyses 1 cylinder/second?
When the Quick Search ended it found two partitions starting at 2048, one was the EFI system and the other was the desired My Passport partition (that was missing before).
Perhaps I can post some of the details in the log file for more details, where can I find it?
in the folder with the Testdisk executable file
The beginning of the log file:
Afterwards I received about 2000 rows along the lines of:
and
Finally, the quick search results:
Sun Apr 5 12:28:07 2020
TestDisk 7.2-WIP, Data Recovery Utility, January 2020
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=263257587712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=26843545600
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000LPCX-24VHAT0, S/N:WD-WXF1A188YJFZ, FW:02.01A02
Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD My Passport 25E2, S/N:WX71A87798Z4, FW:4004
Disk /dev/sdb - 2000 GB / 1862 GiB - WD My Passport 25E2
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3906963455 (expected 3906963455)
hdr_lba_start=34
hdr_lba_end=3906963422
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Reserved 534528 567295 32768 [Microsoft reserved partition]
4 P MS Data 922296320 974725119 52428800 [Basic data partition]
1 P EFI System 2048 534527 532480 [EFI system partition]
3 P MS Data 567296 514742271 514174976 [Basic data partition]
NTFS, blocksize=4096, 263 GB / 245 GiB
6 P Linux filesys. data 678582272 922296319 243714048
5 P Windows Recovery Env 974725120 976773119 2048000 [Basic data partition]
Analyse Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 0/32/33
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
no_of_cluster : 65536 (2 - 65537)
fat_length 513 calculated 513
FAT32 at 0/32/33
FAT: cluster=2(0x2), pos=10240
EFI System 2048 534527 532480 [EFI System Partition] [SYSTEM_DRV]
FAT32, blocksize=4096, 272 MB / 260 MiB
NTFS at 35/79/45
filesystem size 514174976
mftmirr_lcn 2
NTFS part_offset=290455552, part_size=263257587712, sector_size=512
NTFS at 35/79/45
mftmirr_lcn 2
LVM magic value at 32861/156/22
FAT12 at 56345/163/35
check_FAT: Unusual media descriptor (0xf8!=0xf0)
FAT1 : 1-4
FAT2 : 5-8
start_rootdir : 9
Data : 41-4860
sectors : 4864
cluster_size : 4
no_of_cluster : 1205 (2 - 1206)
fat_length 4 calculated 4
heads/cylinder 64 (FAT) != 255 (HD)
EFI System 905192728 905197591 4864 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 2490 KB / 2432 KiB
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/2799, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 91749888
recover_EXT2: part_size 733999104
Filesystem created: Sat Jul 21 10:10:22 2018
Linux filesys. data 1023724454 1757723557 733999104
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 375 GB / 349 GiB
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/2799, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux filesys. data 1143371974 1877371077 733999104
NTFS at 243197/25/28
filesystem size 3906959360
mftmirr_lcn 2
MS Data 2048 3906961407 3906959360 [My Passport]
NTFS found using backup sector, blocksize=4096, 2000 GB / 1862 GiB
mftmirr_lcn 2
file_pread(5,2,buffer,3913252869(243588/184/58)) lseek err Invalid argument
file_pread(5,1,buffer,3913252869(243588/184/58)) lseek err Invalid argument
NTFS: Can't read MFT
MS Data 3906961407 7813920766 3906959360
NTFS, blocksize=4096, 2000 GB / 1862 GiB
This partition ends after the disk limits. (start=3906961407, size=3906959360, end=7813920766, disk end=3906963456)
file_pread(5,1,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,3906965505(243197/90/31)) lseek err Invalid argumentCode: Select all
file_pread(5,1,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.Code: Select all
The harddisk (2000 GB / 1862 GiB) seems too small! (< 4000 GB / 3725 GiB)
NTFS filesystem needs to be repaired.
