TestDisk hangs at a particular cylinder
hfeng
#1 Post by hfeng »
Need help!
I have a 2TB Seagate HDD with two partitions: F and G. Somehow all the files in G disappeared suddenly and the drive shows as "Raw" in Windows 7. But F still works fine.
Then I turned to TestDisk, which can see this partition. But a quick search found nothing, only with the warning message: the filesystem may be damaged.
Then I ran a deeper search, and Testdisk seemed to find a few bad sectors after many hours with these lines (from my memory, so it may be inaccurate)
HFS + 11387 432 ...
But it then stalled at
Analyze cylinder 16387/132755: 12%
It got stuck in this status for several hours with 0 CPU utilization and did not respond to any key. Finally I gave up and killed the process.
I then restarted the tool and ran the deeper search again. This time it scanned through the previous cylinders fairly quickly. But it again got stuck at this particular cylinder with a new error message:
Read error at 16387/222/47 (lba=247785472)
So I'm wondering what the best step to take next.
Many thanks,
hfeng
Re: TestDisk hangs at a particular cylinder
Bad sectors can cause that an OS and software hang or stop reading your data due to read errors.
In case, cloning might help.
Can you check your disk using CrystalDiskInfo first?
Please download the portable version, because the installer (exe) contains the adware open candy.
hfeng
#3 Post by hfeng »
Thanks a lot!
The screenshot is here.
I'll try the cloning step. But please pardon me for being a new user, which tool do you you recommend for carrying out this talk, TestDisk or CrystalDiskInfo?
Best,
hfeng
#4 Post by Fiona »
DD or ddrescue could help:
On Windows, Acronis True Image and sector copy could help too.
hfeng
#5 Post by hfeng »
Great! Will try that. Many thanks!
