Recovering 2 partitions on one drive
Protostar
#1 Post by Protostar »
Hey guys, recently one of my drives just gave out, the data seemed intact on the drive as i could see it all using tesktdisk, but what i did is cloned the drive to a new drive to properly recover without fear of losing the original files as i'm new to using testdisk.
I have run the analysis and a bunch of deeper searches to try get to the point of being able to write the partition tables and now I'm at this point.
It shows both of my partitions correctly with their file structures intact, but if i label them both P or a combination of P and any other label, it will show that my structure is bad, what am i doing wrong here? And if i need to back out to change any menu settings how do i get back to this partition list without having to analyse everything again (i have logs being written)
Cheers!
Re: Recovering 2 partitions on one drive
The first two partitions are overlapping. That's why you aren't allowed to write a partition table including both partitions.
If you have a log file including data of a deep search your only chance to avoid to repeat the analysis is by manually adding partitions.
You should use the "p"-key ("list files") to find out if Testdisk is able to read the partitions. If that fails try out a commercial recovery program. Using Photorec as an armaggedon tool implies loss of metadata such as file names and folder structures. Use Photorec if you have no money to pay for a commercial recovery program or if the commercials fail to provide file name and folders.
Protostar
#3 Post by Protostar »
Hey thanks for the response!
Yeah both partitions have all the files listed, can see everything in the log files too, all the filestructures are intact also so it seems good there.
So if the 2 main partitions are overlapping how is the best way to write these part tables?
I could go and pay for a commercial recov program but was just going to give testdisk a shot as ive got a clone of my drive anyway so i can experiment a bit with this!
Cheers
Protostar
#4 Post by Protostar »
recuperation wrote: 21 Jan 2023, 11:39 The first two partitions are overlapping. That's why you aren't allowed to write a partition table including both partitions.
heres a pastebin with the log (minus the file list just replaced it with //files// comment
if this can help diagnose the issue/the next steps
https://pastebin.com/VhdPckKq
#5 Post by recuperation »
Would you be so kind as to upload your logfile to this site?
You can copy it into a code section:
I am the logfile!
Thank you.
Protostar
#6 Post by Protostar »
recuperation wrote: 22 Jan 2023, 00:36 Would you be so kind as to upload your logfile to this site?
I am the logfile!
Thank you.
Sure thing!
Sat Jan 14 23:30:35 2023
TestDisk 7.2-WIP, Data Recovery Utility, November 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=8001563222016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=8001562869760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=41156608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=75438161920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive10)=114352496640
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999610265600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2199023255040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000068874240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=256059113472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=8001560772608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=750153367552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=1000186314752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=41094144
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Hitachi HDS721010CLA332, S/N:JP2940J81WJ9VV, FW:JP4OA3MA
Disk \\.\PhysicalDrive1 - 8001 GB / 7452 GiB - CHS 972801 255 63, sector size=512 - TOSHIBA MG08ADA800E, S/N:52V0A00BFCXH, FW:0101
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 970 EVO Plus 1TB, S/N:0025_3858_0143_479F., FW:2B2QEXM7
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 970 EVO 1TB, S/N:0025_385B_81B1_D76F., FW:2B2QEXE7
Disk \\.\PhysicalDrive4 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - SAMSUNG MZVPV256HDGL-00000, S/N:S1XWNYAG902517      _00000001., FW:BXW7300Q
Disk \\.\PhysicalDrive5 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 860 EVO 1TB, S/N:S3Z9NB0M303722N, FW:RVT04B6Q
Disk \\.\PhysicalDrive6 - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Crucial_CT750MX300SSD1, S/N:161412590AC1, FW:M0CR011
Disk \\.\PhysicalDrive7 - 8001 GB / 7452 GiB - CHS 972801 255 63, sector size=512 - WD My Book 25EE, S/N:7SHZT7GW, FW:4004
