Entire Flash Drive Boot Sector listed as Bad
Invisible1
#1 Post by Invisible1 »
Is it possible to recover or rebuild in some way a flash drive (8 GB - it does show the correct size and name) that shows it has no partition, and lists both the boot sector and the backup boot sector as bad? I hoped I could rebuild it with testdisk, but I don't see any way to do it. It also says the first sectors (boot code and partition information) and second sectors (cluster information) are not identical. The drive is RAW, but it seems to be in perfectly good condition otherwise, but with no boot sector. Thanks for any suggestions.
Re: Entire Flash Drive Boot Sector listed as Bad
Try TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
If it doesn't work, use PhotoRec to recover your data.
Invisible1
#3 Post by Invisible1 »
Thank you, but Advanced doesn't give me the option of Boot. It only gives the option of image creation.
I had to list it as no partition, because all the other choices gave me no options, except that there is no partition.
I did click on Type under Advanced which sent me to Boot after I put it as FAT32. I think it WAS Fat32 before it was RAW- not sure if it stays the same? Rebuild BS shows this:
If I list it as ex-Fat it shows this:
I've already used file recovery tools to recover all that it appears I can, but I really wanted the actual names on some of the files, and some other things that aren't recoverable. I really really had hoped there was a way to rewrite the boot sector, or whatever is wrong, so that I can see everything again as it was before it became RAW.I tried to attach the log, but it wouldn't allow it. I looked at disk geometry as well - is there some way I could fix it that way instead? I don't know however, what numbers to put in myself. Is there any other option?
Can you post the content of testdisk.log corresponding to FAT32 boot sector rebuild ?
Invisible1
#5 Post by Invisible1 »
Here it is:
Thu Sep 19 16:01:41 2013
OS: Windows Vista (6002) SP2
Compilation date: 2012-10-25T19:31:29
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=8086618112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=8086618112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=152430856704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=7608384000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8086618112
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WDC WD1600JS-60NCB1, S/N:2020202057202d4443574e41394d373736313738, FW:10.02E02
Disk /dev/sdb - 8086 MB / 7712 MiB - CHS 983 255 63, sector size=512 - Verbatim Store 'n' Go, FW:1.30
Disk /dev/sdb - 8086 MB / 7712 MiB - Verbatim Store 'n' Go
Partition table type: None
P Unknown 0 0 1 983 36 13 15794176
Change partition type:
P FAT32 0 0 1 983 36 13 15794176
fat32_boot_sector
Bad
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=123456, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
FAT32 at 2(0/0/3), nbr=1
FAT32 at 3(0/0/4), nbr=1
FAT32 at 4(0/0/5), nbr=1
FAT32 at 5(0/0/6), nbr=1
FAT32 at 6(0/0/7), nbr=1
FAT32 at 7(0/0/8), nbr=1
FAT32 at 8(0/0/9), nbr=1
FAT32 at 9(0/0/10), nbr=1
FAT32 at 10(0/0/11), nbr=1
FAT32 at 11(0/0/12), nbr=1
FAT32 at 12(0/0/13), nbr=1
FAT32 at 13(0/0/14), nbr=1
FAT32 at 14(0/0/15), nbr=1
FAT32 at 15(0/0/16), nbr=1
FAT32 at 16(0/0/17), nbr=1
FAT32 at 17(0/0/18), nbr=1
FAT32 at 18(0/0/19), nbr=1
FAT32 at 19(0/0/20), nbr=1
FAT32 at 20(0/0/21), nbr=1
FAT32 at 21(0/0/22), nbr=1
FAT32 at 22(0/0/23), nbr=1
FAT32 at 23(0/0/24), nbr=1
FAT32 at 24(0/0/25), nbr=1
FAT32 at 25(0/0/26), nbr=1
FAT32 at 26(0/0/27), nbr=1
FAT32 at 27(0/0/28), nbr=1
FAT32 at 28(0/0/29), nbr=1
FAT32 at 29(0/0/30), nbr=1
FAT32 at 30(0/0/31), nbr=1
FAT32 at 31(0/0/32), nbr=1
FAT32 at 32(0/0/33), nbr=2
FAT32 at 33(0/0/34), nbr=1
FAT32 at 34(0/0/35), nbr=1
FAT32 at 35(0/0/36), nbr=1
FAT32 at 36(0/0/37), nbr=1
FAT32 at 37(0/0/38), nbr=1
FAT32 at 38(0/0/39), nbr=1
FAT32 at 39(0/0/40), nbr=1
FAT32 at 40(0/0/41), nbr=1
FAT32 at 41(0/0/42), nbr=1
FAT32 at 42(0/0/43), nbr=1
FAT32 at 43(0/0/44), nbr=1
FAT32 at 44(0/0/45), nbr=1
FAT32 at 45(0/0/46), nbr=1
FAT32 at 46(0/0/47), nbr=1
