[ Continue ] Can't be selected
DataSaver
#1 Post by DataSaver »
I can't seem to be able to select continue , i accidentally flash a Windows 10 bootable install to my SSD instead of my USB Drive. I have linux installed on the SSD , i really don't care that much for the Install as i do for the files. I think the SSD got formatted from EXT4 to NTFS
I have been running TestDisk 3 times now , and each deep scan run has taken about 3 hours , but i am unable to select Continue , each time i open the partition and i can't back out with Q as that closes everything
I just wish to select continue and not to open the partition , can someone help me ?
Image : https://ibb.co/bM9jk7mD
Test Dump :
Disk /dev/sdc - 960 GB / 894 GiB - CHS 116737 255 63
The hard disk (960 GB / 894 GiB) seems too small! (< 1440 GB / 1341 GiB)
> Linux 58305 184 56 174977 88 23 1874329600
Linux 58310 47 42 174981 206 9 1874329600
Linux 58311 20 14 174982 178 44 1874329600
Linux 58312 122 51 174984 26 18 1874329600
Linux 58313 95 23 174984 253 53 1874329600
Linux 58321 233 25 174993 136 55 1874329600
Linux 58323 145 63 174995 49 30 1874329600
Linux 58325 91 7 174996 249 37 1874329600
Linux 58329 241 25 175001 144 55 1874329600
Linux 58340 37 2 175011 195 32 1874329600
[ Continue ]
ext4 blocksize=4096 Large_file Sparse_SB Recover, 959 GB / 893 GiB
DataSaver
Re: [ Continue ] Can't be selected
#2 Post by DataSaver »
I have tried to press the down arrow , but i only get to the end of the partitions list , i can't seem to be able to select continue , tab doesn't work eater
#3 Post by recuperation »
2026 0620_image.jpg (122.87 KiB) Viewed 107362 times
Pressing the "return"-key should take you to the next screen.
DataSaver
#4 Post by DataSaver »
Thank you for telling me, I will start up testing again, I will a update in a few hours if it has worked :)
DataSaver
#5 Post by DataSaver »
The return key (enter just opens the selected first partition, it select it by default when it finishes, and I can't go don't to continue, and when I open a partition I can't close it
#6 Post by recuperation »
I can't reproduce your behaviour.
Your screen is not listed here
but I can see a similar screen after running the quick search.
After [Analyse] and [Quick Search] the only thing here is to click the return key and you should arrive at the screen where the first partition is higlighted with a green horizontal line.
Maybe you are doing something else but as you unfortunately don't bother to describe how to get to your screen I don't know what you are doing.
