Hi guys
trying to restore EXT HDD partition - i managed to install and use , it finds partition ok (so does disk utility) - i have clicked write and very quickly says need to reboot to take effect .
i reboot but still Partition will not mount or show up
i tried back to Disk Utility Mount - nothing happens
i tried first aid - failed
i tried safe mode - same as above
i tried a different Mac computer - same
the HDD is there as tried DMDE free and seems to show all files but free only seems to recover odd file -
So any help to make this partition show up again appriciated - i am not into terminal or coding but can follow or copy and paste bits no worries
thanks Mark
Help needed recover partition Mac
Re: Help needed recover partition Mac
What is "EXT HDD"? Do not use abbreviations to simplify your life and make mine bad. "HDD" is perfectly OK. But "EXT HDD" has two possible meanings.
What did you install and use?!partition - i managed to install and use
Who is "it"? Avoid pronouns!, it
Who?finds partition ok (so does disk utility) - i have clicked write and
The secret partition type you do not mention determins if TestDisk can look inside after finding it.very quickly says need to reboot to take effect .
thanks Mark
You should really make an effort so that you can be understood. If you cross-read the forum, you quickly notice which requests can be easily understood and which can not.
globalmark
Hi
Thanks for the reply - sorry if i didnt make sense - i will try answer all .
EXT HDD - means External Harddrive
I managed to install and Use - i installed (Test disk) and managed to use it as instructed
It - test disk
So i used Test disk as per instructions - as on my external Harddrive there is 2 partitions - one of which mount and one does not - however both show up on disk utility and test disk -
Using - test disk the partition that does not mount - how do i use test disk to fix it and make it mount again ???
I have tried clicking the write button which seems to work - after a couple seconds Test disk (terminal) says reboot for changes to take effect - but after restart the Harddrive partion still does not mount
SO help is needed on using test disk to mount the partion that does not mount ..
Thanks - I hope thats clearer .
cheers Mark
It - test disk
cheers Mark
TestDisk, not "Test disk" is the name of the software.
If you don't answer my questions, I can't answer yours.as per instructions - as on my external Harddrive there is 2 partitions - one of which mount and one does not - however both show up on disk utility and test disk -
I stated above:
[... The secret partition type you do not mention determines if TestDisk can look inside after finding it ...]
That means that you have to specify which partition type/file system had been installed on the unreadable partition. TestDisk comes with a very limited number of tools whose availability depends on the file system used.
Please read the enclosed manual or the online documentation. TestDisk does not mount anything with regards to your Apple operating system.
cheers Mark
globalmark
Hi
Check - Testdisk
i am not sure whats meant by secret Partition - its just a standard External Harddrive - used for a Mac
but if helps its a 2TB harddrive in GUID and each partition is 1.45gb Mac OS Extended (Journaled) which works fine
also the one that doesnt mount is
550GB Mac OS Extended (Journaled)
i have read for 2 days the step by step instructions and also forum comments as well as googled but all i can find is use Write - i cannot find how to fix this so this Partition will work .
So any help much appriciated - Thanks "recuperation"
Check - Testdisk
Your TestDisk manual came with a PDF file included thas is labeled "TestDisk.pdf".
When you clicked the entry for Macs in the download section
https://www.cgsecurity.org/Download_and ... 64.tar.bz2
there is a reference to the documentation again (which is included in the download anyway).
As there are Apple-specific instructions in there, it might be a bad idea to ignore them.
You don't need to read the manual like a novel. Reading the directory, using the search function in your PDF reader, cross-reading the content is sufficient in most cases.
Surprisingly there is a section labeled "6.6. Running TestDisk, PhotoRec under macOS". It is worth reading that section. The manual is accessible as well.
https://www.cgsecurity.org/testdisk_doc/running.html
When visiting the web site https://www.cgsecurity.org and clicking on "TestDisk"
you are lead to
which gives you an overview what TestDisk can do.
you are lead to
globalmark
Hi
thanks for the reply - i have read all of this inc most of the manual however nothing here has helped - i dont think testdisk restarts itself under sudo - but as far as i understand i did all correctly and clicked write that partition as in manual which happenned very fast 1-2 seconds then had to reboot computer for effects to take place but nothing changed .
i am trying to recover a Partition as mentioned - get this partition to Mount again -all info appears there if i use free version disk drill or other , but just doesnt mount .
so any help to make it mount would be amazing
thanks Mark
thanks Mark
Repair of possibly broken partitions is rather the exception than the rule.
Use this example to try to list your files and folders and copy them to a free disk:
If that fails try other software productes. If everything fails, use PhotoRec.