FAT32 at 47(0/0/48), nbr=1
FAT32 at 48(0/0/49), nbr=1
FAT32 at 49(0/0/50), nbr=1
FAT32 at 50(0/0/51), nbr=1
FAT32 at 51(0/0/52), nbr=1
FAT32 at 52(0/0/53), nbr=1
FAT32 at 53(0/0/54), nbr=1
FAT32 at 54(0/0/55), nbr=1
FAT32 at 55(0/0/56), nbr=1
FAT32 at 56(0/0/57), nbr=1
FAT32 at 57(0/0/58), nbr=1
FAT32 at 58(0/0/59), nbr=1
FAT32 at 59(0/0/60), nbr=1
FAT32 at 60(0/0/61), nbr=1
FAT32 at 61(0/0/62), nbr=1
FAT32 at 62(0/0/63), nbr=1
FAT32 at 63(0/1/1), nbr=1
FAT32 at 64(0/1/2), nbr=1
FAT32 at 65(0/1/3), nbr=1
FAT32 at 66(0/1/4), nbr=1
FAT32 at 67(0/1/5), nbr=1
FAT32 at 68(0/1/6), nbr=1
FAT32 at 69(0/1/7), nbr=1
FAT32 at 70(0/1/8), nbr=1
FAT32 at 71(0/1/9), nbr=1
FAT32 at 72(0/1/10), nbr=1
FAT32 at 73(0/1/11), nbr=1
FAT32 at 74(0/1/12), nbr=1
FAT32 at 75(0/1/13), nbr=1
FAT32 at 76(0/1/14), nbr=1
FAT32 at 77(0/1/15), nbr=1
FAT32 at 78(0/1/16), nbr=1
FAT32 at 79(0/1/17), nbr=1
FAT32 at 80(0/1/18), nbr=1
FAT32 at 81(0/1/19), nbr=1
FAT32 at 82(0/1/20), nbr=1
FAT32 at 83(0/1/21), nbr=1
FAT32 at 84(0/1/22), nbr=1
FAT32 at 85(0/1/23), nbr=1
FAT32 at 86(0/1/24), nbr=1
FAT32 at 87(0/1/25), nbr=1
FAT32 at 88(0/1/26), nbr=1
FAT32 at 89(0/1/27), nbr=1
FAT32 at 90(0/1/28), nbr=1
FAT32 at 91(0/1/29), nbr=1
FAT32 at 92(0/1/30), nbr=1
FAT32 at 93(0/1/31), nbr=1
FAT32 at 94(0/1/32), nbr=1
FAT32 at 95(0/1/33), nbr=1
FAT32 at 96(0/1/34), nbr=1
FAT32 at 97(0/1/35), nbr=1
FAT32 at 98(0/1/36), nbr=1
FAT32 at 99(0/1/37), nbr=1
FAT32 at 100(0/1/38), nbr=1
FAT32 at 101(0/1/39), nbr=1
FAT32 at 102(0/1/40), nbr=1
FAT32 at 103(0/1/41), nbr=1
FAT32 at 104(0/1/42), nbr=1
FAT32 at 105(0/1/43), nbr=1
FAT32 at 106(0/1/44), nbr=1
FAT32 at 107(0/1/45), nbr=1
FAT32 at 108(0/1/46), nbr=1
FAT32 at 109(0/1/47), nbr=1
FAT32 at 110(0/1/48), nbr=1
FAT32 at 111(0/1/49), nbr=1
FAT32 at 112(0/1/50), nbr=1
FAT32 at 113(0/1/51), nbr=1
FAT32 at 114(0/1/52), nbr=1
FAT32 at 115(0/1/53), nbr=1
FAT32 at 116(0/1/54), nbr=1
FAT32 at 117(0/1/55), nbr=1
FAT32 at 118(0/1/56), nbr=1
FAT32 at 119(0/1/57), nbr=1
FAT32 at 120(0/1/58), nbr=1
FAT32 at 121(0/1/59), nbr=1
FAT32 at 122(0/1/60), nbr=1
FAT32 at 123(0/1/61), nbr=1
FAT32 at 124(0/1/62), nbr=1
FAT32 at 125(0/1/63), nbr=1
FAT32 at 126(0/2/1), nbr=1
FAT32 at 127(0/2/2), nbr=1
FAT32 at 128(0/2/3), nbr=1
FAT32 at 129(0/2/4), nbr=1
FAT32 at 130(0/2/5), nbr=1
FAT32 at 131(0/2/6), nbr=1
FAT32 at 132(0/2/7), nbr=1
FAT32 at 133(0/2/8), nbr=1
FAT32 at 134(0/2/9), nbr=1
FAT32 at 135(0/2/10), nbr=1
FAT32 at 136(0/2/11), nbr=1
FAT32 at 137(0/2/12), nbr=1
FAT32 at 138(0/2/13), nbr=1
FAT32 at 139(0/2/14), nbr=1
FAT32 at 140(0/2/15), nbr=1
FAT32 at 141(0/2/16), nbr=1
FAT32 at 142(0/2/17), nbr=1
FAT32 at 143(0/2/18), nbr=1
FAT32 at 144(0/2/19), nbr=1
FAT32 at 145(0/2/20), nbr=1
FAT32 at 146(0/2/21), nbr=1
FAT32 at 147(0/2/22), nbr=1
FAT32 at 148(0/2/23), nbr=1
FAT32 at 149(0/2/24), nbr=1
FAT32 at 150(0/2/25), nbr=1
FAT32 at 151(0/2/26), nbr=1
FAT32 at 152(0/2/27), nbr=1
FAT32 at 153(0/2/28), nbr=1
FAT32 at 154(0/2/29), nbr=1
FAT32 at 155(0/2/30), nbr=1
FAT32 at 156(0/2/31), nbr=1
FAT32 at 157(0/2/32), nbr=1
FAT32 at 158(0/2/33), nbr=1
FAT32 at 159(0/2/34), nbr=1
FAT32 at 160(0/2/35), nbr=1
FAT32 at 161(0/2/36), nbr=1
FAT32 at 162(0/2/37), nbr=1
FAT32 at 163(0/2/38), nbr=1
FAT32 at 164(0/2/39), nbr=1
FAT32 at 165(0/2/40), nbr=1
FAT32 at 166(0/2/41), nbr=1
FAT32 at 167(0/2/42), nbr=1
FAT32 at 168(0/2/43), nbr=1
FAT32 at 169(0/2/44), nbr=1
FAT32 at 170(0/2/45), nbr=1
FAT32 at 171(0/2/46), nbr=1
FAT32 at 172(0/2/47), nbr=1
FAT32 at 173(0/2/48), nbr=1
FAT32 at 174(0/2/49), nbr=1
FAT32 at 175(0/2/50), nbr=1
FAT32 at 176(0/2/51), nbr=1
FAT32 at 177(0/2/52), nbr=1
FAT32 at 178(0/2/53), nbr=1
FAT32 at 179(0/2/54), nbr=1
FAT32 at 180(0/2/55), nbr=1
FAT32 at 181(0/2/56), nbr=1
FAT32 at 182(0/2/57), nbr=1
FAT32 at 183(0/2/58), nbr=1
FAT32 at 184(0/2/59), nbr=1
FAT32 at 185(0/2/60), nbr=1
FAT32 at 186(0/2/61), nbr=1
FAT32 at 187(0/2/62), nbr=1
FAT32 at 188(0/2/63), nbr=1
FAT32 at 189(0/3/1), nbr=1
FAT32 at 190(0/3/2), nbr=1
FAT32 at 191(0/3/3), nbr=1
FAT32 at 192(0/3/4), nbr=1
FAT32 at 193(0/3/5), nbr=1
FAT32 at 194(0/3/6), nbr=1
FAT32 at 195(0/3/7), nbr=1
FAT32 at 196(0/3/8), nbr=1
