Hi again,
And I'm really sorry for bothering.
I ran Disk Drill to understand what's in a memory card I have and recover a few files. I then ran PhotoRec to recover the files. Unfortunately, even after selecting the whole partition, Photorec did not recover all files that Disk Drill had detected.
If it helps, Photorec is detecting several different partitions (which is weird). So maybe I should run it for every single partition?
Thank you and very best,
Hollow
Photorec "didn't" recover "all" files
Hollow77Shots
Re: Photorec didn't recover all files
Different concept, different results. Not comparable.Hollow77Shots wrote: 10 Apr 2020, 14:52 Hi again,
Totally logical depending on the content found.
If you just had one partition before run it on the whole disk.So maybe I should run it for every single partition?
Hollow77Shots
Re: Photorec "didn't" recover "all" files
Hi recuperation,
Thank you.
Truth be said, I'm still strugling with this: viewtopic.php?f=7&t=9941. I now understand that because the external hard drive lost power while being used, a number of files got lost and lost track of themselves. By connecting the external hard drive with a Windows PC, windows repair system put these files in a FOUND folder and gave the files a .chk type.
I just need to know how I can recover these files from before this change and if this is even possible? If I "undelete", these don't show up.
I'm really thankful for all the help. These files are massively important and all that possibly helps is very much welcome.
Very best regards.
Thank you.
Not sure I understand, I'm sorry. In what way? And then how can I recover the rest of the files detected by disk drill from the memory card (that is actually empty)."Different concept, different results. Not comparable."
What happened was that the usb disconnected a few times while I was using Test Disk and every time I reconected a new dev/r would show up. In the end, I was able to do part of what I intended by disconnecting the memory card and working with the newest dev/r."Totally logical depending on the content found"
Very best regards.
Different recovery strategy. I explained that in a posting during the last 2 or 3 months but I can't find it now.Hollow77Shots wrote: 10 Apr 2020, 19:44Not sure I understand,"Different concept, different results. Not comparable."
Ask the disk drill support.I'm sorry. In what way? And then how can I recover the rest of the files detected by disk drill from the memory card (that is actually empty).
You used Testdisk on your broken computer? This is really destructive and a very stupid idea. Common sense should prevent you from doing so.What happened was that the usb disconnected a few times while I was using Test Disk"Totally logical depending on the content found"
Sorry, I personally don't want to hear those stories about massively important files anymore - that is outright ridiculous.and every time I reconected a new dev/r would show up. In the end, I was able to do part of what I intended by disconnecting the memory card and working with the newest dev/r.
If so consult a professional recovery service - if there is anything left to rescue after all your interventions.
As can be seen from our conversation from the other thread you are absolutely ignorant towards hardware errors (continuing to using your faulty notebook, pretending to repair it (repeatedly??? - that is not a repair!) to continuously connecting/disconnecting your memory stick - that is like driving a car with used up brake pads down to bare metal.
Basically you can judge the abilities of people and their chance of performing a recovery already by their error description. Unfortunately you have no clue what you are doing and you don't understand my hints.
This is not to put you down, this is an unfortunately negative feedback to prevent you from destroying your massively important files.
Hollow77Shots
Hi recuperation,
Thank you for your feedback. I appreciate it, but the toxicity levels on your side are unbelievable.
You clearly misunderstood what I wrote overall, didn't understand the issues and believe I came from a bad place to this all. I was actually writing a full reply but figured out mid-way that I don't have to comply with this type of behavior.
Thank you for your time and have a great day.
Hollow
Hollow
