hitachi 500gb is no longer accesible
kumarjay75
#1 Post by kumarjay75 »
hi ,
i have a hitachi 500 gd external drive which is inaccessible after i accidentally dban it . however the dban program only ran for 2 percent i have quickly unplugged the usd hdd.
now wheni plug it back to computer i am not able to see it under my computer however can be seen under disk management with unallocated message.
i am able to see the files on the hdd using other programs , but unable to recover .
when i run the testdisk it completes the quick search however am i stuck in window where it say the the hdd is too small and gives no further options to move forward.
i will upload the screenshort . please advise
many thanks
jay
Re: hitachi 500gb is no longer accesible
Did you use TestDisk 6.14-32bit?
Normally there should be continue displayed to move forward if you press enter?
Can you repeat your diagnose as far as possible?
So at least, I'll get infos about your current situation.
I would need infos form Analyse and Quick Search first.
But I assume if you wrote 2 percent into your file system, then it might be damaged.
But to judge your situation I'd need more infos.
kumarjay75
#3 Post by kumarjay75 »
thanks fiona , i will get the infos as soon as i have done the dignosing ,
besides i could actually see all the files and folders when icare data receovery areused . thanks for your response , iwill provide snapshots and testdisk.log
kumarjay75
#4 Post by kumarjay75 »
please find attched the result from diagnosis
thanks.
jay
result from diag
result from diag
kumarjay75
#5 Post by kumarjay75 »
Sun May 6 17:29:08 2012
TestDisk 6.14-WIP, Data Recovery Utility, April 2012
OS: Windows 7 (7600)
Compilation date: 2012-04-21T15:07:46
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
Disk /dev/sda - 120 GB / 111 GiB - CHS 15505 240 63, sector size=512 - HITACHI HTS541612J9SA00, S/N:2020202020204253443331343545344447414535, FW:SBDIC7UP
Sun May 6 17:29:53 2012
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HTS545050B9A300, S/N:801130168383
Disk /dev/sdb - 500 GB / 465 GiB - Hitachi HTS545050B9A300
Ask the user for vista mode
search_vista_part: 1
#6 Post by Fiona »
There is no partition in your partition table anymore.
Testdisk.log was aborted.
Would it be possible to run Deeper Search?
It's not Quick Search.
Reason is, I assume that your boot sector could be overridden also.
That's why I'd like to try to find your backup of the boot sector and have a try to list your data.
If Deep Search finds your partition, then press p to have a try to list your files.
Please let me know, did you see your data or an error message?
kumarjay75
#7 Post by kumarjay75 »
Hi Fiona ,
I try deeper search but test disk did not find
Any partition .
Is there anything else we could try?
Thanks
Jay
#8 Post by Fiona »
Would it be possible to zip and upload the testdisk.log?
If no partition was found, you can try to repeat Deeper Search using partition table type None.
It takes a little bit longer.
You'll find partition table type None after selecting your affected disk.
Please upload the log also.
You also can copy and paste the content of your log.
kumarjay75
#9 Post by kumarjay75 »
hi fiona ,
the attached file is a snapshot from deeper search with none option.
it has run about 24 percent now, however does the stats show any sign of successfull recovery.
thanks
jay
#10 Post by Fiona »
The scan only provides some infos about FAT-partitions.
Please let it finish.
The backup of the boot sector is normally located at the end of the partition/volume.
I assum it was a NTFS partition?
Did you only use one partition using the whole space?