FAT32 at 197(0/3/9), nbr=1
FAT32 at 198(0/3/10), nbr=1
FAT32 at 199(0/3/11), nbr=1
FAT32 at 200(0/3/12), nbr=1
FAT32 at 201(0/3/13), nbr=1
FAT32 at 202(0/3/14), nbr=1
FAT32 at 203(0/3/15), nbr=1
FAT32 at 204(0/3/16), nbr=1
FAT32 at 205(0/3/17), nbr=1
FAT32 at 206(0/3/18), nbr=1
FAT32 at 207(0/3/19), nbr=1
FAT32 at 208(0/3/20), nbr=1
FAT32 at 209(0/3/21), nbr=1
FAT32 at 210(0/3/22), nbr=1
FAT32 at 211(0/3/23), nbr=1
FAT32 at 212(0/3/24), nbr=1
FAT32 at 213(0/3/25), nbr=1
FAT32 at 214(0/3/26), nbr=1
FAT32 at 215(0/3/27), nbr=1
FAT32 at 216(0/3/28), nbr=1
FAT32 at 217(0/3/29), nbr=1
FAT32 at 218(0/3/30), nbr=1
FAT32 at 219(0/3/31), nbr=1
FAT32 at 220(0/3/32), nbr=1
FAT32 at 221(0/3/33), nbr=1
FAT32 at 222(0/3/34), nbr=1
FAT32 at 223(0/3/35), nbr=1
FAT32 at 224(0/3/36), nbr=1
FAT32 at 225(0/3/37), nbr=1
FAT32 at 226(0/3/38), nbr=1
FAT32 at 227(0/3/39), nbr=1
FAT32 at 228(0/3/40), nbr=1
FAT32 at 229(0/3/41), nbr=1
FAT32 at 230(0/3/42), nbr=1
FAT32 at 231(0/3/43), nbr=1
FAT32 at 232(0/3/44), nbr=1
FAT32 at 233(0/3/45), nbr=1
FAT32 at 234(0/3/46), nbr=1
FAT32 at 235(0/3/47), nbr=1
FAT32 at 236(0/3/48), nbr=1
FAT32 at 237(0/3/49), nbr=1
FAT32 at 238(0/3/50), nbr=1
FAT32 at 239(0/3/51), nbr=1
FAT32 at 240(0/3/52), nbr=1
FAT32 at 241(0/3/53), nbr=1
FAT32 at 242(0/3/54), nbr=1
FAT32 at 243(0/3/55), nbr=1
FAT32 at 244(0/3/56), nbr=1
FAT32 at 245(0/3/57), nbr=1
FAT32 at 246(0/3/58), nbr=1
FAT32 at 247(0/3/59), nbr=1
FAT32 at 248(0/3/60), nbr=1
FAT32 at 249(0/3/61), nbr=1
FAT32 at 250(0/3/62), nbr=1
FAT32 at 251(0/3/63), nbr=1
FAT32 at 252(0/4/1), nbr=1
FAT32 at 253(0/4/2), nbr=1
FAT32 at 254(0/4/3), nbr=1
FAT32 at 255(0/4/4), nbr=1
FAT32 at 256(0/4/5), nbr=1
FAT32 at 257(0/4/6), nbr=1
FAT32 at 258(0/4/7), nbr=1
FAT32 at 259(0/4/8), nbr=1
FAT32 at 260(0/4/9), nbr=1
FAT32 at 261(0/4/10), nbr=1
FAT32 at 262(0/4/11), nbr=1
FAT32 at 263(0/4/12), nbr=1
FAT32 at 264(0/4/13), nbr=1
FAT32 at 265(0/4/14), nbr=1
FAT32 at 266(0/4/15), nbr=1
FAT32 at 267(0/4/16), nbr=1
FAT32 at 268(0/4/17), nbr=1
FAT32 at 269(0/4/18), nbr=1
FAT32 at 270(0/4/19), nbr=1
FAT32 at 271(0/4/20), nbr=1
FAT32 at 272(0/4/21), nbr=1
FAT32 at 273(0/4/22), nbr=1
FAT32 at 274(0/4/23), nbr=1
FAT32 at 275(0/4/24), nbr=1
FAT32 at 276(0/4/25), nbr=1
FAT32 at 277(0/4/26), nbr=1
FAT32 at 278(0/4/27), nbr=1
FAT32 at 279(0/4/28), nbr=1
FAT32 at 280(0/4/29), nbr=1
FAT32 at 281(0/4/30), nbr=1
FAT32 at 282(0/4/31), nbr=1
FAT32 at 283(0/4/32), nbr=1
FAT32 at 284(0/4/33), nbr=1
FAT32 at 285(0/4/34), nbr=1
FAT32 at 286(0/4/35), nbr=1
FAT32 at 287(0/4/36), nbr=1
FAT32 at 288(0/4/37), nbr=1
FAT32 at 289(0/4/38), nbr=1
FAT32 at 290(0/4/39), nbr=1
FAT32 at 291(0/4/40), nbr=1
FAT32 at 292(0/4/41), nbr=1
FAT32 at 293(0/4/42), nbr=1
FAT32 at 294(0/4/43), nbr=1
FAT32 at 295(0/4/44), nbr=1
FAT32 at 296(0/4/45), nbr=1
FAT32 at 297(0/4/46), nbr=1
FAT32 at 298(0/4/47), nbr=1
FAT32 at 299(0/4/48), nbr=1
FAT32 at 300(0/4/49), nbr=1
FAT32 at 301(0/4/50), nbr=1
FAT32 at 302(0/4/51), nbr=1
FAT32 at 303(0/4/52), nbr=1
FAT32 at 304(0/4/53), nbr=1
FAT32 at 305(0/4/54), nbr=1
FAT32 at 306(0/4/55), nbr=1
FAT32 at 307(0/4/56), nbr=1
FAT32 at 308(0/4/57), nbr=1
FAT32 at 309(0/4/58), nbr=1
FAT32 at 310(0/4/59), nbr=1
FAT32 at 311(0/4/60), nbr=1
FAT32 at 312(0/4/61), nbr=1
FAT32 at 313(0/4/62), nbr=1
FAT32 at 314(0/4/63), nbr=1
FAT32 at 315(0/5/1), nbr=1
FAT32 at 316(0/5/2), nbr=1
FAT32 at 317(0/5/3), nbr=1
FAT32 at 318(0/5/4), nbr=1
FAT32 at 319(0/5/5), nbr=1
FAT32 at 320(0/5/6), nbr=1
FAT32 at 321(0/5/7), nbr=1
FAT32 at 322(0/5/8), nbr=1
FAT32 at 323(0/5/9), nbr=1
FAT32 at 324(0/5/10), nbr=1
FAT32 at 325(0/5/11), nbr=1
FAT32 at 326(0/5/12), nbr=1
FAT32 at 327(0/5/13), nbr=1
FAT32 at 328(0/5/14), nbr=1
FAT32 at 329(0/5/15), nbr=1
FAT32 at 330(0/5/16), nbr=1
FAT32 at 331(0/5/17), nbr=1
FAT32 at 332(0/5/18), nbr=1
FAT32 at 333(0/5/19), nbr=1
FAT32 at 334(0/5/20), nbr=1
FAT32 at 335(0/5/21), nbr=1
FAT32 at 336(0/5/22), nbr=1
FAT32 at 337(0/5/23), nbr=1
FAT32 at 338(0/5/24), nbr=1
FAT32 at 339(0/5/25), nbr=1
FAT32 at 340(0/5/26), nbr=1
FAT32 at 341(0/5/27), nbr=1
FAT32 at 342(0/5/28), nbr=1
FAT32 at 343(0/5/29), nbr=1
