Recovering photos after deleting partitions (diskpart clean)
MaKin
#1 Post by MaKin »
Hey guys,
after replacing my broken mainboard I did a clean install of Windows 10 (UEFI) and then had the problem that my internal drive (4TB) was not accessible for third party programmes due to missing rights. In a board post I've read about a way to clean the rights attributes via diskpart but because of my pure stupidity I read the wrong line and did a 'diskpart clean' on my drive which resulted in the deletion of the partitions and now I only see the drive as 'unallocated space'.
I had multiple partitions on the drive (1 for movies/music and 1 for backup). When running 'EaseUS Data Recovery Wizard' one lost-partition is found with movies and music but I do not care about these files. All I want to recover is my backup partition as it contains photos from the children growing up and as my notebook (with the files on the drive) was stolen - I have no copy of them. :(
After running the 'clean'-command I was asked whether I want to declare the HDD as MBR or GPT and I chose GPT. All partitions were formatted as NTFS drives before. I haven't done anything else so far as I did not want to make it worse...
I am totally frustrated and have no idea what to do. Please help me. :(
I received the following message while doing the Quick Search (I chose INTEL instead of GPT as I wasn't sure whether the partitions were MBR or GPT but now I've seen that the other drives are GPT so I assume that I should have chosen GPT here):
Disk \\.\PhysicalDrive2 - 4000 GB / 3726 GiB - CHS 486401 255 63
The harddisk (4000 GB / 3726 GiB) seems too small! (< 4559 GB / 4246 GiB)
>  FAT16 <32M           334401 149  7 554335  59 35 3533234069
   FAT32                415820 234 31 504023 166 25 1416976906
I found the folders with the photos but when copying I get the following errors:
Please select a destination where /VB and any files below will be copied.
Keys: Arrow keys to select another directory
      C when the destination is correct
Copying, please wait... 0 ok, 9581 failed
The log-file says:
Can't create file \/VB/Fotoalben/ABI/P6263101.JPG: No such file or directory
The fact that the files were found brought back some hope, I really hope they aren't lost. :(
Also I am note sure whether I should try to recover the partitions or better just try to recover the files (photos).
Re: Recovering photos after deleting partitions (diskpart cl
Once TestDisk find your lost partition, set this partition as P(rimary). On next screen if all your partitions are listed, choose Write, confirm, Quit and restart your computer. You should be able to access your files normally.
MaKin
#3 Post by MaKin »
With PhotoRec I could recover 66GB of my photos (should be everything), I just started TestDisk QuickSearch again (with GPT selected) and it is supposed to take about 2 days. :shock:
When I ran the Quick Search with 'INTEL' as the selected option, the search was interrupted, it showed the partitions afterwards but I wasn't able to recover anything. I could see the files (not sure whether it was complete) but when copying it said "File or Directory not found" or something like that. :(
Is it possible that my selection of 'INTEL' instead of 'GPT' might have been the reason?
MaKin
#4 Post by MaKin »
I attached a screenshot of how it looks so far. I never had a Mac partition. :/
MaKin
#5 Post by MaKin »
Now this Message popped up.
What should I do?
MaKin
#6 Post by MaKin »
I'm doing a deep search and so far I'm seeing this. What the heck?
Why am I shown Mac HFS? I've never used it on my Mac...
#7 Post by Fiona »
When TestDisk runs on EFI GPT, it can recognize any HFS-partition by remnants, because Intel-Mac uses the same partition table type too.
It has no significance and you should only look for your appropriate partition type (file system) like FAT32LBA or NTFS.
I've answered your german topic!