Disk \\.\PhysicalDrive8 - 41 MB / 39 MiB - CHS 5 255 63, sector size=512 - WIBU - CodeMeter-Stick, S/N:000001479197, FW:v1.0
Disk \\.\PhysicalDrive9 - 75 GB / 70 GiB - CHS 1146 255 63, sector size=4096 - MSFT XVDD, FW:1.0
Disk \\.\PhysicalDrive10 - 114 GB / 106 GiB - CHS 1737 255 63, sector size=4096 - MSFT XVDD, FW:1.0
Disk \\.\PhysicalDrive1 - 8001 GB / 7452 GiB - TOSHIBA MG08ADA800E
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 15628053167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 2 P MS Reserved                 2082     262177     260096 [Microsoft reserved partition]
 1 P MS LDM MetaData               34       2081       2048 [LDM metadata partition]
 3 P MS LDM Data               262178 3907029134 3906766957 [LDM data partition]
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Analyse Disk \\.\PhysicalDrive1 - 8001 GB / 7452 GiB - CHS 972801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 29/16/51
filesystem size           3172356096
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=239074816, part_size=1624246321152, sector_size=512
NTFS at 29/16/51
mftmirr_lcn               2
     MS Data                   466943 3172823038 3172356096
     NTFS, blocksize=4096, 1624 GB / 1512 GiB
NTFS at 236673/149/20
filesystem size           3067287552
mftmirr_lcn               2
     MS Data                734873600 3802161151 3067287552 [Storage]
     NTFS found using backup sector, blocksize=4096, 1570 GB / 1462 GiB
mftmirr_lcn               2
     MS Data               3802161151 6869448702 3067287552
     NTFS, blocksize=4096, 1570 GB / 1462 GiB
file_win32_pread(568,11,buffer,15628053159(972801/80/55)) read err: read after end of file
file_win32_pread(568,11,buffer,15628053162(972801/80/58)) read err: read after end of file
file_win32_pread(568,8,buffer,15628053161(972801/80/57)) read err: read after end of file
file_win32_pread(568,3,buffer,15628053167(972801/80/63)) read err: read after end of file
file_win32_pread(568,8,buffer,15628053165(972801/80/61)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053156(972801/80/52)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053157(972801/80/53)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053158(972801/80/54)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053159(972801/80/55)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053160(972801/80/56)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053162(972801/80/58)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053164(972801/80/60)) read err: read after end of file
file_win32_pread(568,14,buffer,15628053166(972801/80/62)) read err: read after end of file
$MFT has invalid magic.
ntfs_mft_load(): Failed.
dir_partition inode=5
//files//
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
 Dump : No
 Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Backup partition structure
partition_save
interface_load
Disk \\.\PhysicalDrive1 - 8001 GB / 7452 GiB - CHS 972801 255 63 Wed Jan 18 20:08:47 2023
 1 P Unknown                       34       2081       2048
 2 P Unknown                     2082     262177     260096
 3 P Unknown                   262178 3907029134 3906766957
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
interface_load
interface_load
interface_load
write!
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=15628053167 (expected 15628053167)
hdr_lba_start=34
hdr_lba_end=15628053134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=15628053167
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_table=15628053135
hdr_entries=128
hdr_entsz=128
Trying alternate GPT
interface_load
write!
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_start=34
hdr_entries=128
hdr_entsz=128
Wed Jan 18 20:18:04 2023
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - Hitachi HDS721010CLA332
Analyse Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63
Wed Jan 18 20:22:43 2023
NTFS at 0/32/33
 1 P HPFS - NTFS              0  32 33 121601  25 24 1953519616 [1TB Storage]
NTFS at 0/32/33
filesystem size           1953519616
mftmirr_lcn               2
   * HPFS - NTFS              0  32 33 121601  25 24 1953519616 [1TB Storage]
 1 * HPFS - NTFS              0  32 33 121601  25 24 1953519616 [1TB Storage]
NTFS at 0/32/33
mftmirr_lcn               2
BAD_RS LBA=3694718333 1855633
     FAT12                229985 147 48 321450 155 21 1469385703
This partition ends after the disk limits. (start=3694718333, size=1469385703, end=5164104035, disk end=1953525168)
NTFS at 121601/25/24
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
The hard disk (1000 GB / 931 GiB) seems too small! (< 2644 GB / 2462 GiB)
       5 dr-xr-xr-x     0      0         0 19-Jan-2023 00:17 .