FAT32 at 344(0/5/30), nbr=1
FAT32 at 345(0/5/31), nbr=1
FAT32 at 346(0/5/32), nbr=1
FAT32 at 347(0/5/33), nbr=1
FAT32 at 348(0/5/34), nbr=1
FAT32 at 349(0/5/35), nbr=1
FAT32 at 350(0/5/36), nbr=1
FAT32 at 351(0/5/37), nbr=1
FAT32 at 352(0/5/38), nbr=1
FAT32 at 353(0/5/39), nbr=1
FAT32 at 354(0/5/40), nbr=1
FAT32 at 355(0/5/41), nbr=1
FAT32 at 356(0/5/42), nbr=1
FAT32 at 357(0/5/43), nbr=1
FAT32 at 358(0/5/44), nbr=1
FAT32 at 359(0/5/45), nbr=1
FAT32 at 360(0/5/46), nbr=1
FAT32 at 361(0/5/47), nbr=1
FAT32 at 362(0/5/48), nbr=1
FAT32 at 363(0/5/49), nbr=1
FAT32 at 364(0/5/50), nbr=1
FAT32 at 365(0/5/51), nbr=1
FAT32 at 366(0/5/52), nbr=1
FAT32 at 367(0/5/53), nbr=1
FAT32 at 368(0/5/54), nbr=1
FAT32 at 369(0/5/55), nbr=1
FAT32 at 370(0/5/56), nbr=1
FAT32 at 371(0/5/57), nbr=1
FAT32 at 372(0/5/58), nbr=1
FAT32 at 373(0/5/59), nbr=1
FAT32 at 374(0/5/60), nbr=1
FAT32 at 375(0/5/61), nbr=1
FAT32 at 376(0/5/62), nbr=1
FAT32 at 377(0/5/63), nbr=1
FAT32 at 378(0/6/1), nbr=1
FAT32 at 379(0/6/2), nbr=1
FAT32 at 380(0/6/3), nbr=1
FAT32 at 381(0/6/4), nbr=1
FAT32 at 382(0/6/5), nbr=1
FAT32 at 383(0/6/6), nbr=1
FAT32 at 384(0/6/7), nbr=1
FAT32 at 385(0/6/8), nbr=1
FAT32 at 386(0/6/9), nbr=1
FAT32 at 387(0/6/10), nbr=1
FAT32 at 388(0/6/11), nbr=1
FAT32 at 389(0/6/12), nbr=1
FAT32 at 390(0/6/13), nbr=1
FAT32 at 391(0/6/14), nbr=1
FAT32 at 392(0/6/15), nbr=1
FAT32 at 393(0/6/16), nbr=1
FAT32 at 394(0/6/17), nbr=1
FAT32 at 395(0/6/18), nbr=1
FAT32 at 396(0/6/19), nbr=1
FAT32 at 397(0/6/20), nbr=1
FAT32 at 398(0/6/21), nbr=1
FAT32 at 399(0/6/22), nbr=1
FAT32 at 400(0/6/23), nbr=1
FAT32 at 401(0/6/24), nbr=1
FAT32 at 402(0/6/25), nbr=1
FAT32 at 403(0/6/26), nbr=1
FAT32 at 404(0/6/27), nbr=1
FAT32 at 405(0/6/28), nbr=1
FAT32 at 406(0/6/29), nbr=1
FAT32 at 407(0/6/30), nbr=1
FAT32 at 408(0/6/31), nbr=1
FAT32 at 409(0/6/32), nbr=1
FAT32 at 410(0/6/33), nbr=1
FAT32 at 411(0/6/34), nbr=1
FAT32 at 412(0/6/35), nbr=1
FAT32 at 413(0/6/36), nbr=1
FAT32 at 414(0/6/37), nbr=1
FAT32 at 415(0/6/38), nbr=1
FAT32 at 416(0/6/39), nbr=1
FAT32 at 417(0/6/40), nbr=1
FAT32 at 418(0/6/41), nbr=1
FAT32 at 419(0/6/42), nbr=1
FAT32 at 420(0/6/43), nbr=1
FAT32 at 421(0/6/44), nbr=1
FAT32 at 422(0/6/45), nbr=1
FAT32 at 423(0/6/46), nbr=1
FAT32 at 424(0/6/47), nbr=1
FAT32 at 425(0/6/48), nbr=1
FAT32 at 426(0/6/49), nbr=1
FAT32 at 427(0/6/50), nbr=1
FAT32 at 428(0/6/51), nbr=1
FAT32 at 429(0/6/52), nbr=1
FAT32 at 430(0/6/53), nbr=1
FAT32 at 431(0/6/54), nbr=1
FAT32 at 432(0/6/55), nbr=1
FAT32 at 433(0/6/56), nbr=1
FAT32 at 434(0/6/57), nbr=1
FAT32 at 435(0/6/58), nbr=1
FAT32 at 436(0/6/59), nbr=1
FAT32 at 437(0/6/60), nbr=1
FAT32 at 438(0/6/61), nbr=1
FAT32 at 439(0/6/62), nbr=1
FAT32 at 440(0/6/63), nbr=1
FAT32 at 441(0/7/1), nbr=1
FAT32 at 442(0/7/2), nbr=1
FAT32 at 443(0/7/3), nbr=1
FAT32 at 444(0/7/4), nbr=1
FAT32 at 445(0/7/5), nbr=1
FAT32 at 446(0/7/6), nbr=1
FAT32 at 447(0/7/7), nbr=1
FAT32 at 448(0/7/8), nbr=1
FAT32 at 449(0/7/9), nbr=1
FAT32 at 450(0/7/10), nbr=1
FAT32 at 451(0/7/11), nbr=1
FAT32 at 452(0/7/12), nbr=1
FAT32 at 453(0/7/13), nbr=1
FAT32 at 454(0/7/14), nbr=1
FAT32 at 455(0/7/15), nbr=1
FAT32 at 456(0/7/16), nbr=1
FAT32 at 457(0/7/17), nbr=1
FAT32 at 458(0/7/18), nbr=1
FAT32 at 459(0/7/19), nbr=1
FAT32 at 460(0/7/20), nbr=1
FAT32 at 461(0/7/21), nbr=1
FAT32 at 462(0/7/22), nbr=1
FAT32 at 463(0/7/23), nbr=1
FAT32 at 464(0/7/24), nbr=1
FAT32 at 465(0/7/25), nbr=1
FAT32 at 466(0/7/26), nbr=1
FAT32 at 467(0/7/27), nbr=1
FAT32 at 468(0/7/28), nbr=1
FAT32 at 469(0/7/29), nbr=1
FAT32 at 470(0/7/30), nbr=1
FAT32 at 471(0/7/31), nbr=1
FAT32 at 472(0/7/32), nbr=1
FAT32 at 473(0/7/33), nbr=1
FAT32 at 474(0/7/34), nbr=1
FAT32 at 475(0/7/35), nbr=1
FAT32 at 476(0/7/36), nbr=1
FAT32 at 477(0/7/37), nbr=1
FAT32 at 478(0/7/38), nbr=1
FAT32 at 479(0/7/39), nbr=1
FAT32 at 480(0/7/40), nbr=1
FAT32 at 481(0/7/41), nbr=1
FAT32 at 482(0/7/42), nbr=1
FAT32 at 483(0/7/43), nbr=1
FAT32 at 484(0/7/44), nbr=1
FAT32 at 485(0/7/45), nbr=1
FAT32 at 486(0/7/46), nbr=1
FAT32 at 487(0/7/47), nbr=1
FAT32 at 488(0/7/48), nbr=1
FAT32 at 489(0/7/49), nbr=1
FAT32 at 490(0/7/50), nbr=1
FAT32 at 491(0/7/51), nbr=1
