Truecrypt drive: boot sector damaged?
Gibson
#1 Post by Gibson »
Hello, it appears my encrypted external USB-drive with 1TB of data has suddenly become inaccessible. I got a message that said, the volume header has become corrupted and it will use the backup header stored in the volume, but it didn't mount. I was eventually able to mount the volume by restoring the header from an external backup file, but i still can't access the files, it says it needs to be formatted.
When it was still working fine, there was always an inaccessible drive E:\ under "My Computer" and the Truecrypt volume remained hidden until mounted. When the header got corrupted, drive E:\ showed up as an empty, formatted hard drive. After restoring the backup header, drive E: is now entirely gone and the Truecrypt volume shows up as uninitialized with unallocated space in Disk Management.
A scan with Testcrypt shows a few results but it can't mount any of them:
Contrary to Windows Disk Management, i can see two entries for the external drive in TestDisk: one with the correct name and the mounted drive (X:)
Selecting the mounted Disk "X:" and "None" for the partition type, i get this:
It looks like the boot sector and the backup are bad, therefore no access to the file system. So far, i haven't tried to rebuild the BS, because i am not entirely sure if i am doing the right thing (or if it will even work, since the backup is bad, too). I just want to avoid making things worse and causing further damage. If i choose "Intel", it says "The partition sector doesn't have the endmark 0xAA55". Is it safe to rebuild the boot sector or do i need to to something else?
Re: Truecrypt drive: boot sector damaged?
Run TestDisk, X: (choose the unlocked truecrypt volume), None, Advanced, Boot, RebuildBS, List.
If you can see your files, chose Write, confirm, Quit.
If it doesn't work, use PhotoRec instead. If PhotoRec recovers only junk, it's because a wrong truecrypt header has been used (wrong encryption key).
Gibson
#3 Post by Gibson »
I tried to rebuild the Boot Sector, but it didn't work. "Search mft" takes 5 hours but it does nothing. It simply returns to the screen, where it says "Boot sector bad", no write option or anything. I selected the mounted volume, Partition type "None" and then i can choose between "Type", "Image Creation" or "Quit" (i assume this is the Advanced menu). I have set it to NTFS and then "Boot", like this:
If i select "List" instead of "Boot" it says: "Can't open filesystem. Filesystem seems damaged."
Also tried Photorec, but it recovers nonsensical data like 3 Gigabyte swf-files, but i am very sure i used the correct backup header, because Truecrypt shouldn't have accepted the password if it was wrong.
Rocky111
#4 Post by Rocky111 »
Looking for the same solution but not sure how initiate the process. Would it be possible for someone to make a video tutorial on it for newbies?
#5 Post by cgrenier »
If TestDisk failed to rebuild the boot sector, you should try PhotoRec. If PhotoRec recovers only broken files, it mean the truecrypt volume has been unlocked with a wrong key.
