Cant Open Filesystem. WD My book world NAS drive.
Glynbailey
#1 Post by Glynbailey »
Recently my WD My Book World Edition (white light) stopped working.
After much tinkering and not much sucess i now have it hooked up to my computer with a SATA-USB lead.
I have tried using many recovery tools but not had any luck until coming across testdisk. I have now started to get somewhere for the first time since the problem started.
The trouble i have is the set up i have at home is very limited. I only have a laptop, a 4TB NAS drive and the damaged 1TB drive in question.
Using PhotoRec i have managed to recover almost all of the original data, but there is over 100,000 files that i dont really fancy renaming.
Hopefully somebody can help me recover the drive so the original file/folder structure is intact.
the offending drive is the 1000GB and the data is on the 4th partition.
Log file reads as follows:
Tue Jul 15 17:11:40 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=126686218240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=10737418240
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST9160821AS, S/N:2020202020202020202020204d35364158423044, FW:3.CDD
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EADS-00L5B1, S/N:152D20337A0C
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10 EADS-00L5B1
Raid magic value at 4/0/1
Raid apparent size: 3919616 sectors
Raid chunk size: 0 bytes
check_MD 0.90
md0 md 0.90.0 L.Endian Raid 1: devices 0(8,1)*
Raid magic value at 248/0/1
Raid apparent size: 513920 sectors
check_MD 0.90
md1 md 0.90.0 L.Endian Raid 1: devices 0(8,2)*
Raid magic value at 280/0/1
Raid apparent size: 1975808 sectors
check_MD 0.90
md3 md 0.90.0 L.Endian Raid 1: devices 0(8,3)*
Raid magic value at 403/0/1
Raid apparent size: 1947045632 sectors
check_MD 0.90
md2 md 0.90.0 L.Endian Raid 1: devices 0(8,4)*
get_geometry_from_list_part_aux head=255 nbr=8
get_geometry_from_list_part_aux head=8 nbr=3
1 P Linux RAID 4 0 1 247 254 63 3919860 [md0]
2 P Linux RAID 248 0 1 279 254 63 514080 [md1]
3 P Linux RAID 280 0 1 402 254 63 1975995 [md3]
4 P Linux RAID 403 0 1 121600 254 63 1947045870 [md2]
recover_EXT2: s_block_group_nr=0/14, s_mnt_count=70/27, s_blocks_per_group=32768, s_inodes_per_group=16352
recover_EXT2: s_blocks_count 489952
recover_EXT2: part_size 3919616
Linux 4 0 1 247 251 8 3919616
ext3 blocksize=4096 Large file Sparse superblock, 2006 MB / 1913 MiB
Raid magic value at 247/251/9
Linux RAID 4 0 1 247 253 10 3919744 [md0]
md 0.90.0 L.Endian Raid 1: devices 0(8,1)*, 2006 MB / 1913 MiB
Linux Swap 248 0 1 279 252 13 513904
SWAP2 version 1, pagesize=4096, 263 MB / 250 MiB
Raid magic value at 279/252/30
Linux RAID 248 0 1 279 254 31 514048 [md1]
md 0.90.0 L.Endian Raid 1: devices 0(8,2)*, 263 MB / 251 MiB
recover_EXT2: s_block_group_nr=0/7, s_mnt_count=66/27, s_blocks_per_group=32768, s_inodes_per_group=15456
recover_EXT2: s_blocks_count 246976
recover_EXT2: part_size 1975808
Linux 280 0 1 402 252 2 1975808
ext3 blocksize=4096 Large file Sparse superblock, 1011 MB / 964 MiB
Raid magic value at 402/252/3
Linux RAID 280 0 1 402 254 4 1975936 [md3]
md 0.90.0 L.Endian Raid 1: devices 0(8,3)*, 1011 MB / 964 MiB
XFS Marker at 403/0/1
recover_xfs
Linux 403 0 1 121600 251 14 1947045632
XFS 6.2+ - bitmap version blocksize=4096, 996 GB / 928 GiB
Raid magic value at 121600/251/15
Linux RAID 403 0 1 121600 253 16 1947045760 [md2]
md 0.90.0 L.Endian Raid 1: devices 0(8,4)*, 996 GB / 928 GiB
file_pread(5,8,buffer,1953525203(121601/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1953525203(121601/81/36)) lseek err Invalid argument
file_pread(5,8,buffer,1953525331(121601/83/38)) lseek err Invalid argument
file_pread(5,8,buffer,1953525459(121601/85/40)) lseek err Invalid argument
file_pread(5,8,buffer,1953525587(121601/87/42)) lseek err Invalid argument
file_pread(5,8,buffer,1953525715(121601/89/44)) lseek err Invalid argument
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
get_geometry_from_list_part_aux head=255 nbr=10
get_geometry_from_list_part_aux head=8 nbr=5
Linux 4 0 1 247 254 63 3919860
Linux Swap 248 0 1 279 254 63 514080
SWAP2 version 1, pagesize=4096, 263 MB / 251 MiB
Linux 280 0 1 402 254 63 1975995
Linux 403 0 1 121600 254 63 1947045870
check_MD 0.90
check_MD 0.90
check_MD 0.90
check_MD 0.90
recover_xfs
block_group_nr 3
recover_EXT2: s_block_group_nr=3/14, s_mnt_count=0/27, s_blocks_per_group=32768, s_inodes_per_group=16352
ext3 blocksize=4096 Large file Sparse superblock Backup superblock, 2006 MB / 1913 MiB
recover_EXT2: s_block_group_nr=0/7, s_mnt_count=47/27, s_blocks_per_group=32768, s_inodes_per_group=15456
Linux 280 182 31 403 179 32 1975808
ext3 blocksize=4096 Large file Sparse superblock Recover, 1011 MB / 964 MiB
Linux 281 25 1 404 22 2 1975808
Linux 281 220 4 404 217 5 1975808
Linux 282 62 37 405 59 38 1975808
block_group_nr 3
recover_EXT2: s_block_group_nr=3/7, s_mnt_count=0/27, s_blocks_per_group=32768, s_inodes_per_group=15456
ext3 blocksize=4096 Large file Sparse superblock Backup superblock, 1011 MB / 964 MiB
recover_xfs
get_geometry_from_list_part_aux head=8 nbr=6
Linux 280 182 31 403 187 40 1976320
ext3 blocksize=4096 Large file Sparse superblock Recover, 1011 MB / 965 MiB
Linux 281 25 1 404 30 10 1976320
Linux 281 220 4 404 225 13 1976320
Linux 282 62 37 405 67 46 1976320
Couldn't open reiser filesystem
Support for this filesystem hasn't been enable during compilation.
check_MD 0.90
check_MD 0.90
check_MD 0.90
check_MD 0.90
Thank you for any help you can provide. I am sure to be donating when this is all fixed.