FAT32 at 492(0/7/52), nbr=1
FAT32 at 493(0/7/53), nbr=1
FAT32 at 494(0/7/54), nbr=1
FAT32 at 495(0/7/55), nbr=1
FAT32 at 496(0/7/56), nbr=1
FAT32 at 497(0/7/57), nbr=1
FAT32 at 498(0/7/58), nbr=1
FAT32 at 499(0/7/59), nbr=1
FAT32 at 500(0/7/60), nbr=1
FAT32 at 501(0/7/61), nbr=1
FAT32 at 502(0/7/62), nbr=1
FAT32 at 503(0/7/63), nbr=1
FAT32 at 504(0/8/1), nbr=1
FAT32 at 505(0/8/2), nbr=1
FAT32 at 506(0/8/3), nbr=1
FAT32 at 507(0/8/4), nbr=1
FAT32 at 508(0/8/5), nbr=1
FAT32 at 509(0/8/6), nbr=1
FAT32 at 510(0/8/7), nbr=1
FAT32 at 511(0/8/8), nbr=1
FAT32 at 512(0/8/9), nbr=1
FAT32 at 513(0/8/10), nbr=1
FAT32 at 514(0/8/11), nbr=1
FAT32 at 515(0/8/12), nbr=1
FAT32 at 516(0/8/13), nbr=1
FAT32 at 517(0/8/14), nbr=1
FAT32 at 518(0/8/15), nbr=1
FAT32 at 519(0/8/16), nbr=1
FAT32 at 520(0/8/17), nbr=1
FAT32 at 521(0/8/18), nbr=1
FAT32 at 522(0/8/19), nbr=1
FAT32 at 523(0/8/20), nbr=1
FAT32 at 524(0/8/21), nbr=1
FAT32 at 525(0/8/22), nbr=1
FAT32 at 526(0/8/23), nbr=1
FAT32 at 527(0/8/24), nbr=1
FAT32 at 528(0/8/25), nbr=1
FAT32 at 529(0/8/26), nbr=1
FAT32 at 530(0/8/27), nbr=1
FAT32 at 531(0/8/28), nbr=1
FAT32 at 532(0/8/29), nbr=1
FAT32 at 533(0/8/30), nbr=1
FAT32 at 534(0/8/31), nbr=1
FAT32 at 535(0/8/32), nbr=1
FAT32 at 536(0/8/33), nbr=1
FAT32 at 537(0/8/34), nbr=1
FAT32 at 538(0/8/35), nbr=1
FAT32 at 539(0/8/36), nbr=1
FAT32 at 540(0/8/37), nbr=1
FAT32 at 541(0/8/38), nbr=1
FAT32 at 542(0/8/39), nbr=1
FAT32 at 543(0/8/40), nbr=1
FAT32 at 544(0/8/41), nbr=1
FAT32 at 545(0/8/42), nbr=1
FAT32 at 546(0/8/43), nbr=1
FAT32 at 547(0/8/44), nbr=1
FAT32 at 548(0/8/45), nbr=1
FAT32 at 549(0/8/46), nbr=1
FAT32 at 550(0/8/47), nbr=1
FAT32 at 551(0/8/48), nbr=1
FAT32 at 552(0/8/49), nbr=1
FAT32 at 553(0/8/50), nbr=1
FAT32 at 554(0/8/51), nbr=1
FAT32 at 555(0/8/52), nbr=1
FAT32 at 556(0/8/53), nbr=1
FAT32 at 557(0/8/54), nbr=1
FAT32 at 558(0/8/55), nbr=1
FAT32 at 559(0/8/56), nbr=1
FAT32 at 560(0/8/57), nbr=1
FAT32 at 561(0/8/58), nbr=1
FAT32 at 562(0/8/59), nbr=1
FAT32 at 563(0/8/60), nbr=1
FAT32 at 564(0/8/61), nbr=1
FAT32 at 565(0/8/62), nbr=1
FAT32 at 566(0/8/63), nbr=1
FAT32 at 567(0/9/1), nbr=1
FAT32 at 568(0/9/2), nbr=1
FAT32 at 569(0/9/3), nbr=1
FAT32 at 570(0/9/4), nbr=1
FAT32 at 571(0/9/5), nbr=1
FAT32 at 572(0/9/6), nbr=1
FAT32 at 573(0/9/7), nbr=1
FAT32 at 574(0/9/8), nbr=1
FAT32 at 575(0/9/9), nbr=1
FAT32 at 576(0/9/10), nbr=1
FAT32 at 577(0/9/11), nbr=1
FAT32 at 578(0/9/12), nbr=1
FAT32 at 579(0/9/13), nbr=1
FAT32 at 580(0/9/14), nbr=1
FAT32 at 581(0/9/15), nbr=1
FAT32 at 582(0/9/16), nbr=1
FAT32 at 583(0/9/17), nbr=1
FAT32 at 584(0/9/18), nbr=1
FAT32 at 585(0/9/19), nbr=1
FAT32 at 586(0/9/20), nbr=1
FAT32 at 587(0/9/21), nbr=1
FAT32 at 588(0/9/22), nbr=1
FAT32 at 589(0/9/23), nbr=1
FAT32 at 590(0/9/24), nbr=1
FAT32 at 591(0/9/25), nbr=1
FAT32 at 592(0/9/26), nbr=1
FAT32 at 593(0/9/27), nbr=1
FAT32 at 594(0/9/28), nbr=1
FAT32 at 595(0/9/29), nbr=1
FAT32 at 596(0/9/30), nbr=1
FAT32 at 597(0/9/31), nbr=1
FAT32 at 598(0/9/32), nbr=1
FAT32 at 599(0/9/33), nbr=1
FAT32 at 600(0/9/34), nbr=1
FAT32 at 601(0/9/35), nbr=1
FAT32 at 602(0/9/36), nbr=1
FAT32 at 603(0/9/37), nbr=1
FAT32 at 604(0/9/38), nbr=1
FAT32 at 605(0/9/39), nbr=1
FAT32 at 606(0/9/40), nbr=1
FAT32 at 607(0/9/41), nbr=1
FAT32 at 608(0/9/42), nbr=1
FAT32 at 609(0/9/43), nbr=1
FAT32 at 610(0/9/44), nbr=1
FAT32 at 611(0/9/45), nbr=1
FAT32 at 612(0/9/46), nbr=1
FAT32 at 613(0/9/47), nbr=1
FAT32 at 614(0/9/48), nbr=1
FAT32 at 615(0/9/49), nbr=1
FAT32 at 616(0/9/50), nbr=1
FAT32 at 617(0/9/51), nbr=1
FAT32 at 618(0/9/52), nbr=1
FAT32 at 619(0/9/53), nbr=1
FAT32 at 620(0/9/54), nbr=1
FAT32 at 621(0/9/55), nbr=1
FAT32 at 622(0/9/56), nbr=1
FAT32 at 623(0/9/57), nbr=1
FAT32 at 624(0/9/58), nbr=1
FAT32 at 625(0/9/59), nbr=1
FAT32 at 626(0/9/60), nbr=1
FAT32 at 627(0/9/61), nbr=1
FAT32 at 628(0/9/62), nbr=1
FAT32 at 629(0/9/63), nbr=1
FAT32 at 630(0/10/1), nbr=1
FAT32 at 631(0/10/2), nbr=1
FAT32 at 632(0/10/3), nbr=1
FAT32 at 633(0/10/4), nbr=1
FAT32 at 634(0/10/5), nbr=1
FAT32 at 635(0/10/6), nbr=1
FAT32 at 636(0/10/7), nbr=1
FAT32 at 637(0/10/8), nbr=1
FAT32 at 638(0/10/9), nbr=1
