Photorec: how to skip unknown marker
Robbyccyip
#1 Post by Robbyccyip »
I am using the lates WIP 7.2 photo rec. I am very happy with the product. But I am having problem that cause my photo recovery take forever to run. I looked into the log and found the reason stuck at 40 to 50% because photorec repeatedly scan the same partition with unknown marker.
Every time finish recover a new photo, it went back and search the unknown marker, then it repeats and repeats.
I wonder if I can skip the unknown marker and how in qphotorec or photorec, so that it can move on the ones that can be recovered.
Many thanks. I love your product as there are many scam software out there.
Recovered pictures / recup _ dir . 94 / f918353814 . jpg unknown marker Ox19 at Ox / Recovered pictures / recup _ dir . 94 / 4946331346 . jpg unknown marker Ox11 at Ox / Recovered pictures / recup _ dir . 94 / f954317748 . jpg unknown marker Ox8f at Ox / Recovered pictures / recup _ dir . 94 / 1976075336 . jpg unknown marker Oxf8 at Ox / Recovered pictures / recup _ dir . 94 / f976102890 . jpg unknown marker Oxb9 at Ox / Recovered pictures / recup _ dir . 94 / f976246600 . jpg unknown marker Oxb4 at Ox : / Recovered pictures / recup _ dir . 94 / f977007760 . jpg unknown marker Oxdc at Ox3 / Recovered pictures / recup _ dir . 94 / 1991192642 . jpg unknown marker Oxd2 at Ox3 / Recovered pictures / recup _ dir . 94 / 6997394012 . jpg unknown marker Oxd5 at Ox3 - / Recovered pictures / recup _ dir . 94 / 1997802422 . jpg unknown marker Oxdo at Ox3 : / Recovered pictures / recup _ dir . 94 / 1998604098 . jpg unknown marker Oxd3 at 0x3 : / Recovered pictures / recup _ dir . 94 / 1998614842 . jpg unknown marker Oxd3 at Ox3 : / Recovered pictures / recup _ dir . 94 / f999133918 . jpg unknown marker Oxf8 at Ox3 : / Recovered pictures / recup _ dir . 94 / f999236874 . jpg unknown marker Oxf3 at Ox3 : / Recovered pictures / recup _ dir . 94 / f999257018 . jpg unknown marker Oxd7 at Ox3 : / Recovered pictures / recup _ dir . 94 / f1008682208 _ ftyp . mov 1008682208 - 10086878 : / Recovered pictures / recup _ dir . 94 / f918353814 . jpg unknown marker Ox19 at Ox3 : / Recovered pictures / recup _ dir . 94 / 1946331346 . jpg unknown marker Ox11 at Ox3 : / Recovered pictures / recup _ dir . 94 / f954317748 . jpg unknown marker Ox8f at Ox3 : / Recovered pictures / recup _ dir . 94 / 1976075336 . jpg unknown marker Oxf8 at 0x3 : / Recovered pictures / recup _ dir . 94 / 1976102890 . jpg unknown marker Oxb9 at Ox3 1 : / Recovered pictures / recup _ dir . 94 / f976246600 . jpg unknown marker Oxb4 at 0x3 7 : / Recovered pictures / recup _ dir . 94 / f977007760 . jpg unknown marker Oxdc at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f991192642 . jpg unknown marker Oxd2 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f997394012 . jpg unknown marker Oxd5 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / 6997802422 . jpg unknown marker Oxdo at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f998604098 . jpg unknown marker Oxd3 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f998614842 . jpg unknown marker Oxd3 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f999133918 . jpg unknown marker Oxf8 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f999236874 . jpg unknown marker Oxf3 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / 1999257018 . jpg unknown marker Oxd7 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f1008687872 . jpg 1008687872 - 100869171 Y : / Recovered pictures / recup _ dir . 94 / f918353814 . jpg unknown marker Ox19 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f946331346 . jpg unknown marker 0x11 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f954317748 . jpg unknown marker Ox8f at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f976075336 . jpg unknown marker Oxf8 at 0x3 Y : / Recovered pictures / recup dir . 94 / f976102890 . jpg unknown marker Oxb9 at Ox3 Y : / Recovered pictures / recup dir . 94 / 1976246600 . jpg unknown marker Oxb4 at Ox3 Y : / Recovered pictures / recup dir . 94 / 1977007760 . jpg unknown marker Oxdc at Ox3 Y : / Recovered pictures / recup dir . 94 / 1991192642 . jpg unknown marker Oxd2 at Ox3 Y : / Recovered pictures / recup dir . 94 / 1997394012 . jpg unknown marker Oxd5 at Ox3 Y : / Recovered pictures / recup dir . 94 / 6997802422 . jpg unknown marker Oxdo at Ox3 Y : / Recovered pictures / recup dir . 94 / 1998604098 . jpg unknown marker Oxd3 at Ox3 Y : / Recovered pictures / recup dir . 94 / 1998614842 . jpg unknown marker Oxd3 at Ox3 Y : / Recovered pictures / recup dir . 94 / 1999133918 . jpg unknown marker Oxf8 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f999236874 . jpg unknown marker Oxf3 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / 1999257018 . jpg unknown marker Oxd7 at Ox3 Y : / Recovered pictures / recup dir . 94 / 61008691720 ftyp . mov 1008691720 - 1008697205 Y : / Recovered pictures / recup _ dir . 94 / f918353814 . jpg unknown marker Ox19 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f946331346 . jpg unknown marker Ox11 at 0x3 Y : / Recovered pictures / recup _ dir . 94 / f954317748 . jpg unknown marker Ox8f at Ox3 Y : / Recovered pictures / recup dir . 94 / f976075336 . jpg unknown marker Oxf8 at Ox3 Y : / Recovered pictures / recup _ dir . 94 / f
Re: Photorec: how to skip unknown marker
If it takes too much time, a workaround is to manually edit (after a backup) the photorec.ses file and remove the sector range where the bad file is present.
Once it's done, restart PhotoRec and resume the recovery.
Robbyccyip
#3 Post by Robbyccyip »
Thanks, one last question. If I must scan the whole disk, can I still select the where I left off if I stop it now. Because most of the example in the forum is scanning a specific partition. In my case, my partition is destroyed by windows boot disk.
Thanks
Robbyccyip
#4 Post by Robbyccyip »
# 1586738168 \ \ . \ PhysicalDrive3 partition _ gpt , 255 , blocksize , 1024 , fileopt , options , paranoid , keep c orrupted _ file no , wholespace , search , status = ext2 off , 939829934 , inter 0 - 2063 2072 - 32185 32194 - 33279 33474 - 33535 33538 - 33599 33632 - 33727 33730 - 33791 41012 - 41023 48600 - 48639 52520 - 52543 57180 -
i want to confirm the following (in order to skip to where I left off and skip unknown marker):
Replace 939829934 with latest recovered f* filename?
And the range at the bottom of ses file remains the same?
Many many thanks
