The partition can't be recovered
testingdisks
#1 Post by testingdisks »
Hello folks. Great piece of technology--thanks.
I believe I have the same problem described in this thread: viewtopic.php?t=9575
I have a 1TB drive with 1 NTFS partition B (931GiB) "expanded" to fill disk via Windows Disk Management, resulted in disk becoming "dynamic" and creating second NTFS partition A (approximately 99MiB or 99MB, according to my recollection).
I deleted volume of partition A, and it took partition B with it. This was my mistake.
I am attempting to recover partition B, 931 GiB, containing my data, testdisk identifies the partition but says:
The harddisk (1000 GB / 931 GiB) seems too small! (< 1000 GB / 931 GiB)
I don't understand the answer given in the linked thread above:
After Quick Search, try Deeper Search.
Use the arrow keys to switch the partition B from D(eleted) to P(rimary).
On the next screen, if the partitions A and B are correctly listed, choose Write, confirm, Quit and restart your computer.
I've used the same partition naming scheme used by author in linked thread. Partition "B" is the one testdisk is saying unrecoverable, and as a result I can not use the arrow keys to switch partition B from D(eleted) to P(rimary) because it does not appear in the list of partitions I can operate on. Only A does.
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
>* HPFS - NTFS              0  32 33    12 223 19     204800
       Enter: to continue
Thanks in advance for any assistance.
Intel
Sat Jan 29 19:18:27 2022
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499452703744
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-9YN162, S/N:S1D1LLK9, FW:CC4D
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RANX0H723011Y, FW:EMT02B6Q
Disk /dev/sdc - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - INTEL SSDSC2BW120A4, S/N:PHDA431400HL1207GN, FW:DC32
Disk /dev/sda - 1000 GB / 931 GiB - ST1000DM003-9YN162
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 12/223/20
filesystem size           1953513472
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             12 223 20 121613 118 41 1953513472 [Media]
This partition ends after the disk limits. (start=206848, size=1953513472, end=1953720319, disk end=1953525168)
file_pread(4,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(4,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
NTFS at 12/190/50
mftmirr_lcn               2
NTFS part_offset=104857088, part_size=1000198897664, sector_size=512
NTFS at 12/223/19
filesystem size           204800
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
 1 * HPFS - NTFS              0  32 33    12 223 19     204800
EFI GPT
Sat Jan 29 20:07:16 2022
Partition table type: EFI GPT
Trying alternate GPT
NTFS at 12/190/50
mftmirr_lcn               2
NTFS at 12/190/50
mftmirr_lcn               2
     MS Data                   204799 1953718270 1953513472
This partition ends after the disk limits. (start=204799, size=1953513472, end=1953718270, disk end=1953525168)
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
     MS Data                     2048     206847     204800
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
     MS Data                   206847     411646     204800
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 12/190/50
mftmirr_lcn               2
NTFS at 12/190/50
mftmirr_lcn               2
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
NTFS part_offset=105906176, part_size=1000198897664, sector_size=512
NTFS at 12/223/20
mftmirr_lcn               2
     MS Data                   206848 1953720319 1953513472 [Media]
Re: The partition can't be recovered
Please correct your posting by removing/replacing gamer speak: "IIRC". Thank you.
testingdisks
#3 Post by testingdisks »
recuperation wrote: 30 Jan 2022, 13:10 Please correct your posting by removing/replacing gamer speak: "IIRC". Thank you.
My apologies. The post has been corrected.
Did you run "deeper search"?
testingdisks
#5 Post by testingdisks »
recuperation wrote: 02 Feb 2022, 11:09 Did you run "deeper search"?
Yes. Running deeper search exposes the smaller 99 MB "NTFS partition" that I believe is the part the original NTFS partition was expanded into when it became a dynamic disk.
#6 Post by recuperation »
The difference between you and the incident linked is that your first partition has probably been a Microsoft reserved partition before the merge operation.
The other case is dealing with two partitions of the same type.