FAT32 at 639(0/10/10), nbr=1
FAT32 at 640(0/10/11), nbr=1
FAT32 at 641(0/10/12), nbr=1
FAT32 at 642(0/10/13), nbr=1
FAT32 at 643(0/10/14), nbr=1
FAT32 at 644(0/10/15), nbr=1
FAT32 at 645(0/10/16), nbr=1
FAT32 at 646(0/10/17), nbr=1
FAT32 at 647(0/10/18), nbr=1
FAT32 at 648(0/10/19), nbr=1
FAT32 at 649(0/10/20), nbr=1
FAT32 at 650(0/10/21), nbr=1
FAT32 at 651(0/10/22), nbr=1
FAT32 at 652(0/10/23), nbr=1
FAT32 at 653(0/10/24), nbr=1
FAT32 at 654(0/10/25), nbr=1
FAT32 at 655(0/10/26), nbr=1
FAT32 at 656(0/10/27), nbr=1
FAT32 at 657(0/10/28), nbr=1
FAT32 at 658(0/10/29), nbr=1
FAT32 at 659(0/10/30), nbr=1
FAT32 at 660(0/10/31), nbr=1
FAT32 at 661(0/10/32), nbr=1
FAT32 at 662(0/10/33), nbr=1
FAT32 at 663(0/10/34), nbr=1
FAT32 at 664(0/10/35), nbr=1
FAT32 at 665(0/10/36), nbr=1
FAT32 at 666(0/10/37), nbr=1
FAT32 at 667(0/10/38), nbr=1
FAT32 at 668(0/10/39), nbr=1
FAT32 at 669(0/10/40), nbr=1
FAT32 at 670(0/10/41), nbr=1
FAT32 at 671(0/10/42), nbr=1
FAT32 at 672(0/10/43), nbr=1
FAT32 at 673(0/10/44), nbr=1
FAT32 at 674(0/10/45), nbr=1
FAT32 at 675(0/10/46), nbr=1
FAT32 at 676(0/10/47), nbr=1
FAT32 at 677(0/10/48), nbr=1
FAT32 at 678(0/10/49), nbr=1
FAT32 at 679(0/10/50), nbr=1
FAT32 at 680(0/10/51), nbr=1
FAT32 at 681(0/10/52), nbr=1
FAT32 at 682(0/10/53), nbr=1
FAT32 at 683(0/10/54), nbr=1
FAT32 at 684(0/10/55), nbr=1
FAT32 at 685(0/10/56), nbr=1
FAT32 at 686(0/10/57), nbr=1
FAT32 at 687(0/10/58), nbr=1
FAT32 at 688(0/10/59), nbr=1
FAT32 at 689(0/10/60), nbr=1
FAT32 at 690(0/10/61), nbr=1
FAT32 at 691(0/10/62), nbr=1
FAT32 at 692(0/10/63), nbr=1
FAT32 at 693(0/11/1), nbr=1
FAT32 at 694(0/11/2), nbr=1
FAT32 at 695(0/11/3), nbr=1
FAT32 at 696(0/11/4), nbr=1
FAT32 at 697(0/11/5), nbr=1
FAT32 at 698(0/11/6), nbr=1
FAT32 at 699(0/11/7), nbr=1
FAT32 at 700(0/11/8), nbr=1
FAT32 at 701(0/11/9), nbr=1
FAT32 at 702(0/11/10), nbr=1
FAT32 at 703(0/11/11), nbr=1
FAT32 at 704(0/11/12), nbr=1
FAT32 at 705(0/11/13), nbr=1
FAT32 at 706(0/11/14), nbr=1
FAT32 at 707(0/11/15), nbr=1
FAT32 at 708(0/11/16), nbr=1
FAT32 at 709(0/11/17), nbr=1
FAT32 at 710(0/11/18), nbr=1
FAT32 at 711(0/11/19), nbr=1
FAT32 at 712(0/11/20), nbr=1
FAT32 at 713(0/11/21), nbr=1
FAT32 at 714(0/11/22), nbr=1
FAT32 at 715(0/11/23), nbr=1
FAT32 at 716(0/11/24), nbr=1
FAT32 at 717(0/11/25), nbr=1
FAT32 at 718(0/11/26), nbr=1
FAT32 at 719(0/11/27), nbr=1
FAT32 at 720(0/11/28), nbr=1
FAT32 at 721(0/11/29), nbr=1
FAT32 at 722(0/11/30), nbr=1
FAT32 at 723(0/11/31), nbr=1
FAT32 at 724(0/11/32), nbr=1
FAT32 at 725(0/11/33), nbr=1
FAT32 at 726(0/11/34), nbr=1
FAT32 at 727(0/11/35), nbr=1
FAT32 at 728(0/11/36), nbr=1
FAT32 at 729(0/11/37), nbr=1
FAT32 at 730(0/11/38), nbr=1
FAT32 at 731(0/11/39), nbr=1
FAT32 at 732(0/11/40), nbr=1
FAT32 at 733(0/11/41), nbr=1
FAT32 at 734(0/11/42), nbr=1
FAT32 at 735(0/11/43), nbr=1
FAT32 at 736(0/11/44), nbr=1
FAT32 at 737(0/11/45), nbr=1
FAT32 at 738(0/11/46), nbr=1
FAT32 at 739(0/11/47), nbr=1
FAT32 at 740(0/11/48), nbr=1
FAT32 at 741(0/11/49), nbr=1
FAT32 at 742(0/11/50), nbr=1
FAT32 at 743(0/11/51), nbr=1
FAT32 at 744(0/11/52), nbr=1
FAT32 at 745(0/11/53), nbr=1
FAT32 at 746(0/11/54), nbr=1
FAT32 at 747(0/11/55), nbr=1
FAT32 at 748(0/11/56), nbr=1
FAT32 at 749(0/11/57), nbr=1
FAT32 at 750(0/11/58), nbr=1
FAT32 at 751(0/11/59), nbr=1
FAT32 at 752(0/11/60), nbr=1
FAT32 at 753(0/11/61), nbr=1
FAT32 at 754(0/11/62), nbr=1
FAT32 at 755(0/11/63), nbr=1
FAT32 at 756(0/12/1), nbr=1
FAT32 at 757(0/12/2), nbr=1
FAT32 at 758(0/12/3), nbr=1
FAT32 at 759(0/12/4), nbr=1
FAT32 at 760(0/12/5), nbr=1
FAT32 at 761(0/12/6), nbr=1
FAT32 at 762(0/12/7), nbr=1
FAT32 at 763(0/12/8), nbr=1
FAT32 at 764(0/12/9), nbr=1
FAT32 at 765(0/12/10), nbr=1
FAT32 at 766(0/12/11), nbr=1
FAT32 at 767(0/12/12), nbr=1
FAT32 at 768(0/12/13), nbr=1
FAT32 at 769(0/12/14), nbr=1
FAT32 at 770(0/12/15), nbr=1
FAT32 at 771(0/12/16), nbr=1
FAT32 at 772(0/12/17), nbr=1
FAT32 at 773(0/12/18), nbr=1
FAT32 at 774(0/12/19), nbr=1
FAT32 at 775(0/12/20), nbr=1
FAT32 at 776(0/12/21), nbr=1
FAT32 at 777(0/12/22), nbr=1
FAT32 at 778(0/12/23), nbr=1
FAT32 at 779(0/12/24), nbr=1
FAT32 at 780(0/12/25), nbr=1
FAT32 at 781(0/12/26), nbr=1
