Filesystem seems damaged
jidetiwo
#1 Post by jidetiwo »
Hi all,
Please I need help, I was lucky to come across TestDisk and PhotoRec some hours ago. I have hope that I can restore my Seagate 1TB external drive.
I got hooked with TestDisk when I got this "Can't open filesystem. Filesystem seems damaged."
So I tried PhotoRec, right now photoRec is recovering my files unto my C drive, It has created over 250 folders already with diffrent file types and strange names.
I would like to restore my Seagate 1TB to its last working state even after PhotoRec has finishes its work. Please what can do I do to achieve this.
Please see images below for perhaps helpful information...
Image 1
Image 1
Image 2
Image 2
Image 3:
Image 3:
Re: Filesystem seems damaged
Try the following: run "cmd" (right click run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter)
jidetiwo
#3 Post by jidetiwo »
Thanks. I have my Seagte 1TB data back, Chkdsk worked.
SkipperGas
#4 Post by SkipperGas »
cgrenier wrote:Try the following: run "cmd" (right click run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter)
If Windows won't assign a drive letter, is there a way to still run chkdsk against the drive?
#5 Post by cgrenier »
SkipperGas, you can use Windows Disk manager to affect a drive letter to the partition.
ihimanshusoni
#6 Post by ihimanshusoni »
Chkdsk returns - The type of the file system is NTFS.
Unable to determine volume version and state. CHKDSK aborted.
what to do next?
#7 Post by cgrenier »
ihimanshusoni, if chkdsk doesn't work, try TestDisk, Advanced, List and copy your files. If it failed, use PhotoRec.
