Hello, everyone!
I extracted TestDisk (7.0 for Windows) from compressed archive and created "DESTINATION" folder inside it. Then I ran TestDisk to recover thousands of text files into that folder. I managed to delete almost all of the recovered files when I no longer needed them, but the folder itself together with a few files inside can't be deleted for some reason.
When I'm trying to delete the folder using Windows Explorer, I get "Could not find this item. This is no longer located in \testdisk-7.0. Verify the item's location and try again." And same goes for the two files inside.
Does anyone know what could cause this and how I can get rid of that folder? Would it even be properly erased when I reformat the disk (although I'm not planning on doing so in the near future)?
Your help is appreciated. Thank you.
Can't delete files recovered with TestDisk
Re: Can't delete files recovered with TestDisk
You may need to take ownership of the folders. http://support.microsoft.com/kb/308421
cgrenier, thank you for replying.
The folder has been in ownership of a user-group to which I belong. I opened properties of the folder and checked just in case and I have full control (permission to delete) of the folder, I even changed the ownership from the group to myself but the issue remains.
Although I discovered that files which can't be deleted inside the folder have an error displayed on the Security pane ("The requested security information is either unavailable or can't be displayed.") so I couldn't make sure I have control over them.
I mentioned recovering text files but by the name of those that can't be deleted I recognize them as media files (one is mp3 and another is mp4, but they have no extension and are corrupted--however, retained their size: ~10 MB and ~117 MB). I must've recovered more file types than I thought (since it was weeks ago, I forgot what exact file types I tried to recover with TestDisk). Now that I think of it, I remember trying PhotoRec but can't recall the details. If it helps, I'm sure I needed to recover an html file and had hundreds of thousands recovered files in the folder I can't delete now.
The issue of 2 files that can't be deleted doesn't bother me much. I just hope that the disk reformats correctly when the time comes, and thought it would be helpful to provide you with feedback to try avoid similar issues in the future.