FAT32 at 782(0/12/27), nbr=1
FAT32 at 783(0/12/28), nbr=1
FAT32 at 784(0/12/29), nbr=1
FAT32 at 785(0/12/30), nbr=1
FAT32 at 786(0/12/31), nbr=1
FAT32 at 787(0/12/32), nbr=1
FAT32 at 788(0/12/33), nbr=1
FAT32 at 789(0/12/34), nbr=1
FAT32 at 790(0/12/35), nbr=1
FAT32 at 791(0/12/36), nbr=1
FAT32 at 792(0/12/37), nbr=1
FAT32 at 793(0/12/38), nbr=1
FAT32 at 794(0/12/39), nbr=1
FAT32 at 795(0/12/40), nbr=1
FAT32 at 796(0/12/41), nbr=1
FAT32 at 797(0/12/42), nbr=1
FAT32 at 798(0/12/43), nbr=1
FAT32 at 799(0/12/44), nbr=1
FAT32 at 800(0/12/45), nbr=1
FAT32 at 801(0/12/46), nbr=1
FAT32 at 802(0/12/47), nbr=1
FAT32 at 803(0/12/48), nbr=1
FAT32 at 804(0/12/49), nbr=1
FAT32 at 805(0/12/50), nbr=1
FAT32 at 806(0/12/51), nbr=1
FAT32 at 807(0/12/52), nbr=1
FAT32 at 808(0/12/53), nbr=1
FAT32 at 809(0/12/54), nbr=1
FAT32 at 810(0/12/55), nbr=1
FAT32 at 811(0/12/56), nbr=1
FAT32 at 812(0/12/57), nbr=1
FAT32 at 813(0/12/58), nbr=1
FAT32 at 814(0/12/59), nbr=1
FAT32 at 815(0/12/60), nbr=1
FAT32 at 816(0/12/61), nbr=1
FAT32 at 817(0/12/62), nbr=1
FAT32 at 818(0/12/63), nbr=1
FAT32 at 819(0/13/1), nbr=1
FAT32 at 820(0/13/2), nbr=1
FAT32 at 821(0/13/3), nbr=1
FAT32 at 822(0/13/4), nbr=1
FAT32 at 823(0/13/5), nbr=1
FAT32 at 824(0/13/6), nbr=1
FAT32 at 825(0/13/7), nbr=1
FAT32 at 826(0/13/8), nbr=1
FAT32 at 827(0/13/9), nbr=1
FAT32 at 828(0/13/10), nbr=1
FAT32 at 829(0/13/11), nbr=1
FAT32 at 830(0/13/12), nbr=1
FAT32 at 831(0/13/13), nbr=1
FAT32 at 832(0/13/14), nbr=1
FAT32 at 833(0/13/15), nbr=1
FAT32 at 834(0/13/16), nbr=1
FAT32 at 835(0/13/17), nbr=1
FAT32 at 836(0/13/18), nbr=1
FAT32 at 837(0/13/19), nbr=1
FAT32 at 838(0/13/20), nbr=1
FAT32 at 839(0/13/21), nbr=1
FAT32 at 840(0/13/22), nbr=1
FAT32 at 841(0/13/23), nbr=1
FAT32 at 842(0/13/24), nbr=1
FAT32 at 843(0/13/25), nbr=1
FAT32 at 844(0/13/26), nbr=1
FAT32 at 845(0/13/27), nbr=1
FAT32 at 846(0/13/28), nbr=1
FAT32 at 847(0/13/29), nbr=1
FAT32 at 848(0/13/30), nbr=1
FAT32 at 849(0/13/31), nbr=1
FAT32 at 850(0/13/32), nbr=1
FAT32 at 851(0/13/33), nbr=1
FAT32 at 852(0/13/34), nbr=1
FAT32 at 853(0/13/35), nbr=1
FAT32 at 854(0/13/36), nbr=1
FAT32 at 855(0/13/37), nbr=1
FAT32 at 856(0/13/38), nbr=1
FAT32 at 857(0/13/39), nbr=1
FAT32 at 858(0/13/40), nbr=1
FAT32 at 859(0/13/41), nbr=1
FAT32 at 860(0/13/42), nbr=1
FAT32 at 861(0/13/43), nbr=1
FAT32 at 862(0/13/44), nbr=1
FAT32 at 863(0/13/45), nbr=1
FAT32 at 864(0/13/46), nbr=1
FAT32 at 865(0/13/47), nbr=1
FAT32 at 866(0/13/48), nbr=1
FAT32 at 867(0/13/49), nbr=1
FAT32 at 868(0/13/50), nbr=1
FAT32 at 869(0/13/51), nbr=1
FAT32 at 870(0/13/52), nbr=1
FAT32 at 871(0/13/53), nbr=1
FAT32 at 872(0/13/54), nbr=1
FAT32 at 873(0/13/55), nbr=1
FAT32 at 874(0/13/56), nbr=1
FAT32 at 875(0/13/57), nbr=1
FAT32 at 876(0/13/58), nbr=1
FAT32 at 877(0/13/59), nbr=1
FAT32 at 878(0/13/60), nbr=1
FAT32 at 879(0/13/61), nbr=1
FAT32 at 880(0/13/62), nbr=1
FAT32 at 881(0/13/63), nbr=1
FAT32 at 882(0/14/1), nbr=1
FAT32 at 883(0/14/2), nbr=1
FAT32 at 884(0/14/3), nbr=1
FAT32 at 885(0/14/4), nbr=1
FAT32 at 886(0/14/5), nbr=1
FAT32 at 887(0/14/6), nbr=1
FAT32 at 888(0/14/7), nbr=1
FAT32 at 889(0/14/8), nbr=1
FAT32 at 890(0/14/9), nbr=1
FAT32 at 891(0/14/10), nbr=1
FAT32 at 892(0/14/11), nbr=1
FAT32 at 893(0/14/12), nbr=1
FAT32 at 894(0/14/13), nbr=1
FAT32 at 895(0/14/14), nbr=1
FAT32 at 896(0/14/15), nbr=1
FAT32 at 897(0/14/16), nbr=1
FAT32 at 898(0/14/17), nbr=1
FAT32 at 899(0/14/18), nbr=1
FAT32 at 900(0/14/19), nbr=1
FAT32 at 901(0/14/20), nbr=1
FAT32 at 902(0/14/21), nbr=1
FAT32 at 903(0/14/22), nbr=1
FAT32 at 904(0/14/23), nbr=1
FAT32 at 905(0/14/24), nbr=1
FAT32 at 906(0/14/25), nbr=1
FAT32 at 907(0/14/26), nbr=1
FAT32 at 908(0/14/27), nbr=1
FAT32 at 909(0/14/28), nbr=1
FAT32 at 910(0/14/29), nbr=1
FAT32 at 911(0/14/30), nbr=1
FAT32 at 912(0/14/31), nbr=1
FAT32 at 913(0/14/32), nbr=1
FAT32 at 914(0/14/33), nbr=1
FAT32 at 915(0/14/34), nbr=1
FAT32 at 916(0/14/35), nbr=1
FAT32 at 917(0/14/36), nbr=1
FAT32 at 918(0/14/37), nbr=1
FAT32 at 919(0/14/38), nbr=1
FAT32 at 920(0/14/39), nbr=1
FAT32 at 921(0/14/40), nbr=1
FAT32 at 922(0/14/41), nbr=1
FAT32 at 923(0/14/42), nbr=1
