recovery 3T GPT partitions
biotank
#1 Post by biotank »
I have a 3T WD green drive, and divided into 3 partitions, a little bit after a month I couldn't access my drive any more, I check with the disk manager, and all 3 partitions shows "RAW", I googled and found testdisk might be able to help me to retrieve the partitions.
1. so here is what I did, ran the testdisk_win.exe under adminstrator
2. select partition table type to "EFI GPT", and bottom of the screen also shows EFI GPT partition table is detected
3. choose the hard drive, and did a quick search
4. found 4 partitions, which is correct ( 3 formatted partition and unused partition)
now what do I do ?? I try to list the files, but error msg shows damage partition ?
3 Analyse disk.png (70.9 KiB) Viewed 7368 times
4 search menu.png (61.91 KiB) Viewed 7368 times
5 search result.png (58.41 KiB) Viewed 7368 times
biotank
Re: recovery GPT partitions
#2 Post by biotank »
also what does Number of cylinder/head mismatch
and Number of track mismatch means ?/?
biotank
Re: recovery 3T GPT partitions
#3 Post by biotank »
can anyone help ?
solitaryxsoul
#4 Post by solitaryxsoul »
cylinders and heads mismatch, so I think you would need to change the geometry. it should be under advanced.
an example of this is on the testdisk home.
biotank
#5 Post by biotank »
I end up using "R Studio" to retrieve the data, I think 90% of data were retrieved by the software
msoliman85
#6 Post by msoliman85 »
I had the same exact issue with the same hard drive. My pc had an improper shutdown after losing power, I used R - studio and I was able to retrieve 100% of the data as it exactly was. I used my other 3 TB to back the data to. I am not sure if there is away to fix the hard drive to allow it to see the file structure.
msoliman85
#7 Post by msoliman85 »
remove this post please