       5 dr-xr-xr-x     0      0         0 19-Jan-2023 00:17 ..
     202 dr-xr-xr-x     0      0         0 17-Jul-2017 23:04 $RECYCLE.BIN
      39 dr-xr-xr-x     0      0         0  5-Dec-2015 17:44 FileHistory
  218758 dr-xr-xr-x     0      0         0 12-Jul-2018 14:53 MSOCache
    2821 dr-xr-xr-x     0      0         0  7-Jan-2021 05:56 OBS
      51 dr-xr-xr-x     0      0         0 28-Apr-2022 23:40 Old Laptop files
  148013 dr-xr-xr-x     0      0         0 15-Feb-2018 19:43 Recovery
  468592 dr-xr-xr-x     0      0         0 26-Sep-2022 20:30 Shadowplay
    2883 dr-xr-xr-x     0      0         0  7-Jan-2021 06:44 Sony Camera
  482404 dr-xr-xr-x     0      0         0 19-Jan-2023 00:34 SteamLibrary
      35 dr-xr-xr-x     0      0         0  1-Jul-2019 14:23 System Volume Information
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
NTFS at 29/49/21
filesystem size           839473152
mftmirr_lcn               2
     HPFS - NTFS             29  49 21 52283 249 62  839473152 [Hybrid HDD]
     NTFS, blocksize=4096, 429 GB / 400 GiB
BAD_RS LBA=2703872000 1333433
     HPFS - NTFS          168308  63 12 168309 108 63      18952
mftmirr_lcn               2
     HPFS - NTFS          45743 195 21 236673 149 20 3067287552 [Storage]
NTFS at 243201/78/13
mftmirr_lcn               2
     HPFS - NTFS          190946 132 35 243201  78 13  839473152
     NTFS found using backup sector, blocksize=4096, 429 GB / 400 GiB
     HPFS - NTFS          168308  63 12 168309 133 16      20480
//files//
//files//
NTFS at 29/16/51
mftmirr_lcn               2
NTFS at 29/49/21
mftmirr_lcn               2
BAD_RS LBA=2454780159 2578507
     FAT16 <32M           152802 254 28 366353 102 29 3430687241
BAD_RS LBA=3189381746 14842872
     HPFS - NTFS          198529 212  6 226728 136 26  453012168
NTFS at 45743/195/21
mftmirr_lcn               2
mftmirr_lcn               2
mftmirr_lcn               2
//files//
#7 Post by recuperation »
If you did not purchase your Toshiba 8 TB disk with an external housing you should run Testdisk in GPT mode. Otherwise only 2 TB out of 8 TB can be addressed by the MBR-style partition table given a sector size of 512 bytes.
If the partitions overlap and you don't know to which partition that (incorrectly) shared area belongs to, just use Testdisk to copy each of its content to another disk.
Protostar
#8 Post by Protostar »
recuperation wrote: 22 Jan 2023, 14:05 If you did not purchase your Toshiba 8 TB disk with an external housing you should run Testdisk in GPT mode. Otherwise only 2 TB out of 8 TB can be addressed by the MBR-style partition table given a sector size of 512 bytes.
The new drive is 8tb but the drive i cloned onto it is only 2tb, will re analyse in GPT mode though, and as for copying the partitions to another disk, can you point me to the right resource on how to copy the partitions each separately? been searching but not having much luck finding exactly what i need there. (unless yorue just talking about going into the partitions, selecting all files and copying the files specifically)
Thanks for the help!!
Protostar
#9 Post by Protostar »
set the files to copy now and its going through them, though would be nicer to be able to actually fix the partitions as it would be a lot faster but i can settle for this as an alternative