FAT32 at 924(0/14/43), nbr=1
FAT32 at 925(0/14/44), nbr=1
FAT32 at 926(0/14/45), nbr=1
FAT32 at 927(0/14/46), nbr=1
FAT32 at 928(0/14/47), nbr=1
FAT32 at 929(0/14/48), nbr=1
FAT32 at 930(0/14/49), nbr=1
FAT32 at 931(0/14/50), nbr=1
FAT32 at 932(0/14/51), nbr=1
FAT32 at 933(0/14/52), nbr=1
FAT32 at 934(0/14/53), nbr=1
FAT32 at 935(0/14/54), nbr=1
FAT32 at 936(0/14/55), nbr=1
FAT32 at 937(0/14/56), nbr=1
FAT32 at 938(0/14/57), nbr=1
FAT32 at 939(0/14/58), nbr=1
FAT32 at 940(0/14/59), nbr=1
FAT32 at 941(0/14/60), nbr=1
FAT32 at 942(0/14/61), nbr=1
FAT32 at 943(0/14/62), nbr=1
FAT32 at 944(0/14/63), nbr=1
FAT32 at 945(0/15/1), nbr=1
FAT32 at 946(0/15/2), nbr=1
FAT32 at 947(0/15/3), nbr=1
FAT32 at 948(0/15/4), nbr=1
FAT32 at 949(0/15/5), nbr=1
FAT32 at 950(0/15/6), nbr=1
FAT32 at 951(0/15/7), nbr=1
FAT32 at 952(0/15/8), nbr=1
FAT32 at 953(0/15/9), nbr=1
FAT32 at 954(0/15/10), nbr=1
FAT32 at 955(0/15/11), nbr=1
FAT32 at 956(0/15/12), nbr=1
FAT32 at 957(0/15/13), nbr=1
FAT32 at 958(0/15/14), nbr=1
FAT32 at 959(0/15/15), nbr=1
FAT32 at 960(0/15/16), nbr=1
FAT32 at 961(0/15/17), nbr=1
FAT32 at 962(0/15/18), nbr=1
FAT32 at 963(0/15/19), nbr=1
FAT32 at 964(0/15/20), nbr=1
FAT32 at 965(0/15/21), nbr=1
FAT32 at 966(0/15/22), nbr=1
FAT32 at 967(0/15/23), nbr=1
FAT32 at 968(0/15/24), nbr=1
FAT32 at 969(0/15/25), nbr=1
FAT32 at 970(0/15/26), nbr=1
FAT32 at 971(0/15/27), nbr=1
FAT32 at 972(0/15/28), nbr=1
FAT32 at 973(0/15/29), nbr=1
FAT32 at 974(0/15/30), nbr=1
FAT32 at 975(0/15/31), nbr=1
FAT32 at 976(0/15/32), nbr=1
FAT32 at 977(0/15/33), nbr=1
FAT32 at 978(0/15/34), nbr=1
FAT32 at 979(0/15/35), nbr=1
FAT32 at 980(0/15/36), nbr=1
FAT32 at 981(0/15/37), nbr=1
FAT32 at 982(0/15/38), nbr=1
FAT32 at 983(0/15/39), nbr=1
FAT32 at 984(0/15/40), nbr=1
FAT32 at 985(0/15/41), nbr=1
FAT32 at 986(0/15/42), nbr=1
FAT32 at 987(0/15/43), nbr=1
FAT32 at 988(0/15/44), nbr=1
FAT32 at 989(0/15/45), nbr=1
FAT32 at 990(0/15/46), nbr=1
FAT32 at 991(0/15/47), nbr=1
FAT32 at 992(0/15/48), nbr=1
FAT32 at 993(0/15/49), nbr=1
FAT32 at 994(0/15/50), nbr=1
FAT32 at 995(0/15/51), nbr=1
FAT32 at 996(0/15/52), nbr=1
FAT32 at 997(0/15/53), nbr=1
FAT32 at 998(0/15/54), nbr=1
FAT32 at 999(0/15/55), nbr=1
FAT32 at 1000(0/15/56), nbr=1
FAT32 at 122829(7/164/43), nbr=1
FAT32 at 96805(6/6/38), nbr=3
FAT32 at 95326(5/238/8), nbr=12
FAT32 at 94310(5/221/63), nbr=8
FAT32 at 91226(5/173/3), nbr=11
FAT32 at 90514(5/161/47), nbr=6
FAT32 at 89069(5/138/51), nbr=11
FAT32 at 88740(5/133/37), nbr=2
FAT32 at 84040(5/58/62), nbr=36
FAT32 at 79679(4/244/48), nbr=25
FAT32 at 75083(4/171/51), nbr=29
FAT32 at 75075(4/171/43), nbr=7
FAT32 at 73572(4/147/52), nbr=11
FAT32 at 72860(4/136/33), nbr=6
FAT32 at 46840(2/233/32), nbr=2
FAT32 at 46832(2/233/24), nbr=2
FAT32 at 46824(2/233/16), nbr=2
FAT32 at 45720(2/215/46), nbr=2
FAT32 at 45712(2/215/38), nbr=2
FAT32 at 39992(2/124/51), nbr=2
FAT32 at 39984(2/124/43), nbr=2
FAT32 at 39976(2/124/35), nbr=2
FAT32 at 37624(2/87/14), nbr=2
FAT32 at 37616(2/87/6), nbr=2
FAT32 at 37608(2/86/61), nbr=2
first_fat 2, second_fat 3
FAT : 32, reserved=2, fat_length=1
fat32_boot_sector
Bad
Bad
#6 Post by cgrenier »
Try PhotoRec, enable expert mode in the Options menu, start a data recovery, answer yes when asked for FAT unformat, use the default value otherwise, maybe you will get some filenames this way.
Invisible1
#7 Post by Invisible1 »
Thanks for your help, but it didn't work. It still shows all the files as names starting with f0 followed by numbers, no matter what type of file it is. I think I have saved most of the contents of the disk by now (just with part that hasn't much chance of ever being put together properly again) so I guess if the only choice is to format it (although I WAS still hoping for a chance to get it back as it was, at least partially) I guess I have all that is left of it. Does that mean you think there really is no way to rebuild/rewrite it as it's old FAT32 self, exactly like it was? Or even partially so? I really was hoping to find a way it could be rebuilt. Is there any other option for rewriting it - or anything further I could try at all? Thanks again.
